Author Topic: 1:32nd scale RAF BE2c  (Read 36644 times)
Re: 1:32nd scale RAF BE2c
« Reply #135 on: June 25, 2022, 04:51:43 AM »
The kit supplied landing gear comprises two ‘V’ struts and the axle/fairing.
The axle is intended to be glued to the bottom of the two ‘V’ struts.
However, there is nothing to retain the axle at the bottom of the struts, except the CA adhesive under the axle and onto the bottom of the struts.
The weight of the model bearing down on the axle and wheels with only the CA adhesive taking the weight is a joint failure waiting to happen.
Therefore this needs to be addressed.
Also the ’bungee’ suspension cords are retained between two discs on the ends of the axle, which are not represented in the kit.
Finally the internal strengthening rod within the axle protrudes from either end for mounting the wheels.
However, the protrusions do not go far enough into the wheels, which is another weak point.
Onward, upward,
Online KiwiZac
« Reply #136 on: June 25, 2022, 09:46:44 AM »
Stunning rigging Mike, truly stunning! Reminds me why the single-bay BE.2f is my favourite  ;)
I'm keen to see how you tackle the landing gear bungees.
« Reply #137 on: June 26, 2022, 01:46:20 AM »
Landing gear and tail skid now done.
I managed to twist and pull the axle metal rod from the axle fairing.
This was replaced with a brass rod, which was longer to fit deeper into the wheels.
The axle retainer discs for the bungee suspension cords were cut from 0.2 mm thick plastic card with a central hole to fit onto the axle rod.
The axle assembly was held into the 'V' struts with CA adhesive, backed up with 0.2 mm diameter annealed copper wire.
The bungee cord, represented by 'EZ' line White (heavy), was then wrapped across and around the axle ends, between the retainer discs.
The model now needs to be held by the fuselage.
Therefore, before adding the elevator and rudder controls and wires, I'll need to fit the remaining parts to the forward fuselage.
Online KiwiZac
« Reply #138 on: June 26, 2022, 07:15:44 AM »
Lovely work Mike.
« Reply #139 on: June 26, 2022, 11:42:52 PM »
Nice work!!
« Reply #140 on: June 26, 2022, 11:45:26 PM »
Great work Mike!
WD
« Reply #141 on: June 27, 2022, 05:57:17 AM »
A few more updates.
Bombs and bomb control quadrant and cables added.
Hand operated fuel pressure pump added.
Engine exhausts with retaining frames added.
Windscreens added.
Upper wing straps added.
Ammunition drum rack added.
Pilot and observers machine guns added.
The tail planes and elevators added.
The fin and rudder added.
Kit supplied 3D printed wing skids replaced with 0.6 mm diameter blackened Brass tube.
The kit supplied CFS Mk.4 bomb sight has been binned.
It was so frail it literally fell off in bits!!
I'll need to make a representation of one instead.
Also the propeller will be fitted (last).
Finally the rudder and elevator controls and cables are still to be added.
« Reply #142 on: June 27, 2022, 06:31:16 AM »
That's really coming together in the home stretch!
« Reply #143 on: June 28, 2022, 03:21:48 AM »
 ;D , awesome stuff Mike !
« Reply #144 on: June 28, 2022, 05:17:46 AM »
Really an amazing piece of modelling. Great eye for the detail!
« Reply #145 on: June 28, 2022, 04:30:01 PM »
Bomb sight recovered from kit part with extras added from 0.3 mm diameter tube and 0.2 mm thick plastic sheet.
Also the pitot tube added from 0.3 mm diameter tube (blackened).
Just the elevator and rudder controls to add then it's onto the figures,
« Reply #146 on: June 28, 2022, 10:48:21 PM »
Elevator control cables rigged.
Now onto the rudder,
« Reply #147 on: June 29, 2022, 03:56:38 AM »
Nice work!
« Reply #148 on: June 29, 2022, 08:29:25 AM »
Just beautiful Mike!
WD
« Reply #149 on: June 29, 2022, 08:37:11 AM »
The tail plane bracing wires added.
Rudder control cables added.
Propeller fitted.
That's it for the aircraft.
Now onto the figures,
