Author Topic: Printing decals  (Read 2462 times)
Offline Plodder
Printing decals
« on: July 02, 2021, 12:54:23 AM »
I've had a couple of goes of printing my own decals. Inkjet iprinter on clear decals paper. I'm pleased with the results,colour and definition, but when  I  apply them the colours  are  translucent, and  don't look anywhere near a good.. Anyone  tried this , and  any tips.?
Re: Printing decals
« Reply #1 on: July 02, 2021, 01:10:37 AM »
Have you tried using white decal paper ?
Re: Printing decals
« Reply #2 on: July 02, 2021, 05:31:30 AM »
Increase the color density on your printer, then seal with a clear acrylic.
Cheers, Bud
Offline Plodder
Re: Printing decals
« Reply #3 on: July 02, 2021, 05:39:37 AM »
Hi Alexis,I dont want a white border on the decals,and cant cut them accurate enough to leave no edge. Hi Coyotemagic, colour from printer is good, I use high quality photo setting,and  clear coat.
Offline hsmed
Re: Printing decals
« Reply #4 on: July 02, 2021, 04:30:29 PM »
Hi Plodder
If you use an inkjet printer, there is - as far as I know - no way around using white decal paper, if you want to avoid the background colour to bleed through.
But you can avoid a white edge by using the colour of the subject as the background for your decal. At the picture, I have applied the white 'Red Horse' lettering to a bright red area of the car. The way I made the decal was, that I drew a large red square and filled in the white lettering - then printing the whole square at a white decal sheet. In this way I have the white letters with a narrow red frame.
If you look closely at the picture, you can see a small colour difference between the red paint and the decal, but this can be minimized by adjusting the colour at the decal - however, I was satisfied with this.
You can see, the white is a little pink due to the red paint - this is due to the decal paper itself not being 100% opaque. This could also be minimized by applying two decals on top of each other or by applying a white decal square before the decal with the lettering.
However, this technique is hard to use if your background is not in a uniform colour as in my example.
Another way is to use a laser printer with white toner. You can buy a white toner kit for some laser printers - see link - but I have not tried it myself.....yet :-)
https://www.ghost-white-toner.com/
Hope, you can use some of this - and if you succeed it would be great to see the results :-)
Re: Printing decals
« Reply #5 on: July 02, 2021, 09:53:20 PM »
One way I overcome this limitation with inkjet printed decals is to paint a white background.  I have a Silhouette cutter that makes this somewhat easier.  For example:
In this case, the decal is printed with a black edge to hide any inaccuracies with the outline shape.
Offline RLWP
  • Bodger
Re: Printing decals
« Reply #6 on: July 03, 2021, 06:37:15 AM »
I've had terrible results with clear paper, excellent results with white.
I've usually managed to lose the white edge with either paint or weathering
Offline Plodder
Re: Printing decals
« Reply #7 on: July 05, 2021, 07:55:23 AM »
Thanks for the replies I will try with white paper.
Re: Printing decals
« Reply #8 on: July 27, 2021, 10:57:12 PM »
Lets us know how this works out for you .
