Author Topic: Albatros D.II Oswald Boelcke 1/144 scratchbuild  (Read 12395 times)
Offline Flamingo
Re: Albatros D.II Oswald Boelcke 1/144 scratchbuild
« Reply #15 on: May 27, 2024, 06:46:59 AM »
"MacGyver mode" ;D
Where can I get it? Well, here in this thread, and many more in this forum!
The poor man's lathe has been used by me already.
Keep on
Joachim
jets are for kids
Offline ondra
« Reply #16 on: May 27, 2024, 03:10:04 PM »
Many thanks for your nice comments, Nigel, Ben, Rick and Joachim! I am glad you find my MacGyver mode inspirative. :)
With the drawings almost finished, I started working on the fuselage. Whereas the front section will be vacuum formed, the rear section will be solid.
The shape looks ok so far, so in the next step I will fill the gaps in the moulds for the front part with milliput and in the rear part with styrene pieces.
Ondra
« Reply #17 on: May 27, 2024, 06:18:34 PM »
More impressive engineering. It's fascinating to see how you do all this.
« Reply #18 on: May 27, 2024, 11:51:06 PM »
Very impressive Ondra! Like Nigel, your processes always fascinate Me!
Offline Allan31
« Reply #19 on: June 01, 2024, 11:56:46 PM »
What a truly amazing process.
« Reply #20 on: June 06, 2024, 03:08:03 AM »
I am blown away by that mini-lathe. I used an old power drill recently to turn some dowels into gun barrels, but your set up is altogether much more sophisticated!
Excellent start on the fuselage. Have you thought of using wood to make the male part of your mould?
Offline ondra
« Reply #21 on: November 01, 2025, 09:44:30 PM »
Back at the workbench after a long break, I started working on the wings and the propeller.
As a true tool whore, I used my new toy, an ultrasonic knife I got from Aliexpress. Not exactly cheap, but worth every cent for scratchbuild.
My brush skills are very inferior, so I had to look for an innovative solution for the propeller lamination.
Eventually I decided to creat a sandwich of red and yellow plastic. I had to reduce the thickness of the red plastic using my DIY jig, now I have to let it cure.
Cheers.
Ondra
Online KiwiZac
« Reply #22 on: November 02, 2025, 09:36:41 AM »
An ultrasonic knife sounds very intriguing! I'll have to do some YouTube research. It's so nice to see you back on this.
« Reply #23 on: November 02, 2025, 07:22:10 PM »
I would say it's nice to see you back Ondra but I can't, because Imgur doesn't let users in the UK view your photos. So I am afraid I can't see what you are doing......
Offline ondra
« Reply #24 on: November 02, 2025, 07:51:54 PM »
Thanks for the info, Nigel, I did not know about the Imgur issue.
So here a few photos uploaded directly to this website.
Cheers.
Ondra
Offline ondra
« Reply #25 on: November 02, 2025, 07:54:04 PM »
Had to split the photos into multiple posts due to the size limitation.
Offline ondra
« Reply #26 on: November 02, 2025, 07:54:30 PM »
And the last batch.
« Reply #27 on: November 02, 2025, 08:38:29 PM »
Thanks Ondra, the Imgur issue only happened recently, and only affects those of us in the UK. I can see the photos now. The wing looks good and I'm intrigued to see how your prop turns out using the plastic strip approach. And of course I am now Googling ultrasonic knives..... :)
Offline DaddyO
« Reply #28 on: November 02, 2025, 08:48:23 PM »
Excellent Ondra
(I'd avoided the thread because of the Imgur problems; great to see some pictures of what you're up to)
Like Nigel I'm off to google those knives . . . .
Offline DaddyO
« Reply #29 on: November 02, 2025, 10:53:24 PM »
Woah! :o That is quite possibly the scariest thing I've ever seen. Given my casual and fairly clumsy approach to tool use rest assured I'm going to steer well clear of sonic knives so that I can hang onto my full compliment of digits ;)
