Author Topic: 1/32 Albatros D Spinner for WNW Axial propeller  (Read 5148 times)
  • Moderator
« on: July 09, 2023, 05:27:13 AM »
Yet another retooled item from the old catalog, this is my take on the spinner profile for the Albatros D type spinner. There were likely many variations, but I've never been a fan of WNW's depiction, which to my eyes is based on the TVAL reproductions which in turn seem to have been derived from the [mangled] Canberra specimen. But -- it's a highly subjective thing! Anyway, my spinner is tailored to fit the WNW Axial propeller -- just as the originals were. Note that this will NOT fit Proper Plane's 1/32 Axial prop.
https://www.aircraftinpixels.com/shop/p/132-albatros-dva-spinner-for-axial-prop
Offline Brad Cancian
    • Brad's Models
Re: 1/32 Albatros D Spinner for WNW Axial propeller
« Reply #1 on: July 10, 2023, 07:57:59 PM »
Hi Bo - would you ever consider down-scaling this to 1/48 to fit the Eduard kits, to replace their incorrectly shaped spinners?
Thanks!
BC
  • Moderator
« Reply #2 on: July 10, 2023, 10:13:34 PM »
Thanks!
BC
Yes…
    • Brad's Models
« Reply #3 on: July 11, 2023, 06:23:17 PM »
Fantastic Bo! I'd certainly purchase a few. I likewise have the same question regarding the Albatros fuel tank :)
How might I be able to assist with this one? Can I help by measuring up some of the Eduard kits for you?
Cheers!
BC
  • Moderator
« Reply #4 on: July 11, 2023, 08:44:07 PM »
No, I’ll have to have the kit(s) in my hands for this to work efficiently. Therefore guidance on which one to get would be helpful…
Edit: Eduard 8113 Albatros D.V 1/48 on order...
« Last Edit: July 11, 2023, 10:27:56 PM by uncletony »
    • Brad's Models
« Reply #5 on: July 12, 2023, 07:11:28 AM »
8113 was going to be my recommendation Bo :)
I think the spinner would also be good for the other 1/48 Eduard Albatri as well (the D.II and D.III), as I believe the Eduard parts are the same for all of their kits.
As an aside, both the D.V, and D.II/D.III kits could also benefit from having a fuel tank available, I would think (but now i'm probably just being selfish!) :)
Cheers!
BC
  • Moderator
« Reply #6 on: July 12, 2023, 08:43:39 AM »
I’ll have a look for sure. As I’m sure you understand, it’s not a simple matter of scaling things down— stuff has to be tailored to fit and tolerances adjusted. There are minimal wall thicknesses and wire sizes — things that I am always pushing to the limits even in larger scales. On the other hand, I’ve done the legwork so it’s not like starting from scratch…
    • Brad's Models
« Reply #7 on: September 30, 2023, 05:22:52 PM »
Hi Bo! How did you go with this little project?
BC
  • Moderator
« Reply #8 on: September 30, 2023, 10:06:07 PM »
BC
I opened the box and looked inside!  :-D
It’s still in the queue, but other wheels have been squeakier…
    • Brad's Models
« Reply #9 on: October 01, 2023, 06:49:47 AM »
BC
All good Bo, just curious - definitely understand that 1/48 WW1 isn't always top of the pile for aftermarket goodies! Keep doing your great work!
BC
