Author Topic: 'Tis Albatrii Season...! Another 1/48 Albatros DVa  (Read 8038 times)
Offline Thumbs up
Re: 'Tis Albatrii Season...! Another 1/48 Albatros DVa
« Reply #15 on: September 08, 2022, 03:24:29 AM »
Maybe in my old age I'm getting slow,but with these 3D printers and cutters,cads,AI Mr Spock on Zoom...Maybe,just hoping that a new cottage vac form type industry will come out of it,I think Brads doing the doing type work. Great stuff!!!
Online Umlaufmotor
« Reply #16 on: September 10, 2022, 09:00:17 PM »
@Brad Cancian
The "innards" on your Albatros look very good.
Really very nice work, I look forward to more updates, Brad  :D
Servus
Bertl
« Reply #17 on: September 10, 2022, 10:40:13 PM »
Proper Albatros scourge here at the Forum! And what lovely work you are showing us!
EDIT Not often one can write the exact same thing in three different threads at once. 😀
« Last Edit: September 10, 2022, 11:46:00 PM by FAf »
« Reply #18 on: September 23, 2022, 05:32:32 AM »
Damn Brad! You are killing Me with Your Skills  :( Seriously this has to be one of the best builds of this kit I have seen by Anyone!! Outstanding and Brilliant fall Short!
Offline Brad Cancian
    • Brad's Models
« Reply #19 on: September 23, 2022, 07:05:16 AM »
Thanks folks, you are too kind!
Progress has ground to a bit of a halt; I am working on a solution for the Mercedes D.IIIa engine, which is tricky as there are no aftermarket engines available.
I also have a new puppy, which is also a time consuming project :)
Thanks again!
Brad
« Reply #20 on: September 24, 2022, 04:20:44 AM »
Hoping you find an expedient and economical solution for the engine. Unfortunately the puppy will be neither!  My lab is already two years old with no sign of slowing down.
    • Brad's Models
« Reply #21 on: October 02, 2022, 09:10:58 AM »
Hi all - some (very) slow progress due to work and the aforementioned puppy....
The engine will be a focus of any model with the cowls off. The lack of a readily available aftermarket Mercedes D.IIIa forced me to adopt an approach that Chad took with his 1/48 build; i.e. looking to utilise a D.IIIa from the old Roden Fokker D.VII kit. One snag; I didn't have an old Roden Fokker D.VII kit and didn't want to go out and buy one just for this. What I did have, however, was a previously built engine from an old (and now long gone) Roden Fokker D.VII that I built circa 2007. I had added some detail at the time but after years of banging around in the spares box, it was in this state:
Some clean up and help would be needed to bring this motor back to life. Like the Eduard kit engine, one of the annoyances (for me) is the moulded in ignition wire tube, running front to back along each cylinder. This is unrealistic and needs to be removed. So, pulling everything apart and starting to trim these pieces off was step 1:
I then needed to strip the paint, and smooth out the cylinders; this was the most time consuming part. After much sanding, checking, and more sanding, I had an engine that was good enough (not great, but good enough) as a basis for the rest of the engine:
Details were then added, including rocker arm springs and rocker arms, distributor cap details, spark plugs, ignition wires, and some other gismology here and there. I didn't add anything at the rear or under the engine bearers as these areas won't be visible on the finished model. The results, though far from perfect, are good enough to stand on its own:
And in its future home:
The close up photos show a few things I still need to address... sigh... but the hard work is done. Next up i'll scratch build the fuel tanks, which sit behind the engine.
Brad C
Offline Luftace
« Reply #22 on: October 03, 2022, 12:04:35 AM »
Brad
That resurrected engine is looking great! It even looked really good still before you started fixing it up. Can't wait to see it with some paint on it.
Chad
Offline Radarman
« Reply #23 on: October 03, 2022, 01:30:28 AM »
Simply fantastic detail, Brad.
I learn a lot from every build you share with us.
                                                   Kevin
« Reply #24 on: October 03, 2022, 11:45:45 PM »
Nice salvage job on the old motor!!
    • Brad's Models
« Reply #25 on: October 08, 2022, 06:13:41 PM »
Thanks Chad, Kevin and Steve!
Work slowly continues. This afternoon I built the fuel tanks from laminates of plastic sheet, cut and sanded to shape. Details were from plastic, wire and solder:
In its future home:
I also scratch built an oil tank. Here's the whole set up sitting in place. I think the engine bay should now look adequately 'busy' once it's all painted up. I'll add more detail once the main engine bay painting is done.
Next, with the key elements of the engine bay constructed, i'll probably shift my attention back to the cockpit.
Cheers!
BC
« Reply #26 on: October 08, 2022, 10:44:19 PM »
Wow, everything is falling into place. Looks great!!
« Reply #27 on: October 09, 2022, 03:54:48 AM »
I'd say so! Lovely work Brad, she's looking terrific!
« Reply #28 on: October 09, 2022, 06:08:07 AM »
Wow!  This is incredibly detailed!  I’ll stick with 1/72 so I can hide my lack of detail better!
Offline Luftace
« Reply #29 on: October 12, 2022, 08:00:55 AM »
Excellent work Brad! Your structural parts look really great and seem to fit very well. As always, I await your next update to see how she progresses and what neat things you've added.
Chad
