Author Topic: 1:32nd scale Halberstadt Cl.II  (Read 11586 times)
Re: 1:32nd scale Halberstadt Cl.II
« Reply #15 on: February 06, 2023, 10:22:29 PM »
Wonderful progress Mike.  Would you happen to have taken any interior pictures to share with us?
Hi Tim,
Afraid not, just those in this thread.
I didn't bother as there's no modifications carried out internally - basically OOB.
The only mods were to the weapons by using 'Master' barrels and cooling jackets, as opposed to the kit supplied photo-etch,
« Reply #16 on: February 07, 2023, 11:36:24 PM »
The fuselage is ready for applying the 'Aviattic' stipple five colour lozenge effect decals (ATT32209).
I also needed to create the 'Devils Cat' and 'ANNI' decals.
These were copied from the colour profile into Paint Shop Pro 2019 software on my PC.
The edges of each were cleaned and they were then test printed on paper and resized as necessary to match the model size.
The markings were printed on my Canon IP7250 inkjet printer and on ‘MDP’ (Mr Decal Paper) Clear water slide decal paper.
I printed extras as the clear decal paper is translucent and may show the underlying decal.
If so I can double the decals to increase the colour density.
The printed decals were given two light sealing coats of ‘Krylon’ Acryli-Quik sealer to seal in the ink and prevent bleeding of the colours when the decals are applied.
« Reply #17 on: February 08, 2023, 01:03:52 AM »
Interesting process. Looking forward to the application.
« Reply #18 on: February 09, 2023, 03:33:11 AM »
I now have a photograph of the right side of this particular aircraft.
It indicates that the black 'Devil Cat' was applied only on the fuselage left side.
The right side had a Imp figure and a devil face.
The quality of the photograph is not good so I've created decals as close as I can.
The Imp was traced from the photograph and the devil face was the closest I could find (online clip art).
« Reply #19 on: February 09, 2023, 06:49:21 AM »
The fuselage decals have now been applied.
Just a few small tweaks then it's on to the weathering,
« Reply #20 on: February 09, 2023, 07:10:15 AM »
Great results! I assume the camo on the fuse is also decalled?
Offline hrcoleman66
« Reply #21 on: February 09, 2023, 07:11:00 AM »
Wow!  That's a colorful beast.
Looking good.
Hugh
Offline rhwinter
« Reply #22 on: February 09, 2023, 07:46:18 AM »
Mike, that's looking good! Happy I could have been of help!
« Reply #23 on: February 09, 2023, 10:36:11 AM »
The fuselage is all decals.
'Aviattic' ATT32209 stippled lozenge with kit supplied and created by me markings,
Offline davec
« Reply #24 on: February 09, 2023, 12:07:32 PM »
Beautiful work! Looks like the Aviatik decals went down really well despite all the compound curves.  How hard were they to apply?  Any advice or lessons to share from your experience with them?  I'm thinking of building the Halberstadt next.
thanks!
« Reply #25 on: February 09, 2023, 06:25:04 PM »
That’s shaping up really beautifuly!
« Reply #26 on: February 09, 2023, 08:15:19 PM »
thanks!
Hi Dave,
The decals are produced to the correct shapes to fit the various model parts.
They are not 'cookie cut' so have to be carefully cut out from the supplied sheets.
Given the shapes and amount of openings and around the edges, cutting accurately is not that easy.
I chose to cut off the fuselage decking panel area (in front of the cockpit) on the fuselage top decal.
This made it easier to apply it separately.
The fuselage decking panel and the two panels around the fuselage nose have compound curves, which make applying those decals tricky.
Despite these being the correct shape, I found that they still created creases at the edges when applied.
I had to slice through those areas with a scalpel blade to get the decals to conform.
I then brushed 'Tamiya' X20A acrylic thinners over the creases, which is more effective than 'MicroSol' solutions or similar.
Brushed sparingly as too much will melt the decal.
There are still faint lines where the cuts were made, but hardly noticeable.
Accurate cutting is important as overlapping edges of decal will show much darker than the rest of the decal.
Any overlap will need to be carefully sliced off.
The decals for the fuselage decking panel (in front of the cockpit) and the two around the fuselage nose did
« Reply #27 on: February 09, 2023, 08:31:21 PM »
What an excellent result Mike.  The Aviattic decals look nice and your printed ones really are fine.  The overall effect will be gorgeous after some weathering and grunge.
« Reply #28 on: February 09, 2023, 08:33:06 PM »
Yes, thanks Richard,
« Reply #29 on: February 10, 2023, 10:22:14 AM »
Very nice work. Looking at the photo of the original aircraft, by any chance does the imp have a wing on his back?
