Author Topic: WNW DH2  (Read 13076 times)
Offline gcn
WNW DH2
« on: January 10, 2013, 05:35:14 AM »
After finally completing the Bristol I’ve decided to stay on the RFC theme and have some fun rigging the DH2.
I thought long and hard about which scheme I wanted to do and finally plumped for Option B
Throwing the manual out of the window the first area I concentrated on was the wings and tail. Previous experience with WNW kits is that the ailerons need something a little bit more substantial than the standard kit lugs so I drilled some 0.8mm holes and inserted some 0.8mm fuse wire, this creates a much stronger joint, is relatively quick to do, and you can move them around to your hearts content without the fear of the sodding things snapping off.
The painting process for the lower sides was then undertaken once the wings were cleaned up, this involves:
·         Priming with Alclad primer
·         Base coat of 40|60 mix of Tamiya deck tan and White
·         Mask ribs and joints
·         Thin pre-shade of Tamiya Dark grey and smoke to create shadows
·         Tone down shadows with Citadel Bleached Bone thinned with Tamiya thinner
·         Remove mask
·         Further toning down with bleached bone to get desired effect
·         Blend with brown filter using W&N Oils
The wings are now ready for the gloss coat and decals.
Back to the manual. First thing is to be careful when removing some of the more delicate parts from the sprue.
The great thing about WNWs kits is that a lot of the parts are engineered such that you don’t need to fully remove the sprue prior to painting. I followed the kit painting instructions using Tamiya paints.
The seat after priming had a base coat of XF-60 mixed with their clear to gloss it up a bit and then a wash of burnt umber was added. The cushion was a mix of light brown, dark brown and red with a thin mix of black and brown adding shadows. I then with the aid of a toothpick added a desert yellow colour to buttons. To blend it all together a wash of Mig rust was added.
The belts were painted on the sprue flat. Again a convoluted process but I like the effect.
·         Citadel Bleached bone to create a slightly warmer tone
·         Mask and apply Vallejo rust thinned with their own thinner
·         Liberal wash applied to accentuate shadows and grime
·         Couple of coats of future
·         Apply thinned Brown & smoke mix to the edges of the belt
·         Couple of coats of future.
The future is used because it enables me to form the belts to shape after painting without the paint flaking off. I just need to flatten the gloss to finish.
The Nacelle was painted using Deck Tan and bleached bone as before and I added the shadows of the frame using the frame as a mask.
The cockpit frame has lugs in most places that can accept a 0.3mm drill bit for the internal rigging. Some lugs were deformed and some not present at all. Where they weren’t present I drilled a 0.3mm hole and inserted dome 0.2mm fuse wire as shown. I would have like to have seen the lugs a touch bigger to make the job a little easier.
I can then thread a 0.5mm brass sleeve containing a length of thin EZ line over this wire and trim to suit. The bits and pieces were picked out and lowlights added via an oil pin wash.
The IP was painted and then future added to the faces in preparation of the decals. This had the added advantage of darkening the bezels that remained grey to create a contrast. Previously the IP decals on my WNW kits needed trimming otherwise they wouldn’t fit, this time they fitted perfectly on a base of wet future and patted down gently with a cotton bud. That clock that I’ve put upside down I couldn’t even read the detail on it with a mk1 eyeball.
The only bit of bare wood in the cockpit got the normal treatment of base, oils, gloss, smoke and the floor was built up using 3 shades of grey. I’ve only rigged the foot pedals as the rest of the internal rigging cannot be seen. I tried colour modulation on some parts just to waste a bit more time, I’m not sure how worthwhile its been but it looks ok to the naked eye.
Its now on to closing up the fuselage and the engine.
Re: WNW DH2
« Reply #1 on: January 10, 2013, 06:26:16 AM »
Wow that looks amazing. Nice jump out of the gate!! ( For those that want Citadel Bleached Bone it is now called Ushbati Bone)
« Last Edit: January 10, 2013, 06:34:30 AM by pepperman42 »
Re: WNW DH2
« Reply #2 on: January 10, 2013, 06:31:13 AM »
Looking absolutely brilliant, and talk about quick, you are motoring along at a fantastic pace. Everything so far is extremely well done (apart from the upside down clock  :D), I'm looking forward to seeing more progress on this beauty.
Re: WNW DH2
« Reply #3 on: January 10, 2013, 07:01:01 AM »
GCN,
   Very impressive start, your cockpit is terrific and the panel very impressive. Don't worry about the clock, I'm sure there were some Aussies flying these little beasts so the clock is the "down under" version, at least that would be my story! ;)
   Looking forward to more updates.
