Author Topic: plastic + metal which glue?  (Read 2024 times)
Offline MG
« on: October 30, 2022, 09:11:12 PM »
Good morning,
I am building an Italian Nieuport 11, being the first ever it is more correct to say that I am trying, having to build a piece that obviously is not in the kit, the particular Italian support for the Lewis on the wing, I need to glue plastic with metal specifically I think it is aluminum, they are mixed-case parts.
I have two types of glue available, AK EXTRA THIN CEMENT orange cap and AK MAGNET cyanoacrylate, nothing to do they don't stick, what can I use? :'(
Thank you
Re: plastic + metal which glue?
« Reply #1 on: October 30, 2022, 11:00:27 PM »
I don't know AK glues, but the CA should do the job. Some CAs set fast, others slowly but you only need a small amount - a large pool will take forever to dry and cure. You can get accelerators (in a bottle or a spray can) to speed up setting to instant.
I'd try a very small spot of the CA, of course if it is old it may not set at all. (Keep CA in the fridge to extend its life.)
HTH
Offline MG
« Reply #2 on: October 30, 2022, 11:07:37 PM »
Thanks for the prompt reply.
The cyanoacrylate glue is about one year old, however, always kept in a cool and dry place.
Do you think it does not work because it has expired?
Offline MG
« Reply #3 on: October 30, 2022, 11:09:23 PM »
Which cyanoacrylate glue do you recommend?
Offline MG
« Reply #4 on: October 30, 2022, 11:19:55 PM »
I tried gluing some 0.12 fishing line for rigging and the glue works.
« Last Edit: October 31, 2022, 07:42:01 PM by MG »
« Reply #5 on: October 30, 2022, 11:29:24 PM »
Hi MG, at one year it should still work fine. Have you tried cementing a couple of pieces of scrap plastic with it - if that doesn't work, then the CA is past use.
I use a whole variety of CA glues, picked up at model shows, can't think what's on the workbench at the moment. (not at home just now), but for a simple plastic to metal joint, the cheap stuff from a Nickel and Dime store should be perfectly good enough.
S
Offline MG
« Reply #6 on: October 30, 2022, 11:58:57 PM »
THANK YOU!!!  ;D
« Last Edit: October 31, 2022, 07:41:02 PM by MG »
« Reply #7 on: October 31, 2022, 09:44:58 AM »
Folks, a polite reminder that all forum posts must be in English or have an English translation provided.
Offline MG
« Reply #8 on: October 31, 2022, 07:37:56 PM »
Yes, you are right, I must apologize but since everything appears to me translated in a hurry, I was convinced that I used English !!!
