Author Topic: 1:32nd scale Bristol Scout C 1264  (Read 9178 times)
Online Mike Norris (UK)
« on: April 12, 2024, 07:06:51 AM »
I previously built the Copper State Models 1:32nd scale Bristol Scout C, serial No.1260 of No.5 Wing (RNAS), operating from Dover as part of Home Defence in 1916.
I'm now building the same model, but Scout serial No.1264, as it is now, flown by owner/builder David Bremner.
This model is of aircraft as flown by David's grandfather, Sub. Lt. Francis Holden ‘Bunnie’ Bremner of No.2 Wing (RNAS), operating from the Greek island of Thasos, off the coast of Bulgaria, during 1916.
This aircraft can be built from the kit, but only as it was during WW1.
However, David's present reproduction aircraft has differences, primarily in the cockpit.
These differences require the following modifications to the cockpit:
Remove the opening panel in the cockpit rear cross member
Remove the control lever from the upper right longeron
Fit the Pulsometer to cockpit right side frame and add associated pipe
Replace Tachometer drive with lead wire
Fit curved quarter panels at the front and rear of the cockpits upper longerons
Create engine controls (with control rods) at the cockpit left side frame, lower left of pilots seat
Replace pilots seat with better quality 3D printed seat (Gaspatch)
Remove the pre-molded clock from top, left side of the instrument panel
Add representation of the clock above magneto switch at lower left of the instrument panel
Remove compass and its housing from between the pilots foot boards
Add blip switch cable to rear of control column and under pilots foot boards
Add all visible cockpit bracing wires and control cables (rudder, ailerons and elevators)
Add modern four point safety harness in addition
Fit kit supplied lap straps behind the pilots seat
Add ‘Bunnie’s’ flying certificate to the map holder.
Also the engine is the Le Rhone 9J (supplied in the kit (pre-orders only).
The engine was built as supplied, apart from replacing the valve push rods with Nickel-Silver tube and adding spark plug lead using Modelkasten 0.6 (0.13mm) line,
Online NigelR
Re: 1:32nd scale Bristol Scout C 1264
« Reply #1 on: April 12, 2024, 07:29:34 PM »
Nice work Mike, and a great subject for a build. And you have some nice recent colour photos to base your build on as well! Lovely start btw.
Offline djuggie
« Reply #2 on: April 12, 2024, 10:47:27 PM »
Looking at your work makes my eyes water.  Beautiful cockpit and I love the engine.
Dennis
Offline Softscience
« Reply #3 on: April 12, 2024, 11:34:04 PM »
That engine looks amazing. Do you blackbase and then add the metallic colors?
« Reply #4 on: April 13, 2024, 11:05:07 PM »
Dennis
Ha, your comment, Dennis, reminds me of the late, great Michael Gambon who got fed up with stupid questions on chat shows so answered one saying that he used to be homosexual, but had to give it up because it made his eyes water!!!
Superb modelling, Mike.
« Reply #5 on: April 14, 2024, 12:01:40 AM »
Yet one more beauty in the making.
« Reply #6 on: April 14, 2024, 09:49:14 PM »
Yes I airbrush prime with a gloss black, such as 'Tamiya' X1, then apply 'Alclad' metalics (Steel, Duraluminium, engine exhaust etc).
Then brush 'AK Interactive' Kerosene wash over the cylinder fins etc,
« Reply #7 on: April 14, 2024, 09:51:50 PM »
Hi Nigel,
Yes I got the OK from David Bremner to walk around 1264 in the hanger at the Shuttleworth collection at Old Warden, Bedforshire.
So plenty of external and internal shots for reference,
« Reply #8 on: April 15, 2024, 03:26:24 PM »
Hi Nigel,
That's great Mike! I'm very excited to follow along with this as my personal preference is to build modern "warbirds" rather than in-service machines, and I'm interested to see your approach to this rather well-known (and so well-documented) aircraft.
Offline AngryJazz
    • @AngryJazz_Models
« Reply #9 on: April 19, 2024, 06:53:36 PM »
Always enjoy your builds! This one is already looking amazing  :)
//Ben - @AngryJazz_Models
Offline Brad Cancian
    • Brad's Models
« Reply #10 on: April 19, 2024, 07:14:09 PM »
Oh my Mike, another stunner in the works! I don't know how you do it!
Hats off to you, sir!
BC
« Reply #11 on: April 29, 2024, 12:14:36 AM »
Hi all
When daylight from above passes through the clear doped linen covering of this aircraft, the internal structures and bracing wires can be seen as shadows
To represent this effect, a combination of roundel decals, masking and painting and the addition of appropriate decals from the 'Xtradecal' Black Stripes (XPS1) set was used
These will be airbrushed over to blend them with the base colour to create the shadow effect
« Reply #12 on: April 29, 2024, 12:51:05 AM »
Moving along nicely Mike. Your framework should look excellent when finished!
Offline ondra
« Reply #13 on: April 29, 2024, 01:54:00 AM »
Magnificient work, Mike, looking excellent so far.
Cheers.
Ondra
« Reply #14 on: April 29, 2024, 01:07:36 PM »
Beautiful, Mike... the Holy Grail of WW1 modelling—convincing sunlight through clear-doped linen! Looking forward to seeing the finish result.
