Author Topic: Nieuport 17 Triplane, Eduard 1/48, 27.5.2022 Aileron control  (Read 11771 times)
« on: February 09, 2022, 04:13:26 AM »
« Last Edit: May 31, 2022, 01:48:21 AM by Bughunter »
Re: Another Nieuport 17, Eduard 1/48, 8.2.2022 Start
« Reply #1 on: February 09, 2022, 04:45:03 AM »
Another utterly Amazing build underway Frank! I for one will follow with great interest.
Offline Radarman
« Reply #2 on: February 09, 2022, 05:16:57 AM »
It's great to see another Nieuport on your workbench, Frank.
You can never have too many French aircraft in your collection.
        Kevin
Offline Big Sky Modeler
« Reply #3 on: February 09, 2022, 05:47:47 AM »
Love the cowling.  How did you get that look if you don't mind my asking?
« Reply #4 on: February 09, 2022, 06:17:10 AM »
I'm excited for this one Frank as I have two Noops - albeit XIs - on my 1/72 and 1/48 To Do lists. Settling in with a good beverage to watch the magic!
« Reply #5 on: February 09, 2022, 07:40:26 AM »
Welcome and thank you Rick, Kevin, Jim and Zac!
It is turned from aluminium on a lathe. The main reason is, that the in-scale Small Stuff engines won't fit under the thick plastic cowling (in scale outside).
The look is a bit raw at the moment, from the lathe chisel and a bit of sanding on the lathe.
I think it will not stay as it is, as the original ones was more polished. But also major steps are missing: I need to mill the cooling cutouts, and I need to add the "connections". The cowling had seems, so it could be opened without removing the airscrew for engine maintenance. I want to replicate that with alu foil (have done it once) but it is not easy as CA do not stick very good to alu. So with this raw surface I hope the glue sticks better to it. Let's see ...
« Reply #6 on: February 09, 2022, 07:50:49 AM »
Right on , N-17 triplane ! Fantastic stuff Frank !
Another Nieuport 17, Eduard 1/48, 9.2.2022 Cowling
« Reply #7 on: February 10, 2022, 02:28:33 AM »
« Last Edit: May 31, 2022, 01:48:30 AM by Bughunter »
Re: Another Nieuport 17, Eduard 1/48, 9.2.2022 Cowling
« Reply #8 on: February 10, 2022, 04:42:32 AM »
You are a machine! That amazing Camel has just rolled out the line and here is another masterpiece in the making. Great work all around.
« Reply #9 on: February 10, 2022, 04:54:37 AM »
You asked if anyone was interested in following your new build and I thought I'd be funny and say 'no, I'm bored with all of your fantastic detailing'... But that's obviously not true! Who wouldn't want to tag along and be mesmerized by your magic?!
Great work!
« Reply #10 on: February 10, 2022, 06:44:10 AM »
Wow Frank! You are progressing quickly but it certainly doesn't lack your usual Expertise and skills. The pulsator, engine, prop shaft, and of course that Cowling, are true works of art! Lovely and I can't wait for the next update!!
« Reply #11 on: February 10, 2022, 10:20:26 AM »
Absolutely wonderful Frank!  As has been said, you can't have too many French a/c in your collection, and to that I'll add you can never have too many Nieuports.\
I'll be following with great interest as I have a couple of 1/72nd Nieuport builds to get back to after my current project is off the bench. I am wondering how I'm going to thin my injected cowling to fit my Small Stuff rotaries.
WD
« Reply #12 on: February 10, 2022, 04:32:10 PM »
Looks like a good fit between the cowling and the fuselage.  The 'T' shaped pieces look fantastic.  Were they difficult to bend to the cowling shape?
« Reply #13 on: February 11, 2022, 04:00:56 AM »
Comments appreciated, guys, thanks!
I'm preparing the next update ...
No Ken, since the ridge is less than 0.5mm high and the aluminium is soft, a touch with the finger was enough.
Nieuport 17 Triplane, Eduard 1/48, 10.2.2022 Undercarriage
« Reply #14 on: February 11, 2022, 04:09:37 AM »
« Last Edit: May 31, 2022, 01:48:38 AM by Bughunter »
