Author Topic: WNW Albatros D.V/Albatros D.Va Triple - and one more Jasta14 Albatros D.II  (Read 69413 times)
Bertl, your attention to detail makes me smile - it's very inspirational. Thanks for the description of the process. Absolutely astonishing detail. When I cut corners...I hope you don't see them  ::)
I agree with Gary. Inspirational attention to detail. Each update is a joy!
It's all I got ! Love it !
Offline Umlaufmotor
Thank you very much, Zac, Alexis and Gary.
@gedmundson
I will try not to see any cut corners, Gary  ;)
Servus
Bertl
Offline Umlaufmotor
Here is the rear view mirror on the Albatros D.V.
Vfw Bansmer had a rear view mirror mounted on the front right of the cockpit.
Of course I would like to show this on the model as well.
I used the Wingnut Wings kit part #E39 which was sanded slightly smaller with sandpaper.
I used a 0.4mm brass rod to extend the holding rod.
The mirror insert was punched out of a piece of chrome foil coating of a AAA battery and glued in with Still Water from Vallejo.
Still Water was also used to represent the glass.
The mirror itself was painted dark green on the front and gray-green on the back with RLM02.
Small flakes of paint were painted on the back of the mirror, which points in the direction of flight, with dark gray paint - this was dabbed on with a small sponge.
The mirror is only attached to the model in the pictures, a 0.5mm hole was drilled at the edge of the cockpit for this purpose - the mirror is not yet attached to the model, this will only be done shortly before completion.
Servus
Bertl
More superb attention to detail as always. This is a pleasure to watch.
Offline xan
Lovely detail!
Offline Umlaufmotor
Many thanks, Bob, Nigel and Xan!!
Servus
Bertl
Offline Umlaufmotor
The main work is almost all done, so slowly but surely the building curve for this Albatros D.V is coming to an end.
The D.III Mercedes engine is currently under construction.
A few small details are still missing on the Albatros' belly.
A few current pictures from the "Albatros Werkstatt".
The landing gear and the windshield are only loosely attached in the pictures - both will be glued at a later stage of construction.
Servus
Bertl
Glorious rendition. Love the rear view mirror!
That is looking fabulous. Not much more I can say really..... ;)
Beautiful...
Offline Umlaufmotor
Thank you very much, Sandy, Nigel and PrzemoL.
Servus
Bertl
Offline Umlaufmotor
Only minor work is currently being carried out on the Albatros D.V
The cartridges for the flare gun are now almost finished.
Originally, these were pressed cardboard cases.
Later, when it was noticed that the cardboard swelled up when damp and could hardly be inserted into or removed from the barrel of the flare gun, the cases were also made of brass.
Well, I made them from thin, 0.8mm aluminum tubing.
In the original caliber 4 - that was 26.5mm - that's pretty much exactly 0.8mm in 1/32 scale.
So the diameter fits.
I painted the aluminum tubes with Tamiya "Nato brown" and applied the different color markings of the respective cartridge filling - this is the current status, but the cartridges are not yet completely finished.
The cartridges can even be inserted into the flare gun ..... .
Servus
Bertl
