Author Topic: Collet for very small drill bits  (Read 4114 times)
« on: September 29, 2023, 07:01:08 PM »
I have a Proxxon Micromot 230/E. The smallest collet is too wide to take very small drill bits (0.3 mm). Does anyone know of a third party brand collet that fits the 230/E?
I realise there is a big chance of breaking the small drill bits in a high speed devise, but I have some upcoming work fir which I want to use the 230/E in combination with the Proxxon cross side table:
https://cdn.axminstertools.com/media/catalog/product/cache/6aa9e1e59bcc5998e1687ab5ba3e27a4/7/0/702050_xl.jpg
Re: Collet for very small drill bits
« Reply #1 on: September 29, 2023, 10:16:49 PM »
Use .3mm bits from DBU. All the shafts are a uniform size (~1/8”) and will fit in any drill collet. I would not use a .3mm HSS drill bit in a machine, ever.
« Reply #2 on: September 30, 2023, 12:09:24 AM »
The slightest side pressure will shear that bit clean off.
« Reply #3 on: September 30, 2023, 12:36:07 AM »
Wow, Willem, that's ambitious! I have no experience with anything but hand-drilling (with the Acalox 201 mini-grinder, per Sandy's advice) at that size, but you might want to check in with Kensar, who if I remember correctly was using #85/0.011" bits in his bench-top mill a few weeks ago to cross-drill the 0.6mm aluminum-tube attachment points in the rigging on his Strutter.
« Reply #4 on: October 01, 2023, 02:34:49 AM »
Thank you Bo, Steve and Dutch for you comments.
@ Bo
I know of these bits, but the shipping cost to Europe are prohibitive, and I haven't been able to source the same quality with a 1/8th inch shank on this side of the pond.
@ Steve
I thought of that, and in my heart I know you are right. It won't matter if the shank was 1/64 inch or 1/8 inch
@ Dutch
I looked at Kensar's build log but the build log shows he uses drills with a 1/8 inch shank too.
I'm afraid I will have to come up with a better idea...
« Reply #5 on: October 01, 2023, 02:53:13 AM »
No, you won't. I can't remember the brand right now, I'll check when I get home. Drills are available that will hold a .3mm jobber bit, I use it myself.
« Reply #6 on: October 01, 2023, 05:18:28 AM »
Thanks Ian, much appreciated!
« Reply #7 on: October 04, 2023, 03:19:44 PM »
This is what I use.
https://www.starrett.com/products/precision-shop-tools/pin-vises-sets
I doubt very much you'll find a power drill collott this small.
« Reply #8 on: October 05, 2023, 02:30:58 AM »
Thank you all guys.
I finally found what I was looking for in this older thread:
https://forum.ww1aircraftmodels.com/index.php?topic=13745.15
via the link in Reply #24 by Berman.
I fear Steve is right but I'm going to try it anyway  ;)
To be continued...
Offline Scaleber
« Reply #9 on: October 06, 2023, 07:06:49 AM »
eBay couldn't resolve the link for me, can you post some details here wrt what you got? Thanks / Ian
« Reply #10 on: October 06, 2023, 08:33:29 PM »
Ian, I have the same problem with the link. When I posted it, it worked just fine. What I make of it, the offer has ended. Sorry abour that.
However, I did find exactly what I need: a chuck for my Proxxon Micromot.
Again, closer to home than I thought:
https://www.proxxon.com/en/micromot/tools-accessories.php?search#28941
Offline Scaleber
« Reply #11 on: October 06, 2023, 09:29:10 PM »
Brilliant, thanks / Ian
« Reply #12 on: October 13, 2023, 03:32:06 AM »
Late to the party - sorry.
I have one of the chucks pictured, but the quality is not where it needs to be - bits are off-centered.
That being the case, I use the carbide bits in a mill or drill press whenever possible.  Use a high speed and don't drill in too far each stroke to prevent breaking the bits.
Good luck!
« Reply #13 on: October 14, 2023, 02:31:58 AM »
This came in the mail today. It goes on my Proxxon Micromit 12/E.
It is mounted with a regular chuck still in the shaft. The new chuck has a spring system that closes the claws of the chuck as it is screwed on:
My 0.3mm drill bit fits snug between the claws. In this picture the drill is spinning. It is perfectly centered and doesn’t wobble:
Here is a setup ready to go:
I managed to drill a 3 mm hole in this brass plate. Gently easing down in several strokes, every time a little further.
I was expecting (as Steve did) that the drill would break instantly but to my surprise it didn’t.
This went much better that I anticipated and I am very pleased with the result:
The only issue I have with Proxxon tools is that the pins of the connector tend to stay in the power supply when pull it out….:
But overall, I’m a happy man!
« Last Edit: March 21, 2024, 09:04:52 PM by Rookie »
