Author Topic: 1:32nd scale Hansa-Brandenburg W12  (Read 8647 times)
Online Mike Norris (UK)
Re: 1:32nd scale Hansa-Brandenburg W12
« Reply #15 on: July 25, 2023, 03:29:28 AM »
The fuselage is ready to be closed up.
I've carried out a few enhancements to the cockpit:
Rudder control pulleys drilled and control cables added (0.08 mm diameter mono-filament and blackened 0.4 mm diameter Nickel-Silver tube).
Elevator control levers drilled and control cables added (0.08 mm diameter mono-filament and blackened 0.4 mm diameter Nickel-Silver tube).
Aileron control cables (photo-etch) replaced with 0.08 mm diameter mono-filament and 'Proper Plane' resin turnbuckles.
Observers seat and map shelf side stays added from blackened 0.4 mm diameter Nickel-Silver tube.
Lead wire 0.4 mm diameter added for the fuel tank hand pressurizing pump.
Copper wire 0.125 mm diameter wrapped around the pilot control wheel to represent hand grip.
Nickel-silver 0.4 mm diameter tube used for the throttle quadrant to engine carburetor control rod.
« Reply #16 on: July 25, 2023, 10:08:35 AM »
Magnificent, Mike. There seems to have been quite a bit of room in that back office, although the GIB obviously wasn't able to enjoy the Barcalounger-style seating of the driver.
Dave V.
Offline MR Bentley
    • My Instagram feed
« Reply #17 on: July 25, 2023, 10:58:33 PM »
Looking great!
-Max
« Reply #18 on: July 25, 2023, 11:35:17 PM »
Really nicely done Mike. I never noticed that port hole in the rear cockpit wall.  Must be to allow light in for the folding table?  Thanks for sharing.
Tim
Offline AngryJazz
    • @AngryJazz_Models
« Reply #19 on: July 28, 2023, 12:15:03 AM »
Stunning cockpit and attention to details  :)
//Ben - @AngryJazz_Models
« Reply #20 on: July 28, 2023, 05:51:57 AM »
Looking good Mike!
Online RAGIII
« Reply #21 on: July 30, 2023, 05:07:31 AM »
Excellent interior Mike....as always!
« Reply #22 on: August 01, 2023, 03:25:00 AM »
I've replaced the kit supplied Spandau and Parabellum machine guns with modified 'Gaspatch' weapons.
The fuselage and other parts were primed then airbrushed with 'Tamiya' Grey (XF53).
The wings, ailerons and elevator were primed white and pre-shaded with 'Tamiya' Smoke (X19) prior to decal application (Aviattic),
« Reply #23 on: August 03, 2023, 06:26:51 AM »
The fuselage was mottled with two slightly different shades of grey to give a weathered look to the wood surface.
The kit lozenge decals were replaced with 'Aviattic' decals as being more representative of the Lozenge colours.
The undersides have 'Aviattic' CDL decals applied.
The darker lozenge was decal over a grey base coat, to represent the darker linen effect over wood surfaces and upper wing auxiliary fuel tank.
The lighter linen shade was over white base coat.
The direction of the lozenge on the ailerons and elevator are different to the rest of the aircraft lozenge, as on the actual aircraft.
Still more detail painting and subsequent weathering to be done before assembly,
« Last Edit: August 03, 2023, 07:19:40 PM by Mike Norris »
« Reply #24 on: August 05, 2023, 04:41:11 AM »
The basic fuselage and lower wings assembled.
The two 'Spandau' machine guns and associated kit parts were replaced with slightly modified 'Gaspatch' weapons.
Still a lot of detail and weathering to do before full construction can start,
« Reply #25 on: August 05, 2023, 08:35:00 AM »
Now on its floats,
« Reply #26 on: August 05, 2023, 11:58:42 AM »
nice.
« Reply #27 on: August 06, 2023, 07:11:41 AM »
Very fine work on your W12. A pleasure to behold.
Offline AngryJazz
    • @AngryJazz_Models
« Reply #28 on: August 07, 2023, 07:27:29 PM »
Wow! Going together beautifully  :)
« Reply #29 on: August 07, 2023, 10:08:28 PM »
Great work, as usual, Mike.
One question, how do you achieve the weathered look on the machine guns?  Use a sponge with silver paint to dab the silver color on?
