Author Topic: 1:72 Roden SE5a  (Read 22112 times)
Offline torbiorn
Re: 1:72 Roden SE5a
« Reply #30 on: August 22, 2024, 08:52:28 AM »
Nice and sharp - that PC10 overlap I always find very annoying (lots of work for something seemingly simple), but it does look good.
I get nervous looking at that Aldis sight on the stick. I’ve sent one gunsight flying with the airbrush that way: since then I thread them on a wire, make a loop of the wire and clamp it shut with a clothesspin.
Re: 1:72 Roden SE5a
« Reply #31 on: September 10, 2024, 04:04:50 AM »
Catching up (again!). I really like your Aldis sight and the idea of glueing the mounts to a stick so that you do not lose them. Good progress on this one - it is going to be another of your tiny masterpieces.
Offline Skyhook
Re: 1:72 Roden SE5a
« Reply #32 on: October 17, 2024, 06:26:19 PM »
Roden SE5s are great models?.the multipart fuselage is actually quite good if you do some careful sanding and dry-fitting before the final assembly? i have done a couple of these and they look quite right when assembled. The inpection panels are a bit tricky to make look good in 1/72, though?.
Cheers, Skyhook
Re: 1:72 Roden SE5a
« Reply #33 on: December 06, 2024, 05:34:11 PM »
I know I've been a little quiet here, but I didn't realise it had been 4 months!
Mostly due to a lack of mojo, but also there is now a lady in my life (totally unexpected, but what can one do? )
Anyway, I have just a small update to let you know I'm still here!
I tried applying the white stripe decals on the fuselage to see how they behaved and, not unexpectedly, they broke! So I designed a one piece mask for the fuselage sides including the stripe, letter A and background for the roundel, which is slightly off centre. The plan is to spray the decals with decal fix and apply the roundel over the white background.
They didn't turn out too badly!
The left side is a little rickety and neither A is quite as square as I would like it, but I can live with it.
The radiator shutters have also been painted, and the rocker covers added, but that's about it. Not much for 4 months I'm afraid, but some progress has also been made on the SS100 Jag.
Thanks for looking in!
Re: 1:72 Roden SE5a
« Reply #34 on: December 06, 2024, 07:27:35 PM »
That doesn't look too bad at all, keep going! I hope the lady can tolerate a chap who likes making little models...... ;)
Re: 1:72 Roden SE5a
« Reply #35 on: December 07, 2024, 04:58:08 AM »
Thanks, Nigel, and yes she can! A keeper!
Offline torbiorn
Re: 1:72 Roden SE5a
« Reply #36 on: December 07, 2024, 11:27:09 AM »
Congrats, company is better company than bits of plastic, no matter how nice or accurately to scale they look =)
Re: 1:72 Roden SE5a
« Reply #37 on: February 28, 2025, 10:00:32 PM »
I have finally regained a little mojo so this is back!
Firstly, the engine parts were fitted. The kit has both sides the same, which is not correct. The tacho drive to the rear of the head pointing aft should only be on the right side, and the little protuberance on the upper side of the head, to the rear, should only be on the left. That was corrected, and the cut outs on the cowling altered to match. Paint has also been added up front for the shutters, and the mounts for the sight are on.
Then it was time to bite the bullet and fit the upper wing.
First though, the jig had to be set up.
I'd be lost without the Aeroclub jig! The centre section wires were added, the struts were pinned to the upper wing, and it was locked into the jig. Then I "only" had to thread the wires through the upper wing and glue the bottom ends of the struts in place. Only about 2 hours work!
The rear sight mount is only loose in its holes so that I can adjust the height to match the Lewis mount later.
That's it for now, I'll tackle the rest of the rigging and outer struts very soon!
Re: 1:72 Roden SE5a
« Reply #38 on: March 01, 2025, 12:46:32 AM »
Good to see this back on the bench (and in the jig). She's looking good, hopefully the mojo will allow you to get this done!
Offline Dirigible-Al
Re: 1:72 Roden SE5a
« Reply #39 on: March 02, 2025, 04:35:02 AM »
I agree, good to see this moving again.
Alan.
Re: 1:72 Roden SE5a
« Reply #40 on: July 05, 2025, 08:01:06 PM »
Unfortunately mojo is still lacking on this one as it seems that every time I pick it up, something goes wrong! I've had a couple of wires pull out from the centre section, one of which is impossible to refit so will have to stay off. The other has been refitted and I am now at the stage where I can trim up the cabane rigging and start on the wing bays.
Very slowly, we are getting back to some bench time....
Re: 1:72 Roden SE5a
« Reply #41 on: July 05, 2025, 11:11:33 PM »
KEEP CALM, DRINK TEA AND CARRY ON!
Re: 1:72 Roden SE5a
« Reply #42 on: March 29, 2026, 04:20:23 PM »
This one has been fighting me all the way. A little more progress has been made now, but not before I managed to break both of the rear interplane struts. They were repaired and refitted, and a start was made on the interplane rigging. While removing a line during a test fit, one end got trapped in the aileron gap and when I removed the line it ripped the struts out. Half of the one that had previously been repaired was not found so a replacement had to be made. Refitted, rigging continued and is now done with the exception of the stagger wires. I thought I'd be clever and try to replicate the actual aircraft which has these wires attached to the struts not the wing surface. I'm beginning to regret not drilling the holes.....
Anyway, that is still to come. Here's a little picture story of the last week up to where I am now...
Back to the bench later today to hopefully finish the rigging and figure out what to do about the decals that I ruined by adding Microscale decal film - it left visible patches on the roundels. To be fair, they would have fallen apart without it, so it had to be done!
Thanks for looking in,
Offline Brad Cancian
    • Brad's Models
Re: 1:72 Roden SE5a
« Reply #43 on: March 29, 2026, 06:26:18 PM »
Wonderful job on the rigging Ian, great to see you back at this one - she's looking very nice!
BC
Re: 1:72 Roden SE5a
« Reply #44 on: March 29, 2026, 06:55:35 PM »
Nice to see this back on the bench Ian, and well done for persevering! The rigging is looking really neat and it's such a nice build it would be great to see this over the finish line.
