Author Topic: Help sought for flattening styrene sheet  (Read 1649 times)
« on: May 24, 2021, 01:47:55 AM »
I'm not sure this is the right place to post this question, but I leave it to the moderator to move this topic.
A while ago I bought 0.5 x 1400 x 1000 mm styrene sheets. They were sent rolled up in tube and I was stupid enough to leave them in there.
Now I need them, but they refuse to take their original form (flat).
Does anyone know how I can straighten them again?
I can cut of portions, but the biggest size I will need to work with is about 400 x 150 mm.
Any help, hint or tip will be appreciated.
Offline Berman
Re: Help sought for flattening styrene sheet
« Reply #1 on: May 24, 2021, 10:16:37 AM »
You could try placing the styrene between two minimum 5mm thick sheets of absolutely clean glass. Place in direct sunlight. Check every thirty to sixty minutes depending on the temperature.
