Author Topic: 1:32nd scale Macchi M.5  (Read 10053 times)
« on: December 18, 2023, 03:03:21 AM »
The 'HPH Models' 1:32nd scale resin model of the Italian Macchi M.5 float plane.
This is a commission build for the Commander of the Italian Frigate 'Federico Martinengo'.
His ship was named after the Italian naval pilot of WW1, Federico Carlo Martinengo.
I've previously built a version of this model and have a build log on my web site.
The only real differences between the two models will be the aircraft markings.
As such, I'll not create a detailed build log for this model here on the forum, just progress shots,
« Last Edit: December 18, 2023, 03:29:57 AM by Mike Norris »
Re: 1:32nd scale Macchi M.5
« Reply #1 on: December 18, 2023, 05:29:13 AM »
The basic engine modified and with additional detail added in Brass,
« Reply #2 on: December 18, 2023, 07:29:43 PM »
Lovely work as always. I'm sure your client is going to love this.
« Reply #3 on: December 18, 2023, 09:00:47 PM »
Superb as always. I have this one in the stash and will study your beautiful cockpit for inspiration.
« Reply #4 on: December 19, 2023, 12:24:15 AM »
One of my very favorite Great War aeroplanes. Thanks for posting these, Mike, I've read the previous build log a couple of times now but it's still a treat to see this one!
« Reply #5 on: December 21, 2023, 01:26:46 AM »
I've added the following, which are not supplied in the kit:
External compass shroud
External base for gun sight.
Support struts for lower wing floats (Brass tube and rod).
Support struts for the tailplane (Brass tube and rod).
Lower half of the rudder post,
Offline Whiteknuckles
« Reply #6 on: December 21, 2023, 04:54:06 PM »
One lucky client Mike! Beautiful work on a beautiful aircraft.
Eternal Apprentice
« Reply #7 on: December 21, 2023, 07:26:36 PM »
It's a pleasure to see your fine engineering skills on display again. More lovely work.
« Reply #8 on: December 23, 2023, 11:50:40 PM »
Hi all
I've replaced the kit supplied 'Z' struts between the engine support frame and underside of the upper wing.
The kit struts don't align correctly with their attachment points and not every strut has a protruding locating rod.
The replacement struts are Brass tube (formed to an aerofoil profile) with internal rod.
« Reply #9 on: December 24, 2023, 10:20:22 AM »
Brilliant work on this... erm...challenging kit!
BTW, if you would like to share this build with other Macchi fans, we have a FB group dedicated to Macchi aircraft of all eras. Search for Wacky Macchis if so inclined...
« Reply #10 on: December 24, 2023, 07:56:37 PM »
More excellent work Mike, this is definitely another challenging build.
« Reply #11 on: December 30, 2023, 09:57:12 AM »
Outstanding work Mike!
Offline AngryJazz
    • @AngryJazz_Models
« Reply #12 on: January 02, 2024, 05:09:48 PM »
Excellent work  :)
//Ben - @AngryJazz_Models
« Reply #13 on: January 20, 2024, 02:40:28 AM »
Some progression the Macchi M.5.
Painted using 'Tamiya' acrylics and oil paint for the wood hull.
'Aviattic' linen effect decals applied to flight surfaces.
Personal markings are custom made by Mika at 'Arctic Decals'.
The model, especially the engine still require weathering.
« Reply #14 on: January 20, 2024, 03:10:17 AM »
Lovely work Mike, this is looking really good. Can't wait to see more....
