Author Topic: Nieuport 17 Triplane, Eduard 1/48, 27.5.2022 Aileron control  (Read 11703 times)
Re: Nieuport 17 Triplane, Eduard 1/48, 19.3.2022 Rudder
« Reply #45 on: March 22, 2022, 02:31:04 AM »
Thumbs up Frank !
Nieuport 17 Triplane, Eduard 1/48, 18.5.2022 Biplane
« Reply #46 on: May 19, 2022, 05:08:21 AM »
« Last Edit: May 31, 2022, 01:49:22 AM by Bughunter »
Re: Nieuport 17 Triplane, Eduard 1/48, 18.5.2022 Biplane
« Reply #47 on: May 19, 2022, 05:53:12 AM »
Beautiful work Frank.
WD
« Reply #48 on: May 19, 2022, 06:30:27 AM »
WD
Took the words right out of my mouth.
« Reply #49 on: May 19, 2022, 06:35:28 AM »
Another of your truly magnificent models on the way again Frank.
« Reply #50 on: May 19, 2022, 07:20:17 PM »
Spectacular progress!
« Reply #51 on: May 19, 2022, 11:17:38 PM »
Tidy work.  I have also noted the panel fasteners on the oval panel.  8)
« Reply #52 on: May 20, 2022, 10:36:40 PM »
Outstanding as always Frank!
Nieuport 17 Triplane, Eduard 1/48, 20.5.2022 Triplane
« Reply #53 on: May 21, 2022, 04:58:11 AM »
« Last Edit: May 31, 2022, 01:49:30 AM by Bughunter »
Online DaddyO
Re: Nieuport 17 Triplane, Eduard 1/48, 20.5.2022 Triplane
« Reply #54 on: May 21, 2022, 06:16:25 AM »
I've got a roll of self adhesive aluminium 'heat retardant' tape Frank. (It's a big roll and you're more than welcome to some  if it helps) I've used it for hinge details on 1/72 and was just playing with using some on a 72nd Nieuport. Although it looks a bit shiny as it comes it can be toned down by sanding with very fine wet or dry paper. Thickness is about the same as Sellotape.
« Reply #55 on: May 21, 2022, 07:41:06 AM »
This build is very striking, I'm rather enjoying it despite my total ignorance of the type!
« Reply #56 on: May 21, 2022, 07:55:30 AM »
Exceptional work on what has to rank as one of the Oddest of the French Designs  ::)
« Reply #57 on: May 21, 2022, 08:03:06 AM »
Thanks for the suggestion Paul!
I have such big shiny roll. I have tried to use it, but had later a big problem. With weathering the model with thinned oil paints the glue below the foil was washed out has formed nodules :o So I had to replace the stripes.
I was also not sure if alu or linen, but your suggestion is another voting for alu :)
Zac, I must admit a Nieuport biplane is more elegant but I like to setup a collection of triplanes. The crazy Quadruplane also fits into this series.
Rick, I think the Triplane of the Nieuport 10 (which is also on my list) is more ugly?
« Reply #58 on: May 21, 2022, 05:15:49 PM »
Just found this one, Frank. Wow, you're doing some seriously good work here. I'm thinking the 'plane is looking a bit strange - but, of course! It's because you haven't mounted the tailplane yet. It'll look perfectly normal then!!
« Reply #59 on: May 23, 2022, 02:01:07 PM »
Nice to see you back on this one Frank !
