Author Topic: Kondor D.2 1/48 SPIN model; 5.8.21 Finished  (Read 16549 times)
Re: Kondor D.2
« Reply #15 on: July 21, 2021, 09:16:49 PM »
Many thanks for the explanation Frank, evergreen sheet and white glue like your friend is doing sounds like the way ahead for me. I will have a go on my next project.  :)
Kondor D.2 1/48 SPIN model; 21.7.2021 Engine
« Reply #16 on: July 21, 2021, 09:21:03 PM »
Thank you Guy, Michael and Bud!
I have this one in my stash and it's been calling out to me for a few years now.  You just bumped it up in the queue.
Then the build report was already successful :D
I don't know, if SPIN models is still in business today? The latest release was 2016 according to scalemates.
Let's continue:
Engine
The drawing has a note "Oberursel U.0", but that is definitely not a U.0:
Source: wikimedia.org
Luckily I had the matching Small Stuff engine in my stash and have done it. During the build:
The finished engine. The ignition wires are added too. I really like the copper intake pipes (Alclad).
I turned again a new alu cowling. After that I milled a cooling slot for the undersurface.
The resin part is more thick.
Also the Axial airscrew is done in a raw shape.
All new parts for the front together with their kit counterparts.
The new parts working together.
The airscrew still need a bit of work, but there is a chance to reach the look of the original.
Note: here you see also the second prototype with a more powerful engine, different cowling and installed weaponry.
Re: Kondor D.2 1/48 SPIN model; 21.7.2021 Engine
« Reply #17 on: July 21, 2021, 10:18:20 PM »
Fascinating new project, Frank. Looks like another winner when I see the wings and the engine section!
« Reply #18 on: July 21, 2021, 11:28:44 PM »
Simply Stunning work as always Frank!
« Reply #19 on: July 22, 2021, 02:06:56 AM »
Glad that I have been a positive influence Frank  ;) Outstanding work on the cowl and engine !
« Reply #20 on: July 22, 2021, 05:12:55 AM »
Thank you Andreas, Rick and Alexis!
I hope it will look nice at the end. Much more elegant than the Quadruplane. I looked around in the internet but was not able to find this kit built.
« Reply #21 on: July 22, 2021, 09:55:56 AM »
Good choice on the engine change.  I didn't have to say anything.  :-X
Looks like you are getting comfortable with the machine tools (mill, lathe).
(I'll have you scratchbuilding something soon!  With resin pieces!)    ;D
« Reply #22 on: July 22, 2021, 06:21:45 PM »
Gorgeous, another gem under construction and another unusual subject. I'm very pleased to follow along.
« Reply #23 on: July 22, 2021, 06:36:40 PM »
More awesomeness from Frank! Beautiful engine but I especially love that cowling and prop. This is a fun project to follow!
Offline hrcoleman66
« Reply #24 on: July 22, 2021, 08:40:29 PM »
Oh my god!  Macrame is looking good as a new hobby...  I doubt I could even attempt to compete with this sort of work!
Hugh
« Reply #25 on: July 23, 2021, 12:25:28 AM »
Thank you very much my friends!
Oh yes, that is pure fun :D So it looks like I'm hunting for things to be replaced by machined parts ::)
At least there is an idea ... The resin part in this scratch project will be again a small stuff engine. All other parts will be wood, brass and also copper. Stephen also tried to convince me ...
Giuseppe, I'm very pleased that you are follow :)
Thank you Richie! Then let's keep the project under steam and do the next update.
Thank you Hugh, your post made me smile 8)
I can't help with Macrame, but I would be honoured if you would continue to watch!
Kondor D.2 1/48 SPIN model; 22.7.2021 Cockpit
« Reply #26 on: July 23, 2021, 12:32:01 AM »
Cockpit
There are not much info about the cockpit available so some fantasy is needed ;)
With some kit parts, metal, wood and a bit of paint I created the cockpit.
Since the opening is wide I missed something behind the dark frame so I created a fuel tank from wood and brass foil.
Ready for mounting.
Glued in place.
The seat belts are Eduard Steel PE, some dials are also Eduard PE.
Last view before closing the fuselage.
I cut also all control surfaces and made new hinges.
After glueing the fuselage halves I added also the prepared tail parts.
Looks nice with plugged on control surfaces.
On the front I added some plastic with the inside diameter of the cowling.
The cowling has a tight fit.
Re: Kondor D.2 1/48 SPIN model; 22.7.21 Cockpit
« Reply #27 on: July 23, 2021, 12:54:45 AM »
Excellent cockpit Frank. You are moving  along rapidly on this one. Looks great buttoned up!
« Reply #28 on: July 23, 2021, 02:02:11 AM »
As Rick says, you're making quick work of this, and it's looking great!
« Reply #29 on: July 23, 2021, 03:45:39 AM »
Thank you Rick and Ken!
I must admit, I already have a bit of a head start ::) I wanted to avoid to posting the next shelf queen and so check for early blocking points.
Now I have to wait a bit, because I painted oils on the fuselage some minutes ago.
After hardening I want to add some layers of a MRP red-brown clear paint to get some dark finish as on this picture:
Not sure if that is a good idea ??? Let's see ...
