Author Topic: WiP - Tribute to a Simple Time, Part II: 1/72 Airfix D.H.4  (Read 20451 times)
Re: WiP - Tribute to a Simple Time, Part II: 1/72 Airfix D.H.4
« Reply #15 on: July 09, 2021, 05:36:54 AM »
You can not not follow a build that has this kind of introduction!
It'll be fantastic, I'm sure, and the base, I assume this will get a similar one, is just amazing.
« Reply #16 on: July 12, 2021, 11:03:05 PM »
Looking forward to this.
Offline Brad Cancian
    • Brad's Models
« Reply #17 on: July 13, 2021, 07:06:46 PM »
Hi all! Some basic but important work has begun.
Firstly, I tackled the most annoying job; the flying surfaces. Like many Airfix kits of this era, these were quite overdone in terms of exaggerated ribs, textures, and mould release holes. The underside of the upper wing also had slots cut into them to take the struts (great if you're building this kit for simplicity, but not accurate). I filled the slots in the upper wing, and sanded back the flying surfaces (wings and tail) to get rid of the oversized ribs and overdone textures. I also sanded off the incorrectly oriented bomb racks (i.e. slabs of plastic). Lastly, I repositioned the ailerons for a more dynamic look. Here you can see the comparison of one wing sanded back, and one not:
Now both:
Though quite hard to see in the pictures, there are still rib impressions present, but very much toned down. Painting will be used to help highlight the ribs, once I get to that stage (that's quite a long way off!):
I've also built the foundational structure for the interior. I sanded off the interior pegs for the pilots, cut off the gun ring to the rear cockpit, and built up the fuselage sides with some superglue and filler to get the sides of the rear cockpit straight as per the drawings. I have added some bulkheads and frames, plus a rough approximation of the fuel tank that sat between the two cockpits.
It's not entirely accurate due to the lower wing attachment, but at this scale, for this kit, and for what will be seen on the finished model, that's good enough. As far as I can tell, not much will be seen of the front cockpit, at least. But hey, accurate or not, the foundations are there for the rest of the detail.
As I said, not much of a start, but it's a start at least!
BC
« Reply #18 on: July 14, 2021, 03:48:15 AM »
Quote
Well, I suppose the first foot in a 100 metres race isn't much of a beginning either, but still quite necessary in order to reach the finish line... 😃
I think it looks great! Wings definitely better with the reduced ribs and the interior is just so much better!
Offline RLWP
  • Bodger
« Reply #19 on: July 14, 2021, 04:18:57 AM »
This " Tribute to a Simple Time" thing then
I cannot understand why this is taking so long to build! A much younger me would have had this built in an afternoon
OK, it would have had styrene melts, fingerprints in the paintwork, wonky decals and every possible piece of armament fitted. However....
 ;D
    • Brad's Models
« Reply #20 on: July 14, 2021, 07:09:37 AM »
You're describing how most of my models turn out anyways Richard...!  ;D ;D :P
Offline RLWP
  • Bodger
« Reply #21 on: July 14, 2021, 07:11:27 AM »
Happy days. Loosely follow the instructions then use every bomb, rocket and drop tank on the sprues
I'm getting Airfix nostalgia
« Reply #22 on: July 14, 2021, 05:32:35 PM »
Lovely Brad!
I do love these old Airfix kits. It doesn’t look that bad either. I recently built their Demon from 1957 and had more fun with that than a lot of fancy modern kits.
The interior work is stunning already!
    • Brad's Models
« Reply #23 on: July 14, 2021, 07:28:58 PM »
Great work Guy! I'm guessing you also had to do a bit of sanding on those wings.
Out of interest, does anyone know if there are any photographs around of the Airfix kit subject, DH4 serial number A8032?
BC
Offline Flute
« Reply #24 on: July 14, 2021, 08:53:31 PM »
   Brad, The DH4/DH9 File, by Sturtivant and Page, towards the bottom of page 47. Dark band and letter 'C' benind rear cockpit, some sort of star shaped light marking on the wheel covers.
Paul.
    • Brad's Models
« Reply #25 on: July 14, 2021, 10:38:02 PM »
Thanks heaps Paul - unfortunately I don't have a copy of the DH4/DH9 file, is someone able to PM me a copy of the picture? (I figure sharing it here would probably breach some kind of copyright...)
Thanks again!
BC
« Reply #26 on: July 16, 2021, 04:34:12 AM »
The interior work is Fabulous Brad! I am sure the wings will be equally so!
« Reply #27 on: July 16, 2021, 06:17:38 AM »
Great stuff! I really enjoy seeing these old kits getting brought up to date. This is going to be something very special.
« Reply #28 on: July 17, 2021, 02:01:58 AM »
Nice tweaks Brad  :)
« Reply #29 on: July 17, 2021, 09:56:17 AM »
Great progress Brad, I'm enjoying this thread.
Guy, that a/c is simply gorgeous!
WD
