Author Topic: 1:32nd scale Ponnier M.1  (Read 3201 times)
« on: June 25, 2021, 04:48:46 AM »
I thought you might like to see my 1:32 scale build - the French Ponnier M.1, Serial No:18 ‘Le Vampire’ of the Aviation Militaire Belge as flown by Abel de Neef from the Ten Bogaerde (Koksijde) airfield in 1915.
The basic kit is resin and made by ‘Planet Models’ (Kit No: PL253).
The list of changes/additions to the model are:
Engine:
Detailed with Nickel-Silver valve push rods and copper wire ignition leads.
Modified or corrected:
All wing and landing gear struts were replaced with made Brass tube struts with internal reenforcing Brass rod.
The lower wings had 1.0 mm diameter Brass rods added to give adequate support at the fuselage.
Rigging is 0.08 mm or 0.12 mm diameter mono-filament with ‘GasPatch’ 1:48th scale turnbuckles and 0.5 mm or 0.4 mm diameter blackened Brass tube.
Animation of the ailerons, rudder and elevators achieved by cutting out with Brass rod supports.
Aftermarket additions:
‘Xtradecal’ parallel black stripes (XPS1),
‘Aviattic’ CDL aged varnish (ATT32094),
‘Lukgraph’ Dark Plywood (DEC004) - from their Friedrichshafen FF.33L kit (32-30).
‘Wings Cockpit Figures’ Pilot adjusting goggles - (LSK02).
‘GasPatch’ 1:32nd scale Lewis MK.1 Stripped Half Heatsinks.
‘Model Scene’ Wetland Middle (F011).
As usual I've created a downloadable build log in Adobe PDF format, for those who might want to refer to it for reference or build details.
It contains full step by step descriptions of the model build, its modifications/changes and is also supported with illustrations and photographs.
If viewed in Adobe Reader, each build log has book marked chapters/headings for easier navigation through the log.
My model website has the gallery page, so to view any model, go to the gallery (in my link below) and select it.
If it has a PDF build log, it will be available to download using the 'PDF' icon on that models photo's page.
For any photograph, just click the photo to enlarge or reduce the viewing size.
« Last Edit: May 16, 2022, 09:37:46 PM by Mike 'Sandbagger' Norris »
Re: 1:32nd scale Ponnier M.1
« Reply #1 on: June 25, 2021, 08:24:44 AM »
Superb rendition of the wood fuselage. This was a small machine but you have really captured the look of the original. The metallic finish on the nose and staining on the leading edges of the wings are remarkable. That is truly a masterpiece.
« Reply #2 on: June 25, 2021, 11:05:53 AM »
Another beauty from your bench  :)
« Reply #3 on: June 26, 2021, 01:53:43 AM »
Very Nice work ! and good to see such a lessr know subject !
« Reply #4 on: June 26, 2021, 03:38:42 AM »
What a lovely biplane! It looks so real :)
The colorful Belgian cockades are nice, I need to check if there is a kit in 1/48.
Congratulation!
« Reply #5 on: June 28, 2021, 03:25:11 AM »
Truly great work on display here, Mike -
A machine I have not heard of before so makes a change
« Reply #6 on: June 28, 2021, 03:30:34 AM »
   Another winner Mike, just plain beautiful! Your productivity is exceeded only by the quality of your work, my compliments on a "top drawer" model.
« Reply #7 on: June 28, 2021, 06:40:02 PM »
Typical Mike's... Great paintowork, care for details, nice presentation. Keep them coming, please, it is a pleasure to see your models.
« Reply #8 on: June 28, 2021, 06:53:57 PM »
Superb model, Mike and beautifully presented. I can feel they are raring to get in the air after whatever the pilot is spying!
Offline ModelCellar
« Reply #9 on: June 29, 2021, 12:31:08 AM »
VERY nice!  I like the subtle weathering and I especially like the wood fuselage.  Outstanding !!
« Reply #10 on: June 29, 2021, 12:35:36 AM »
As always I enjoyed following your build. The results are Fantastic! I Love the weathering and display! Well Done Mike!
