Author Topic: 1/72 Roland DII (Pegasus)  (Read 4197 times)
Offline DaddyO
« on: September 16, 2023, 06:51:20 PM »
Just finished this one which has been on the bench for a wee while now. (I did start the KP kit, but even after much sanding the kits wings and details were a bit 'clunky' for 1/72 especially when compared to the older Pegasus model which I picked up at a recent show)
Re: 1/72 Roland DII (Pegasus)
« Reply #1 on: September 16, 2023, 09:35:21 PM »
Very nice work Paul, love the interior. I like how you cheated so you didn't have to detail the engine........ ;) ;D
Offline DaddyO
« Reply #2 on: September 17, 2023, 04:05:39 AM »
Cheers Nigel
You spotted my cunning ruse eh? ;) Once I'd decided on the scheme I fancied I found a really good picture of one in a line up of mainly Albatros' and that was it  ;D
Offline Rip Van Winkle
« Reply #3 on: September 17, 2023, 01:42:09 PM »
Nicely done.  I have one of the Pegasus kits also.  I completed a KP kit and discovered it had several inaccuracies. The Pegasus kit looks pretty good so I will eventually try it.
Offline ScottJ
« Reply #4 on: September 18, 2023, 05:47:31 AM »
Paul, that looks excellent! I really like the cockpit coaming, you can see where it's slightly pulled tighter at fuselage mounting points.  Also the hint of the tape that covers the seam where the two halves of the fuselage are joined.  Did you run a thin strip of decal there before painting?  Love the detail...
Scott
E.P. Janney?
Offline DaddyO
« Reply #5 on: September 18, 2023, 05:00:46 PM »
Fair bit of work involved with the older kit RVW, but it's mainly sanding and adding details (which I enjoy) Got a few more of the Pegasus models in the stash and will sort out another once I've finished the model I'm working on.
Here are a couple of views of it all based up and ready for the show at Bovington next weekend.  :)
Offline DaddyO
« Reply #6 on: September 18, 2023, 05:10:33 PM »
Scott
Hi Scott.
Thanks for that mate - glad you like it.  ;D
Cockpit combing was a sausage of Duro putty and the front of the fuselage was built up with Magic Sculpt. I'd intended to use a decal strip for the seam  :-[, but completely forgot so ended up masking and adding a couple of coats of paint (probably needed a light sand down afterwards, which I'll do next time)
I noticed that the aileron push rod positions were a wee bit forward of where they are shown on the plan so the holes were filled a drilled nearer the cockpit. Some scraps of brass shim and sanded 5 thou plastic sheet produced the steps and hatches with detail being added to them using paint.
Tail skid is shaped brass strip and the fairing is built up of scrap plastic sprue and putty.
One of my favorite bits isn't easily seen (the spreader bar on the undercarriage) Made three of these before I was happy with the look and scale of it. Made from brass tube and plastic card the bungee cord is stripped electrical wire which adds a fair bit of strength to the joint area.
« Reply #7 on: September 18, 2023, 08:34:47 PM »
Wonderful work on your Roland, Paul -
Really love the draped sheet effects over engine and you have displayed nicely on your base.
« Reply #8 on: September 19, 2023, 01:32:41 AM »
Agree 100% !
Offline DaddyO
« Reply #9 on: September 19, 2023, 04:02:36 AM »
Cheers Dave and Ed (saved having to detail the rather inadequate engine as well as looking a bit different)  ;)
« Reply #10 on: September 19, 2023, 08:12:59 AM »
Beautifully done Roland Paul.  I like the turnbuckles you added. They really seem to be to scale.
« Reply #11 on: September 19, 2023, 11:22:27 PM »
Bravo, another diminutive cracker.  That tarp draped over the engine looks amazing. It must difficult to achieve such realism in 1/72 but you've managed it!
Offline DaddyO
« Reply #12 on: September 19, 2023, 11:39:00 PM »
Thanks Tim appreciate it (Turnbuckles are made with paint)  ;)
Cheers Ritchie glad you like it  ;D
Offline NinetythirdLiberator
« Reply #13 on: September 20, 2023, 12:06:58 PM »
I built the same one and it looked really nice and delicate.  Yours really looks the part.  Well done!
Dan
Offline DaddyO
« Reply #14 on: September 20, 2023, 05:52:53 PM »
Dan
Cheers Dan (Great minds eh?) ;)
