Author Topic: Roden 1/32 Strutter, A1083 45 Squadron  (Read 11404 times)
Online NigelR
« on: February 09, 2024, 02:14:50 AM »
I've just started a slow and steady build of the Roden Strutter using the Aviattic decals and add-ons. Just working on the interior at present.
My subject aircraft has a CDL fuselage so the I attempted to emulate the roundels showing through on the interior. I sprayed the interiors white, sprayed the roundels (a little heavier than I intended) and then misted some white over the roundel to make it a bit less obvious. I should have gone a little heavier with this....  My circle cutter could not cut a small enough circle for the central red circle, so these are a bit wonky. Anyone know of any good circle cutters?
I painted the framing by hand. Although the supplied masks are very clever, I am better with a paintbrush than scissors and found painting the framing quite easy. I added a bit of pre-weathering as well.
I then applied the interior CDL decals (which are quite subtle over the white), added some rigging from EZ Line and added more weathering. Note I have added a flase floor from plasticard to cover up the join in the fuselage:
Finally here's the lovely resin instrument board which I spent too much time detailing. Although the supplied decals are nice, I used some Airscale ones which I have had in my stash for years.
Re: Roden 1/32 Strutter, A1083 45 Squadron
« Reply #1 on: February 09, 2024, 03:51:28 AM »
Great start, Nigel. Like that see-through roundels.
Online Flik63J
« Reply #2 on: February 09, 2024, 05:36:20 AM »
That’s a gorgeous instrument panel Nigel………looking forward to seeing your build unfold.
David
Online DaddyO
« Reply #3 on: February 09, 2024, 05:36:05 PM »
Loving it so far Nigel.
That instrument panel is worthy of a display all by itself  :)
(Have a chat about roundel cutting tomorrow)
« Reply #4 on: February 09, 2024, 07:14:20 PM »
Beautiful work, Nigel. That instr panel is wonderful.
As regards applying more white overspray on internal roundels I don't think you needed it. SimonCornes' detail shots from the RAF Museum Strutter show how strongly the roundels showed through (over in the Aircraft ref section.) Admittedly this is in a brightly lit hall but no brighter than outdoor sunshine.
Online NigelR
« Reply #5 on: February 09, 2024, 08:08:39 PM »
Thanks everyone, I'll post more updates over the coming weeks.
If in doubt - ask a professional signwriter! Will do, I hope you have some clever tools for me.....
Thanks for this Sandy, it allows me to be happy with what I did. BTW, it was your build thread that alerted me to the need to do this, so many thanks for that as well!
Offline AngryJazz
    • @AngryJazz_Models
« Reply #6 on: February 10, 2024, 07:01:03 AM »
Wow amazing start! I really like how the roundel is done on the inside.
Looking very much forward to this build  :)
//Ben - @AngryJazz_Models
« Reply #7 on: February 12, 2024, 09:44:54 PM »
Brilliant work on that instrument panel Nigel.  I also agree that your interior paintwork looks great. Here is a link to a circle cutter I recently purchased on EBay.  It’s from DSPIAE, all aluminum construction, works great!
https://www.ebay.com/itm/296042075165?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=irezurfeqqk&sssrc=4429486&ssuid=GQ4-MqwKT9u&var=&widget_ver=artemis&media=COPY
Tim
Online NigelR
« Reply #8 on: February 13, 2024, 08:50:41 PM »
Thanks Tim, that circle cutter looks fantastic so I just ordered one.
Offline xan
« Reply #9 on: February 14, 2024, 06:48:54 PM »
Lovely Instrument board , very nice job!
Online NigelR
« Reply #10 on: February 22, 2024, 11:39:10 PM »
A bit of progress here, slow as always...... I could do more on the interior but I am going to stop here as I don't want Schrodinger to get his hands on too much detail.
I cut a new front floorboard from plasticard based on the photos of the RAF Museum Strutter in the Datafile. I also used some HGW paper seatbelts for the first time and I have to say I wasn't that impressed, I definitely prefer photoetch. However, as I didn't have anything suitable in PE these will have to do.
« Last Edit: February 22, 2024, 11:47:02 PM by NigelR »
Online NigelR
« Reply #11 on: February 23, 2024, 04:18:41 AM »
And in an even bigger shock, I surprised myself and got a lot done this afternoon. Got the interior all buttoned up:
The Aviattic resin instrument panel and additional details are superb. It was quite easy to fit the instrument panel on the original Roden mountings, and I even managed to add the  teeny-tiny instrument lights (look carefully and you will spot them):
Things should proceed a bit more quickly now as it's decalling and gluing together all the big bits.....
Online DaddyO
« Reply #12 on: February 23, 2024, 06:28:59 AM »
Looking good Nigel. Shame all that lovely detail on the instrument panel will be lost from sight once the wing goes on  :(
Can't wait to see her all decalled up and ready
« Reply #13 on: February 23, 2024, 07:08:09 AM »
Wow!
Nice work, Nigel.  Your cockpit looks amazing.
« Reply #14 on: February 23, 2024, 10:01:19 PM »
Lovely looking interior!
