Author Topic: 1/72 Roden Felixstowe F.2a  (Read 25383 times)
Re: 1/72 Roden Felixstowe F.2a
« Reply #60 on: June 06, 2022, 04:29:14 AM »
Lovely work! I am looking forward to the wings !
« Reply #61 on: June 06, 2022, 06:59:44 AM »
Beautiful!
WD
« Reply #62 on: June 06, 2022, 03:36:43 PM »
Spectacular.
« Reply #63 on: June 06, 2022, 04:40:37 PM »
Wonderful!!!
Offline pustota
« Reply #64 on: June 07, 2022, 02:48:11 AM »
Thank you, frends.
« Reply #65 on: June 08, 2022, 04:54:23 AM »
The wood finish on the hull is marvellous!
Offline pustota
« Reply #66 on: June 19, 2022, 01:26:46 AM »
Good day. For the last two weeks I have been working on wings.
Here's what happened:
Offline pustota
« Reply #67 on: June 19, 2022, 01:31:18 AM »
Gargrot made half open so that the hold could be seen.
« Reply #68 on: June 19, 2022, 04:33:31 AM »
The Volume of Masking you have done has paid off in a beautiful paint finish on your Model! Everything looks gorgeous! Cutting out the upper section and making framework to enable all to see your interior work is a Brilliant Idea!
« Reply #69 on: June 19, 2022, 08:28:35 AM »
Weeks worth of work have certainly paid off for you, beautiful work!
WD
Offline pustota
« Reply #70 on: June 19, 2022, 02:50:01 PM »
Thank you.
I bow to my colleagues who built / will build this aircraft in 1/32 scale.
« Reply #71 on: June 19, 2022, 08:40:29 PM »
There is some fantastic work going on here, and the wood and fabric tones are brilliant! I would think this subject is even more difficult to make this beautifully in such a small scale... Well done and real inspiration. ATB, Marc.
Offline malaula
« Reply #72 on: June 19, 2022, 09:47:45 PM »
Outstanding finish on the wings,Pustota!I especially like the chipped paint on the overhead tank ..did you use the Roden decals ?
Offline pustota
« Reply #73 on: June 19, 2022, 11:08:36 PM »
Thank you.
Yes it's Roden's decals, and I had lucky with them.
I used a decal medium and decal fix from Vallejo.
So far so good...
Offline malaula
« Reply #74 on: June 20, 2022, 12:03:42 AM »
I never had issues with the late Roden decals...the glossy type seems to work quite good.
The Felixstowe in my oppinion is one of the best Roden kits.
Most important when fixing the wings is to take care of the slight dyhedral of the outer panels of the upperwing to prevent sagging...
the engine support struts are a bit tricky,too.
