Author Topic: Sopwith Camel, 1/48 Eduard, 4.2.22 The end  (Read 39109 times)
Re: Sopwith Camel, 1/48 Eduard, 1.2.22 Tail
« Reply #135 on: February 02, 2022, 05:18:52 AM »
The tail looks sufficiently busy.  I see you are making extensive use of the RAF wire ends.
« Reply #136 on: February 02, 2022, 05:22:59 AM »
Exquisite work Frank! And may I say it's great to see James' photos being used to help your project.
« Reply #137 on: February 02, 2022, 05:38:57 AM »
More modelling marvellousness. (In Deutsch: sehr Wunderbar!)
« Reply #138 on: February 02, 2022, 07:14:55 PM »
Thank you very much to all of you!
You continue to amaze me with this detailed build!
I just added another nice detail 8)
You 32 builders are more lucky guys! I have only one size, in 1/32 one could use the smaller 1/48 terminals on the tail.
Anyway, better then nothing and those little buggers are smaller than my metal pipes or other solutions.
I have not included all the used pictures here in the build report, but I have download all of them in full resolution and have always some of them open while working on specific details. Really helpful pictures!
Re: Sopwith Camel, 1/48 Eduard, 2.2.22 Pitot tube
« Reply #139 on: February 03, 2022, 04:51:04 AM »
First I wish I had the skill to make those control horns and fittings in 1/32nd scale. It would solve an issue I am having with the DH2  ::) Yours are done to perfection! I don't know what part is missing but WOW, is that Camel Gorgeous!!
« Reply #140 on: February 03, 2022, 05:48:07 AM »
Sorry Frank but doctoring James' photo of the pipes on the front strut and trying to pass it off as your model will not do...!
What a model indeed - and the prop is still not fitted!! Is it 1/24 scale by any chance?
« Reply #141 on: February 03, 2022, 06:01:45 AM »
Now How did I miss that!  :-[
Offline torbiorn
« Reply #142 on: February 03, 2022, 07:22:23 AM »
Absolutely stunning, I’m speechless  :-X
No expensive PR campaign could make better commercial for this kit.
« Reply #143 on: February 04, 2022, 12:36:05 AM »
Incredible execution!!
« Reply #144 on: February 04, 2022, 03:38:14 AM »
It's one thing to see James' photos of these delicate-seeming details and tremendous craftsmanship (or, as I've been extremely fortunate, to see them in person) but to translate them into model form...and in 1/48...now that's something special. Frank, all that pipework and rigging is truly inspirational and aspirational.
Hear hear!
« Reply #145 on: February 05, 2022, 02:25:53 AM »
Thank you very much, to each one of you!
As I mentioned the control horns itself are from the PE set of PART. I made them only a bit thicker with tin and a soldering iron.
Stephen, as far as I know Eduard has not any 1/24 scale aircraft model in the portfolio, so this must be 1/48 :D
Rick, you made my day! ;D ;D
That's how we humans are - the obvious is often overlooked.
I think Eduard is aware of this fact 8)
If I know "what" I have to replicate, then I can also find a "how". But nothing works without references.
Re: Sopwith Camel, 1/48 Eduard, 4.2.22 The end
« Reply #146 on: February 05, 2022, 06:41:44 AM »
The prop is absolutely Gorgeous Frank!
Offline s.e.charles
« Reply #147 on: February 05, 2022, 07:01:29 AM »
beautifully done (whole project)
« Reply #148 on: February 05, 2022, 07:13:01 AM »
Gran finale. Top notch, as all this build.
« Reply #149 on: February 05, 2022, 06:07:35 PM »
Well done throughout, Frank! And as always a fantastic build report as well. Truly inspirational!
