Author Topic: Wight Quadruplane, Spin Models 1/48  (Read 8978 times)
Re: Wight Quadruplane, Spin Models 1/48
« Reply #15 on: May 18, 2021, 07:04:09 AM »
I really like odd aeroplanes and this is truly one of them. This is the handiwork of a true craftsman modeller: the engine cowlong and metal parts, extra tiny but significant details, rigging - I could go on and on. It looks much bigger that it really is - I could easily believe that was 1/32 scale. Another gem in your collection of jewels.
« Reply #16 on: May 20, 2021, 06:13:38 PM »
Hi Frank,
Congratulations on a seriously stunning build.
I'd not seen this aircraft until your build started.
The build detail and especially the rigging are top notch,
Offline Fvdm
« Reply #17 on: May 22, 2021, 05:05:42 PM »
Superb Frank. It's sometimes a real challenge to align two wings properly but you managed to align 4 wings. Great!
« Reply #18 on: May 22, 2021, 11:09:35 PM »
    You've done it again Frank, another truly spectacular addition to your beautiful collection! The detailing and your signature scratch built additions, most particularly the metal work, place this work in a class of it's own. Most impressive, and my sincere compliments on your enviable skills!
« Reply #19 on: May 28, 2021, 05:11:28 AM »
Thank you Andreas, Ken, Guy, Prze, Stephen, Mike. Ferry and Lance! Your comments are highly appreciated!
I don't expect to see another one of these!
What about this one on your bench? Looks very common to your recently built 504:
https://www.iwm.org.uk/collections/item/object/205314509
Mike, the bird (and the distance between the wings) is so small that I could not use the usual turnbuckles or RAF wire terminals. Rigging felt like I was building a 1/72 model ::)
Here I take the advantage of my build method. It was possible to bend the brass pins of the struts with brute force on the wings. ;)
Lance, I am very glad that these skills now include resin models. This will definitely not be the only model made of this material.
Sorry for my late answer, as I was some days not at home (so also no progress on my projects).
« Reply #20 on: May 30, 2021, 06:33:16 PM »
That's excellent, Frank!  Really quite an eye catcher.
« Reply #21 on: June 02, 2021, 06:04:56 AM »
Hats off Frank.
The four wings would be a nightmare for me!
Offline cduckworth
    • My WW1 Models
« Reply #22 on: June 05, 2021, 11:14:44 PM »
What a wonderful build; Spin kits aren’t the easiest to build I’ve done their Bristol M.1c and the Sage.  It had to have taken considerable time and lots of patience to line up those small struts and the four wings.  And then add the complex rigging.
The finish colors look perfect too. Congratulations on a great model.
"Look alive. Here comes a buzzard."  Pogo
« Reply #23 on: June 13, 2021, 04:02:51 AM »
Thank you very much Gaz, Willem and Charlie!
Oh yes, the kit was for a long time in my stash, I found it interesting, but was a bit afraid due to resin and the four wings.
It was helpful to do a kit conversion with a Spin modification set (Pfalz Triplane Experimental) to get familar with that resin.
« Reply #24 on: June 14, 2021, 04:55:32 AM »
The real plane moght have been under-appreciated, certainly not your excellent model !
« Reply #25 on: June 21, 2021, 03:05:11 AM »
Thank you Ed!
That was not my last build of Spin Models, as 'half-model' scratch builder it gives my a good base to add scratched parts ;)
Nice to see you, I hope you are fine!
