Author Topic: WNW Roland  (Read 19378 times)
Re: WNW Roland
« Reply #30 on: January 21, 2013, 12:25:33 PM »
Good work getting that all packed in there!!
Offline Ian from Doncaster
Re: WNW Roland
« Reply #31 on: January 21, 2013, 05:54:26 PM »
Ian,
Nice work! I have a question, The rear panel with the lozgene, how did create the ripple effect?
TIA
Steve :)
Hi Steve, the ripples are molded in already.  I did think about dulling down this lozenge, but it is hardly seen on the finished model.
Offline Pete Nottingham
Re: WNW Roland
« Reply #32 on: January 21, 2013, 09:38:08 PM »
Great work so far Ian, just waiting for my Roland kit to arrive from NZ.
Pete.
Re: WNW Roland
« Reply #33 on: January 25, 2013, 10:04:15 AM »
Thanks Pete, I see you got the Taurus extras for the engine.  I've got their spark plugs on the way (also bought sets for the DVII, Albie and Pfalz DXII at the same time) so can't button everything up yet until the engine is done.
Meanwhile, I progressed a little more on the prop and attached the spinner.  The front cowling has been prepared also, and the front end is sat here for a pic.  The wheels need the tyres painting, and the fabric was painted in the semi-gloss black as called for, but dulled down with an anthracite dry brushed over.  I will do the same for the fuselage before applying the edelweiss decals.  I think the contrast between the dulled down paint and the "metal" spinner etc would work well.
Re: WNW Roland
« Reply #34 on: January 25, 2013, 10:56:29 PM »
Very nice propeller! And fine modelling all around. Looking forward to see more.
Re: WNW Roland
« Reply #35 on: February 03, 2013, 09:17:30 AM »
I prepared some more components whilst waiting for the sparks to arrive.  This included the exhaust, guns, undercarriage, rudder, wing struts etc as well as priming the wings in black prior to lozenge decals.  Once the plugs arrived I finished the engine, touched up the paint and assembled the interior frame to the fuselage halves.  These fitted together OK with a little persuasion and self-clamped with the lower wing.  A little filler was required, which is not quite as tidy as I would have liked but ok I guess.
Painted the fuselage having first masked the tail section and protecting the aircraft with a plastic bag.  Placed the edelweiss decals and sat the fuselage on its legs just for the pics.  Biggest job left now is the lozenge.
Re: WNW Roland
« Reply #36 on: February 03, 2013, 09:30:07 AM »
Looking great Ian, good to see that everything fitted in the fuselage, I love the decals on the fuselage, very eyecatching. You did an absolutely brilliant job on the propeller and the engine looks terrific as well.
Offline Epeeman
Re: WNW Roland
« Reply #37 on: February 03, 2013, 09:36:30 AM »
Excellent progress and looks first class, Ian - look forward to seeing more.
Re: WNW Roland
« Reply #38 on: February 03, 2013, 11:26:59 AM »
This one is really moving right along, Ian!  Excellent work all around.
Re: WNW Roland
« Reply #39 on: February 03, 2013, 01:32:38 PM »
Very nice work. Your exhaust looks excellent!!!
Re: WNW Roland
« Reply #40 on: February 03, 2013, 03:25:31 PM »
Looking good so far.  Black is a difficult color to do and weather nicely.  It looks like you have done both to the group build.
Offline michael
Re: WNW Roland
« Reply #41 on: February 03, 2013, 07:05:16 PM »
great stuff this will be a great show piece when completed!
i especially like the work on the prop and exhaust.
michael
Re: WNW Roland
« Reply #42 on: February 05, 2013, 05:45:31 AM »
Hello Ian:
I have to echo the comments so far, very nicely done and the weathering on the fuselage really sets off it off.
I am trying to figure what you used for the seat belts.  Were they the HGW fabric variety or did you use the kit PE?  Very nicely done whatever they were.
If they were the HGW Fabric, what are your thoughts on them?
Re: WNW Roland
« Reply #43 on: February 05, 2013, 08:35:17 AM »
Thanks everyone, although I must admit the camera is hiding some of my deficiencies!  This has only been on the go for about 4 weeks so I guess I am rushing slightly - no extras nor proper weathering.
The fuselage is primed in matt black, then covered in satin black.  Then a thin wash of anthracite over the top before buffing with a q-tip to blend the variations in the blacks.  The fuselage is hand brushed.  The effect is reduced somewhat now I have applied a gloss coat (no pics yet) to seal the decals, but I will brush on some humbrol mattcote to dull it down again, once the wing lozenge is done.  I used Humbrol's new "Clear" as the gloss coat but I prefer Klear, the Humbrol variant is too thick.
The exhaust is done the in the same method as my previous builds.  I use humbrol gunmetal from the spray tin, which leaves a dull-ish colour that is pitted and grainy.  However, that provides a great key for drybrushing on some rust colours in pastel powders, then sealed with a quick spray of matt varnish.
The seat belts are the kit PE.  I am yet to master the techniques of painting these items, and I may buy an AM set for future builds where I take more time, do more detailing etc.
The prop looks ok from the front, but the colouring in the laminations is less effective at the back.
Just need to do the lozenge and rib tapes etc, then assemble and rig.
Here are some pics of the wing lozenge and rib tapes going on...
« Last Edit: February 05, 2013, 09:40:47 AM by Ian from Doncaster »
Re: WNW Roland
« Reply #44 on: February 05, 2013, 10:50:04 PM »
Looking very good now Ian, I'm still waiting for my kit to arrive.
Pete.
