Author Topic: 1:32nd scale Macchi M.5  (Read 9838 times)
Re: 1:32nd scale Macchi M.5
« Reply #15 on: January 20, 2024, 03:40:20 AM »
Just gorgeous. I love those M.5s!
Offline Edo
« Reply #16 on: January 20, 2024, 06:20:50 PM »
on a side note to a wondefully built kit, I’ll add a comment on the green mouse depicted on the plane, as maybe not of all ypu know its meaning in Italian.
The green mause, or rat, refears to an italian slang expression: “ti faccio vedere i sorci verdi”, that translate, more or less, into: “I’ll show you the green rats” that means: “I’ll let you through a very hard time”.
it is not very used nowadays, but it was common in the past. consider this expression: “by boss made me see the green rats” meaning “i had a hard time at work”, or “if you don’t stop it, i’ll show you the green rats!”, meaning “if you don’t stop it  i’ll beat you up in a bad way”.
may be you also saw the green rats on ww2 planes as it was the insigna of 205 bombing squad the first to recive the SM79.
ciao
edo
Online Flik63J
« Reply #17 on: January 20, 2024, 08:04:01 PM »
That’s very interesting Edo thank you………..for sure in this forum we can all learn a lot from each other!
David
« Reply #18 on: January 20, 2024, 09:53:22 PM »
Hi Edo,
I didn't know the origin of the rat marking.
Thanks for that,
« Reply #19 on: January 20, 2024, 10:19:54 PM »
Beautiful work as always Mike.
I'm certain that your client will be very pleased!
« Reply #20 on: January 25, 2024, 01:40:35 AM »
Hi all
The engine installation for the Macchi M.5 is ready to be fitted to the hull.
The propeller will be fitted later in this build,
The frame bracing wires are 0.08 mm diameter mono-filament with blackened 0.4 mm diameter Brass tube.
Turnbuckles are the 'Gaspatch' 1:48th scale metal versions.
« Reply #21 on: January 25, 2024, 09:09:00 AM »
Your engine pod and struts look superb Mike, beautiful work!
« Reply #22 on: January 25, 2024, 12:32:40 PM »
Somehow I missed the last few posts on this thread. That “power egg” is a work of art…
« Reply #23 on: January 25, 2024, 06:00:51 PM »
It is a great build, Mike. The engine component looks spectacular
« Reply #24 on: January 25, 2024, 06:54:47 PM »
Lovely work Mike, another great build on the way here.
Offline Edo
« Reply #25 on: January 26, 2024, 05:12:54 PM »
that engine is super!
ciao
edo
« Reply #26 on: January 26, 2024, 06:45:10 PM »
Looks to me like the real thing recovered from a Macchi...
Very convincing!
Offline AngryJazz
    • @AngryJazz_Models
« Reply #27 on: January 29, 2024, 05:26:00 PM »
Great work Mike! Engine looks stunning :)
//Ben - @AngryJazz_Models
« Reply #28 on: January 29, 2024, 07:00:52 PM »
Hi all
The model has moved on a bit since my last post.
The upper wing has been fitted and all wire rigging done.
I just have the outer wing support struts to make and fit.
These will be made from 0.9 mm formed Brass tube.
Also I have to fit and rig the two ailerons, under wing floats and propeller
« Reply #29 on: January 29, 2024, 07:48:47 PM »
That's definitely progress! Looking very good Mike, you are on the home stretch now.
