Author Topic: Kette of Dr1's  (Read 29803 times)
Re: Kette of Dr1's
« Reply #60 on: November 23, 2023, 03:59:10 AM »
Lovely work Paul, and nice save!
Offline DaddyO
Re: Kette of Dr1's
« Reply #61 on: November 23, 2023, 06:18:17 PM »
Cheers Zac
On the plus side they are now even thinner so probably nearer to scale thickness  ;D
Re: Kette of Dr1's
« Reply #62 on: November 23, 2023, 07:12:22 PM »
Good progress all round, nice work on those tiny props! Looking forward to seeing the whole Kette together.
Will your trompe l'oeil work include painting in the inspection panels in front of the undercarriage?
Offline DaddyO
Re: Kette of Dr1's
« Reply #63 on: November 23, 2023, 08:20:05 PM »
yep, should get around to that at some point before too many wings are added  ;D
Offline DaddyO
Re: Kette of Dr1's
« Reply #64 on: December 01, 2023, 08:02:50 PM »
Right decided that if you're doing a job etc . . .  ;)
Here are the fixings for the access panel  :o
Offline DaddyO
Re: Kette of Dr1's
« Reply #65 on: December 01, 2023, 08:05:21 PM »
And combined with a piece of sanded down piece of 5thou plastic card and a bit of paint (repeated 4 times of course) give us some access panels (May not be entirely accurate, but will have to do)
Now back to decals and assembly :)
Re: Kette of Dr1's
« Reply #66 on: December 01, 2023, 11:25:25 PM »
That's pretty impressive in such a tiny scale! Better than just a paint outline.....
Re: Kette of Dr1's
« Reply #67 on: December 02, 2023, 01:59:50 AM »
I’m really glad you added those access hatches Paul. It’s a not so visible detail but adds a lot to the overall look. Nice work!
Re: Kette of Dr1's
« Reply #68 on: December 02, 2023, 02:48:03 AM »
That's awesome!   Where did, or how did you make, the nuts/bolts?
Offline DaddyO
Re: Kette of Dr1's
« Reply #69 on: December 02, 2023, 05:30:13 AM »
Cheers Nigel - You're dead right although there was a bit of muttering at the time I'm glad I added them ;)
Thanks Tim  ;D
Hi Warren, glad you approve.
The nuts/bolt rivets are made by a company called Masterclub and come in various sizes and styles. These are 0.5mm diameter and fit into a 0.4mm hole. I secured them with varnish which is my preferred 'glue' for non stressed tiny items (I always make a right mess with superglue when using tiny amounts)
Re: Kette of Dr1's
« Reply #70 on: December 03, 2023, 07:50:05 PM »
You are really working fast Paul, but keeping high standards.
Excelent results!
Re: Kette of Dr1's
« Reply #71 on: December 04, 2023, 01:05:01 AM »
Thanks DaddyO!  I've found the 0.6 mm size, guess that'll have to do. This will work out better than my plastic Grandt Line bolt heads.
Offline DaddyO
Re: Kette of Dr1's
« Reply #72 on: December 04, 2023, 04:34:12 AM »
Excelent results!
Thanks Willem  ;D
Feels a bit slow at times because everything needs repeating 4 times, but overall getting there now with wings being added and the models starting to come together
Glad to help Warren. Originally I tried trimming them down a bit, but they're easier to use full length if they don't poke into a visible area (I first used the flat rivets  for buttons on 54mm figures)
Offline DaddyO
Re: Kette of Dr1's
« Reply #73 on: December 06, 2023, 05:18:39 AM »
With a pair of wings and tails now attached to each of the four models attention turned to those little bits and bobs that always get left to last. Tail struts were made from shaped sprue stretched in the usual way. Whilst I was melting plastic I also made up an instrument bar from sprue and added a few instruments cut from the Eduard etch fret with painted faces for a bit of fun  ;)
Re: Kette of Dr1's
« Reply #74 on: December 06, 2023, 07:42:31 PM »
Looking very nice. That streaking looks really good, I think this photo shows it really well.
