Author Topic: 1/72 CMR Armstrong Whitworth FK.10  (Read 4926 times)
« on: October 17, 2023, 08:37:34 AM »
This is the 1/72 Czech Master resin kit. I don’t remember how i acquired it but it is without boxing or instructions. ( I have several CMR kits like this)
The detail is really fine with thin trailing edges. I won’t cut away the ailerons for fear of damaging them.
Here’s an artist rendering of the aircraft:
The kit:
After some cleanup, I decided to make the struts out of brass strip. I used the kit resin ones as a template
I added some interior details to liven it up a little. The brass struts are just placed there to check fit.
I’ll come back to this once I finish my Deperdussin build.
Thanks for looking in!
Tim
Re: 1/72 CMR Armstrong Whitworth FK.10
« Reply #1 on: October 17, 2023, 12:28:17 PM »
Talk about obscure, both the aeroplane and the kit! Looking forward to seeing what you can make out of this one, Tim.
Offline chunks
« Reply #2 on: October 17, 2023, 02:05:51 PM »
I had that kit. It came from the original Aviation Usk in the 1980's.  Back in the days when Tom had us send him a self addressed stamped post card with the kit name and number on it.  Even the plastic packaging looks the same before CMR starting using boxes.  I look forward to seeing what you do with it.
Online DaddyO
« Reply #3 on: October 17, 2023, 05:36:58 PM »
Love it Tim. :)
Good call about the ailerons - I suspect you'd end up using a bit of choice language
« Reply #4 on: October 17, 2023, 05:51:28 PM »
This will be an interesting subject. Will watch with pleasure
Online NigelR
« Reply #5 on: October 17, 2023, 08:15:51 PM »
Lovely subject and a good starting point, although a lot of work required. And I think you will be up to it! A great start.....
« Reply #6 on: November 14, 2023, 08:54:50 AM »
Good day all.  Thank you for the encouraging words on my Deperdussin build.
I had a productive weekend and enjoyed some quality bench time with this AW FK-10.
The interior was painted up and a little extra detail added. I didn’t add a lot because despite being a two seater, not much is visible through the small openings.
I have no interior photos so everything is pure conjecture.
Next, I closed the fuselage and added the two center wing support beams. The section inside the fuselage is stained a wood color.
The Clerget engine was added and the cowling is just tacked on for the photo.
The air intake pipes are Contrail strut material. I ground out the ends with a Dremmel bit.
I’ll need to fill some fuselage seams again but overall looking ready for paint
Next week I’ll start working on the wings.
Tim
« Reply #7 on: November 14, 2023, 12:51:36 PM »
For a 1/48 build I completed recently, this level of detail was me "going all out"...and still I think there was room for improvement. You're far too modest Tim!
« Reply #8 on: November 14, 2023, 01:39:21 PM »
You sure that flat blobby thing was actually part of the kit, Tim? I only ask 'cause it kind of looks like some old chewing gum I peeled off the bottom of my shoe the other day... :)
Marvelous job so far... can't wait to see it completed!
Offline Brad Cancian
    • Brad's Models
« Reply #9 on: November 14, 2023, 06:03:33 PM »
Love it Tim, this is shaping up very nicely!
BC
Online DaddyO
« Reply #10 on: November 14, 2023, 06:28:59 PM »
Love it so far Tim. :D
Going to be a head turner when it's finished
« Reply #11 on: November 14, 2023, 09:26:28 PM »
A friend on another forum likened it to a pile of cat vomit 🤮!  It is an odd way of casting the parts but they are very detailed and clean up very nicely.
Tim
« Reply #12 on: November 14, 2023, 10:26:28 PM »
Great work on that crude material. Fingers crossed!
Online NigelR
« Reply #13 on: November 14, 2023, 11:14:40 PM »
Wow, looking good already! I really wanted to see this one built......
« Reply #14 on: November 15, 2023, 01:56:18 AM »
Interesting project. I had no idea it was a 2 seater and I have a vac kit of it in the stash!
