Author Topic: Turnbuckles  (Read 2055 times)
Offline Mac
Turnbuckles
« on: January 25, 2013, 04:36:23 AM »
Hi guys for the last few evenings I have been making turnbuckles while waiting for my wnw britfish to arrive but I do wonder how many turnbuckles are actually needed to rig a bi plane?  Not that I will stop making them as I'm sure they will get used up!  :)
Regards Pam
Re: Turnbuckles
« Reply #1 on: January 25, 2013, 04:56:57 AM »
It depends entirely on the aircraft. The British did not use many turnbuckles, most of their aircraft were rigged using streamlined flat wire which did not require turnbuckles, they did however use turnbuckles on the control rigging, some aircraft had these turnbuckles hidden inside the fuselage. Most other countries used turnbuckles, there was only one per rigging wire usually near the bottom wing for ease of access. Numbers depended on the size of the aeroplane, if it had one, two or three bays, on an aircraft like the Albatros there were less then 20 turnbuckles, but on the Voisin III there were over 150. It won't matter how many turnbuckles you make, the ones you don't use for one build will come in handy for the next build.
Offline Mac
Re: Turnbuckles
« Reply #2 on: January 25, 2013, 05:59:44 AM »
Thanks for the quick and informative reply Des. Much appreciated.
regards Pam
Regards Pam
