Author Topic: Kette of Dr1's  (Read 30165 times)
Re: Kette of Dr1's
« Reply #90 on: January 28, 2024, 11:38:32 PM »
Great thread, Paul, these are litttle beauties, each and every one... I don't know which one is my favorite! I'd hate to have seen them coming, had I been flying a FE. I recently re-read No Parachute and Lee at one point talked about a Triplane easily breaking off a combat by climbing away, going up like he was in a lift. He and the others in 46 Sqdn viewed them with something like superstitious awe.
Looking forward to seeing them completed!
Re: Kette of Dr1's
« Reply #91 on: January 28, 2024, 11:45:23 PM »
Dutch, that book, and his other one, are my two favorite memoirs of the war in the air from WWI.
Paul, these are wonderful and I love this build thread.
Online DaddyO
Re: Kette of Dr1's
« Reply #92 on: January 29, 2024, 12:18:03 AM »
Wonderful looking builds Paul.  Love the group shot!
Cheers Tim :D
Working on the base, which is lovely, but a dirty great knot on the edge means a bit of repair work and some careful painting to blend in the miliput  :o ;)
Thanks Dutch. Must pick that one up.
I was reading about a combat from an Se5 pilot (I think) who described how when on the tail of one it just applied full rudder and skided away  :o
Thanks Warren. Glad you're enjoying it so far. They are a bit rougher than I'd like in places, but I'm pretty pleased overall so far and it's good to get this one out of my system ;D
Re: Kette of Dr1's
« Reply #93 on: January 29, 2024, 07:52:38 PM »
They are looking fantastic Paul. Seems like you have got enough time to get the base done before Bovington.....
Re: Kette of Dr1's
« Reply #94 on: January 29, 2024, 08:07:12 PM »
It is always a great view, to see a couple of examples of the same type. Lovely job all around!
Re: Kette of Dr1's
« Reply #95 on: February 02, 2024, 08:24:45 AM »
I agree with Prze - same-type builds are fascinating to see, especially when there's such variety in schemes. Great work!
Online DaddyO
Re: Kette of Dr1's
« Reply #96 on: February 02, 2024, 05:26:13 PM »
Cheers Nigel. Base now done so I'll bring them to Bovy next weekend  ;D
Thank you Prze - they look nice grouped together; I'm all tripe'd out for a bit, but there are a couple of other schemes I'd like to do at some point . . . .
Hi Zac. Thanks matey. Need to tone down the white cowls when I'm weathering them (I should have used a slightly off white tone in retrospect - ah well always next time) :o
As mentioned above the base is now made up and I'm working on dressing the figures suitably having sorted out the poses; I'll post a few pics of the finished models once they're weatherd a bit  :)
« Last Edit: March 13, 2024, 06:20:55 PM by DaddyO »
Online DaddyO
Re: Kette of Dr1's
« Reply #97 on: March 13, 2024, 06:29:13 PM »
Right with the Albatros completed (and another model started)  :o it's time to get back to the pilots for the Dr1's.
These are based on 3d printed resin figures which I had in a box of various 1/72 plastic/resin figures. I've modified some poses so they work together as a group and re-dressed them all in more appropriate clothing using putty. (My preferred mix is 50% Duro and 50% Miliput or Magic Sculpt) A quick spray of primer revealed a few bits which needed tweaking hence the patchy colours on some. Pippart is showing some of his new charges a tactic and will be in a white jumper to help him stand out (jacket shown on the left will be slung over his Dr1 fuselage)
Hopefully get some paint on them this weekend and be able to focus on the next build . . .
Re: Kette of Dr1's
« Reply #98 on: March 14, 2024, 07:42:34 AM »
What an excellent touch!
Online DaddyO
Re: Kette of Dr1's
« Reply #99 on: March 14, 2024, 05:38:08 PM »
Thanks Zac  :)
Offline djuggie
Re: Kette of Dr1's
« Reply #100 on: March 14, 2024, 10:18:18 PM »
Paul,
Excellent work on these beautiful aircraft and in 1/72nd.  For the detail you add, you seem to build very quickly.  Building more than one kit at a time can be a challenge.  And it was Phoen's fault.  After the release of his Sopwith Triplane sheet, I did the entire Black Flight, including Collishaw's twin machine version.
Your models are of a very high quality and a pleasure to watch the progress.
Dennis
Online DaddyO
Re: Kette of Dr1's
« Reply #101 on: March 14, 2024, 11:27:15 PM »
Paul,
Dennis
Many thanks Dennis
I don't think of myself as a quick builder, but I do tend to have a lot of projects on the go at once which means they sometimes appear after each other quite quickly. I did find building four at once a real challenge, even with a simple model like the Dr1. Not sure I'd attempt as many again, but have got in mind a pair or two . . .
I agree the Pheon decal sheets have a lot to answer for - it was the gift of this decal set which started the ball rolling  :) Strangely enough the Dave (the chap who gave me the Dr1 sheet) pointed out a couple of other Pheon sheets at a recent show which were going cheap (including the Sopwith Triplane sheet) so I may need to abstain from buying any more decals for a while since I can't keep up with the backlog  ;D
Re: Kette of Dr1's
« Reply #102 on: March 15, 2024, 09:05:48 PM »
The figures look really nice Paul. Looking forward to seeing them painted up and on the base.
Offline Gene K
Re: Kette of Dr1's
« Reply #103 on: March 15, 2024, 11:55:57 PM »
Paul,
Did you print these yourself, and if so, can you give a link to the source files, please?
Gene K
Online DaddyO
Re: Kette of Dr1's
« Reply #104 on: March 16, 2024, 01:40:58 AM »
Cheers Nigel  ;)
Paul,
Gene K
Hi Gene.
Sadly I'm not sure of the origin of the figures other than they were 3D printed civilians (I was given a box of suitably sized figures when I started 1/72 aircraft) For all of these I added flying clothing to them in putty after scraping away their original costumes. A couple also needed poses altering to make them fit in the group.
