Author Topic: Finished! 1/72 Airfix Hawker Hurricane (and extras)  (Read 23003 times)
Re: WiP - 1/72 Airfix Hawker Hurricane (and extras)
« Reply #15 on: December 07, 2023, 12:12:47 AM »
RE: the detail/paint sequence, now you've got me really curious... how the heck are you going to shoot color into that bay and get coverage on the floor and sides of the without paint buildup? Just a super-light touch...?
Offline Brad Cancian
    • Brad's Models
« Reply #16 on: December 07, 2023, 05:42:36 PM »
Indeed Dutch - a light touch :) I'll also use alclads which spray quite thinly to paint the aluminium. I'll pick out the guns in a black with some drybrushing and a wash to finish it off.
Currently focusing on the cockpit; it's already pretty good out of the box, save the instrument panel and seat. I have the Eduard etched fret for the kit which will sort out the instrument panel, but I think I am going to need to scratch build a seat, as the kit one is pretty bad. Oh well, i'm always up for a challenge...!
Cheers again,
BC
« Reply #17 on: December 09, 2023, 06:56:59 AM »
Very fine modelling. Especially the Brownings compartment draws my attention.
« Last Edit: December 19, 2023, 04:44:45 PM by PrzemoL »
« Reply #18 on: December 11, 2023, 11:56:52 AM »
Exquisite work Brad, the extra detailing will really make this pop! Hard to believe it's only 1/72!
    • Brad's Models
« Reply #19 on: December 17, 2023, 04:43:46 PM »
Thanks all!
Some more minor progress this afternoon. I have scratch built a seat from 10 thou plastic card, as well as a bulkhead, which will cover the seam between the kit part and the fuselage halves. The kit seat is next to the new seat for comparison. I used parts from the Eduard SS501 sheet for the pan detail and adjustment handle.
I scratch built a new control column also, as the kit one (right) is a bit chunky. My scratch built effort is not entirely accurate, but it will do the trick.
I also went back to the flap wells; I decided to remove the roof of the longer bays as I was not happy with the trailing edge join; this way I can simply thin the kit's upper wing and be done. I also discovered to my dismay that the CMK flaps are about 2-3mm too long (as you can see from the resin flap piece i've sat next to the left bay for comparison)... this is odd as the bay inserts fit reasonably well... did CMK not even measure the kit? Sigh. There was no way to trim out the extra length due to the resin parts rib spacing, so, I scratch built a new set of flaps from 10 thou card and thin strip (in white). I might as well have not bought the set, to be perfectly honest...
I think we're just about ready to start putting some paint on this thing somewhere...! That being said, I expect a slow down over Christmas due to work and family commitments... oh well.
BC
Offline Radarman
« Reply #20 on: December 18, 2023, 01:22:46 AM »
Looking good, Brad.
With a bit of luck you might be hit by a freak snowstorm over the
Christmas holidays and get snowed in. Then you can concentrate on modeling.
I look forward to seeing your next installment from here in the northern hemisphere.
 Kevin
« Reply #21 on: December 30, 2023, 06:56:12 AM »
Bravo Brad, the extra detail you're adding will really set this one off!
« Reply #22 on: December 30, 2023, 08:43:18 AM »
This is continuing to be inspirational Brad. Awesome work!'
    • Brad's Models
« Reply #23 on: December 30, 2023, 05:25:08 PM »
Thanks gents!
Slow going on this one over Christmas and into the new year with family visiting, plus some reviews still to do - hopefully some progress late on in January on this one once things settle down!
Cheers again!
BC
    • Brad's Models
« Reply #24 on: January 02, 2024, 05:41:51 PM »
Hi everyone - happy new year to you all! I managed to finally get some paint onto the interior, engine, and gun bay:
This thing is tiny for my old eyes... I think i'm at the point of getting some of the major construction elements done next... finally!
Cheers!
BC
« Last Edit: January 02, 2024, 05:57:44 PM by Brad Cancian »
« Reply #25 on: January 03, 2024, 05:22:15 AM »
If this is your swansong for 1/72 then it's a banger, brilliant work Brad! It looks fantastic! I'd love to achieve effects like this in this scale.
« Reply #26 on: January 03, 2024, 09:47:33 AM »
I was wondering how you were going to pull the paint on those gun bays off... brilliantly, as usual! I built the old Revell Hurricane a couple of times back in the late '60s/early '70s, and remembering how small it was this all seems even more impressive.
« Reply #27 on: January 04, 2024, 10:52:24 AM »
Amazing work!
Offline Whiteknuckles
« Reply #28 on: January 04, 2024, 01:30:35 PM »
Amazing work!
Agreed!!
This is shaping up to be a little beauty for sure :)
Have you used washes? If so, what do you use?
Eternal Apprentice
    • Brad's Models
« Reply #29 on: January 04, 2024, 06:19:36 PM »
Thanks gents!
Andrew - indeed I do; the wash on this one is raw umber oil paints.
Progress update - fuselage halves are together and wings are mounted. I fitted the upper wing to the fuselage halves first; the fit of the upper wing panel / piece is very nice. The lower wing piece was then added - the fit here is not so great; it looks like the wings are actually slightly different spans and chord... sigh. Nothing some filling and sanding can't fix (though it is still a tad annoying for a modern kit).
Cheers again!
BC