Re: WNW DH2
« Reply #4 on: January 10, 2013, 07:27:50 AM »
Indeed, an impressive start. Fine shading and wash emphasizing the surface detail.
I will be watching it carefully because accidentally I have selected the same colour scheme for my DH2 I am going to begin later this year.
Re: WNW DH2
« Reply #5 on: January 10, 2013, 07:43:55 AM »
Fantastic Gcn, I will look closely to your WIP in order to get some idea for mine!
Great start indeed
Antonio
Offline Epeeman
Re: WNW DH2
« Reply #6 on: January 10, 2013, 08:58:33 AM »
Brilliant work and very fast progress, mate!
Re: WNW DH2
« Reply #7 on: January 10, 2013, 09:22:28 AM »
   Gary,
Now that's absolutely outstanding progress my friend. She's well on her way to being a real show stopper. Can't wait for more.
Re: WNW DH2
« Reply #8 on: January 10, 2013, 03:29:03 PM »
You're off to a fantastic start, Gary.  One of my favorite subjects, too.
Offline kornbeef
Re: WNW DH2
« Reply #9 on: January 10, 2013, 05:37:45 PM »
That interior is just gorgeous.
Keith
Offline gcn
Re: WNW DH2
« Reply #10 on: January 10, 2013, 06:51:55 PM »
Thanks folks your comments are appreciated.
I have to say I feel slightly short changed by WNW. It say 1/32 scale on the box but this thing is only 1/72, I can't believe how small it is.  :D
Offline Whiteknuckles
Re: WNW DH2
« Reply #11 on: January 15, 2013, 05:07:14 PM »
Lovely work Gary, great progress!!
Eternal Apprentice
Re: WNW DH2
« Reply #12 on: January 16, 2013, 01:47:15 AM »
Hello Gary:
Great start to this kit.  I appreciate your materials list and how you did it.  I will try that on the belts the next time out and your build up grays for the floor.  Like you say, it may not be seen once closed up, but it looks nice out of the fuselage and you know you did it.  I am looking forward to more as you progress.  Great idea using the frame for the internal preshading.  I too am pinning all the control surfaces, I got tired of re-attaching.
Re: WNW DH2
« Reply #13 on: January 16, 2013, 02:29:47 AM »
Just superb work gcn. You are really working the light. Thanks for sharing your secrets.
Offline gcn
Re: WNW DH2
« Reply #14 on: January 30, 2013, 11:55:40 PM »
Just to prove it’s still in progress I present a crappy iPhone photo. My camera is out of charge and I stole the fuse for the wife’s hairdryer when that went whislt I was putting the wing decals on and I've lost the replacement fuses.
I've no idea how this photo looks as work block photo links so all I get is a red x. I had to edit it on the phone but anyway here it is
I will try and get some better photos by the weekend.
Nacelle and wings are fully painted  in fact everything bar the machine gun has now been completed. I've installed all the wing buckles for the rigging and I might regret it but I’ve decided to use knit in elastic rather than EZ line as I think it will look better, but it is thicker and trickier to loop through a brass sleeve twice although not impossible ( I’ve done two so far).
The nacelle went through several paint stages:
Prime
Base colour (Tamiya) from which I created a light and dark shade
Highlights on areas where the light would catch
Lowlights where it wouldn't
A thin oil wash (black with a hint of brown) to accentuate the lowlights
The upper wings call out for a PC8. WNW lists a FS number of which Tamiya XF-60 is the same all but the first digit which IIRC represents the level of sheen.
I used XF-60 as the base
Then masked the ribs
shaded the ribs with a thin brown black
over sprayed with the PC8 mix according to WNW
Removed the tape
more coverage of PC8 to blend
Oil wash of raw sienna to further blend
To further accentuate shadows the outer edges of the wing were sprayed with a thin black brown mix and the insides were given a light spray of Buff to lighten. In the flesh I think I went just a touch OTT on the buff.
Decals were sealed and weathered to blend in. Careful masking and lowlighting the shadows on the ribs followed by an overspray of buff to dull.
There was no lifting of the decals but it is always touch and go.
The seam where the cockpit combing ends was a nuisance to remove although the outside is covered by the ammo boxes the internal seam is visible, photo evidence that I could muster was inconclusive whether there should be one or not, my opinion is it looks better without. I think this part should have been a single piece rather than part of the nacelle halves and a further piece.
The build has been very enjoyable to date with no real gotchas in the construction. I have my rigging plan so I'm hoping I can get this finished before February ends.
Like I said proper photos to follow in due course
« Last Edit: January 31, 2013, 12:20:34 AM by gcn »
