Author Topic: WNW Fokker DVII (Fokker version)  (Read 23882 times)
Offline Epeeman
« on: January 07, 2013, 06:03:50 AM »
Hello, again all -
After having my confidence destroyed after breaking my last build (32nd Roden Spad VII - many thanks to you all for the moral support as it was very much appreciated) I thought long and hard about posting another progress report - I now worry that I might be tempting fate again.  However, my younger son (Andrew) has persuaded me to do another.  So, after taking breath have decided to fully grasp the bull very firmly by the horns again .................
This will be a build report on Wingnut's latest release of the Fokker DVII.  I am currently about 10 days into the build so early days as yet.
The first thing to say is that you need to decide on exactly what version (colours/markings) before starting work.  This is necessary because depending on the version you choose, different parts will be required to complete the build.   This turned out to be a difficult choice as all the schemes are very good.   Finally decided on version 'D' in the kit (as pictured below) for Fritz Oppenhorst of Jasta 71.   A brave decision for me because this scheme is pretty much lozenge marking so I hope the lozenge decals work out well for this one.  As is usual for me, this will mainly be OOB and brush painted model build.
I have now built up the cockpit/engine support structure as shown below.   Fit is very good but assembling this structure was very, very fiddly.  I caution some care removing the cockpit frame structure from the sprue - these parts are molded very fine and could be easily broken whilst cutting from sprue or during part clean up prior to assembly.  Luckily, I have not managed to break any of these delicate parts - phew!  Artist oils (burnt sienna) over ochre base were used to simulate the wood.
The other thing I have made up are the MG's with the PE air cooled jackets.  I did these now as on a previous build (WNW Pfalz DXII) managed to crush the jackets during assembly.  I therefore wanted to get this out the way early.  Luckily, I now seemed to have worked out how to get these together.  I worked out that the plastic at the breech end of the guns (where PE jacket sits on) is overly large and required a fair bit of trimming down before fitting.  I followed WNW's guide (on their website) on fitting these jackets and hollowing out the muzzles,etc.
Next stop - the engine.   Some pictures below on where I am currently up to.
Re: WNW Fokker DVII (Fokker version)
« Reply #1 on: January 07, 2013, 06:34:37 AM »
Excellent start Dave, it is good to see you jump straight back in after your previous disaster. The cockpit looks great so far, very well painted, I'm looking forward to seeing you progress with this kit.
« Reply #2 on: January 07, 2013, 06:44:20 AM »
Outstanding work on the cockpit and guns, mate, and an excellent choice of schemes.  Very striking.  Really glad to see you back in the saddle.
« Reply #3 on: January 07, 2013, 07:11:07 AM »
  Dave,
Outstanding first progress my old friend. Love that detailed interior. I'm looking forward to following this thread!
« Reply #4 on: January 07, 2013, 07:30:52 AM »
Welcome back to the fray Dave!  Great model choice.  Beautiful job on the cockpit! I'll be enjoying this one.  :)
« Reply #5 on: January 07, 2013, 09:06:06 AM »
Great start, looking forward to seeing this kit built...
« Reply #6 on: January 07, 2013, 09:11:16 AM »
Hello Dave:
Glad to see you back at it and doing the DVII.  I have the OAW version and will be following as you progress through this build.  So far you have hit the deck running and giving it an outstanding start.  I am like you; pretty much OOB.
« Reply #7 on: January 07, 2013, 09:57:48 AM »
Great jump out of the gate!!
Offline michael
« Reply #8 on: January 08, 2013, 01:08:01 AM »
Great start Dave keep them pics coming!
michael
« Reply #9 on: January 08, 2013, 01:17:16 AM »
Just want to confirm (read lazy) This is the version I use for Loerzers b/w machine?
Offline Epeeman
« Reply #10 on: January 11, 2013, 09:08:35 AM »
Gentleman - thank you for your comments.  Steve - this is version D for Oppenhorst of Jasta 71.
Latest progress:
Test fitting the cockpit structure into the fuselage revealed a not-so-good fit.   It would seem it is critical to ensure that this structure is built and fitted together correctly to ensure things go together nicely further into the build.  I have therefore had to trim some of the structure at the seat end (where it seems I went wrong somehow although I did follow the instruction diagram as carefully as I could) on either side of the frame.   You will see the area I had to trim in the photos below where bare plastic is showing.  Thankfully, things seem to fit together quite well now.
The above was undertaken whilst working on the motor.   I have completed the engine adding some very basic detail in the form of spark plugs (stretched sprue), ignition leads and valve springs using 5amp fuse wire.  Not brilliant, but enough to add a bit more interest.   Installed completed engine onto the engine mount within the cockpit structure.  This fitted, but was not great fit whereby I had to use CA glue to hold engine neatly in place.
I can now move onto fitting structure in fuselage and closing all up.  Hoping this all goes together well!
Apologies for the standard of photography of the engine, but the others have come reasonably well.  Next update to follow in due course.
« Reply #11 on: January 11, 2013, 09:26:07 AM »
Very nicely done Dave, the engine looks great sitting in the frame.
« Reply #12 on: January 11, 2013, 09:52:35 AM »
I agree, Dave.  Makes a damned fine model just as it is.
Offline Whiteknuckles
« Reply #13 on: January 11, 2013, 03:51:11 PM »
Great Progress Dave, it's good to see you throw yourself into this - your doing mighty fine.
Looking forward to more progress ;)
Eternal Apprentice
Offline kornbeef
« Reply #14 on: January 11, 2013, 05:31:27 PM »
Yes build her as an early. Not sure which top deck to use, I plumped for the later without the gun troughs. One thing you'll need though is lower wing crosses from the D.Va
Thats how I've interpreted it.
Dave, she's looking mighty fine.
Keith
« Last Edit: January 11, 2013, 05:37:48 PM by kornbeef »
