Author Topic: 3D printed Palmer Tires  (Read 4638 times)
Re: 3D printed Palmer Tires
« Reply #15 on: May 02, 2022, 01:30:19 AM »
I made just also a try in Inkscape
I drawed the text (I have no idea which font to use, I used a bold one), made the letters 3mm high.
I draw a circle (the red line of 55mm).
The I selected both, and called from menu Text->Put on Path
That is the result:
If you send me some parameters like font, diameter ... I can send yo a SVG (Scaleable Vector Graphic) file :)
« Reply #16 on: May 02, 2022, 02:30:51 AM »
Hi Frank,
That’s mighty kind of you!
These are the parameters:
Font: Segoe UI (standard in Windows 10)
Font size: 3mm
Outer diameter of the wheel: 47mm
Tire diameter: 10 mm
The letters are positioned in the middle of tire wall.
The 'x' between the tire size numbers is 'floating' in the center-line of the font height.
I think a found a British firm that may provide the service:
https://modelshop.co.uk/
I’m still looking for a company in the Netherlands that can provide the same service, to save on customs fees.
Thanks again Frank!
« Reply #17 on: May 02, 2022, 04:29:23 PM »
This is now done as vector graphics.
The E is different, may be I should have edit the font before.
Now I'm curious to see how it looks on the wheels in the end.
« Reply #18 on: May 06, 2022, 04:07:25 AM »
Have you seen these.
https://www.ebay.co.uk/itm/373386830964 although they may not be big enough for v1500.
Having said that, I'm pretty sure the raised lettering would not be noticeably raised even in 1:32. If it's raised about 3mm  that would only be 0.09mm in 1:32. Decals would be far better than nothing.
« Last Edit: May 06, 2022, 04:13:12 AM by IanB »
