Author Topic: Anyone able to do an article on gluing resin kits?  (Read 7704 times)
« on: May 14, 2021, 11:43:11 AM »
With the growth in the resin kit industry,. most notably in the 1/32 scale field, it's occurred to me many here ( including myself) may be novices at making resin kits and would benefit from and appreciate any tutorials on how to make a resin kit.
The best glue type and best glue techniques would be especially welcomed. Best primer. Any special techniques different to standard plastic kits?
There are several resin kits I'm tempted by but my knowledge and skills base in making resin kits is lacking, hence the idea of an article or post from someone skilled in this field.
Thanks in anticipation.
Re: Anyone able to do an article on gluing resin kits?
« Reply #1 on: May 14, 2021, 12:42:18 PM »
I might be able to aid you in this Dave , what type of kit do you have in mind ...Old moldings or newer ones ?
I still have a few WW 1 resin kits left in the stash . I don't have any 32 scale , but I do have 72 and 48 scale subjects .
« Last Edit: May 14, 2021, 12:48:03 PM by Alexis »
Offline Dave Brewer
« Reply #2 on: May 14, 2021, 01:31:07 PM »
Worth noting that Dave Lockhead of the former Kiwi Resins produced a terrific work on this very subject still available on Kindle cheap as chips, or free to Amazon members.
Dave.
Offline Edo
« Reply #3 on: May 14, 2021, 03:12:34 PM »
this would be a very welcome thread
ciao
edo
« Reply #4 on: May 17, 2021, 10:07:37 PM »
It may also be worthwhile to create a sticky thread with tips about building resin kits in general, not pertaining to any specific kit.
This could be a depository for such information with contributions from multiple builders.
« Reply #5 on: May 17, 2021, 11:47:33 PM »
Yes, A Sticky thread or separate thread like the Rigging for Everyone Tutorial. It might even "Tempt" Me to try resin if it is clear enough  8)
Offline rhwinter
« Reply #6 on: May 18, 2021, 02:13:27 AM »
Yes, that would be it for me, too!
Offline RLWP
  • Bodger
« Reply #7 on: May 18, 2021, 03:10:52 AM »
Quote
<groan>
« Reply #8 on: May 18, 2021, 02:22:27 PM »
Some great ideas folks. So if I create a sticky thread on how to glue resin kits, will someone post a 'how to' article in said thread?
I am hugely relieved to discover I am not the only one a bit intimidated by resin models.
cheers
« Reply #9 on: May 18, 2021, 11:07:58 PM »
Put up the sticky Dave and I will add to it .
« Reply #10 on: May 19, 2021, 01:13:34 AM »
cheers
I have had a Huge Fear of resin kits since I totally botched a JMGT 1/48th SPAD VII in the early 90s'. Cost then was @ $79.00 US and it broke My Heart and  Will to try more resin  :'(
Offline Gene K
« Reply #11 on: May 20, 2021, 08:17:56 PM »
... Dave Lockhead of the former Kiwi Resins produced a terrific work on this very subject still available on Kindle ... .
Thanks, but could you provide a link as I am incompetent in finding the Kindle file?
Gene K
Offline Dave Brewer
« Reply #12 on: May 20, 2021, 08:40:08 PM »
Here you go Gene:https://www.amazon.com.au/How-Build-Resin-Aircraft-Models-ebook/dp/B00Z6DPQPU
Dave.
« Reply #13 on: May 30, 2021, 09:25:59 PM »
Hi Dave,
Here's a few links to a various 'working with resin' guides.
http://www.scalemodelguide.com/construction/techniques/working-with-resin-parts/
https://www.forgeworld.co.uk/resources/fw_site/fw_pdfs/Modelling/Working_With_Resin_Models.pdf
https://www.thesprucecrafts.com/assembling-resin-kits-2382534
Also don't forget our 'Des' has some build logs on his pages.
https://www.ww1aircraftmodels.com/
If it helps, the build logs of my specific resin builds can be downloaded from my site (link in signature).
Currently these 1:32nd builds are:
Macchi M.5
Ansaldo 'Baby'
Ansaldo 'Balilla'
Aviatik 'Berg' D.1
Port Victoria PV.7 'Grain Kitten'
DFW T.28 'Floh'
Sopwith 'Swallow' (conversion)
Hansa-Brandenburg W.20
WIP:
Ponnier M.1
Mosca-Bystritsky MB bis
« Last Edit: May 30, 2021, 09:45:46 PM by Mike 'Sandbagger' Norris »
« Reply #14 on: May 30, 2021, 10:56:20 PM »
I built a few back in my 1/48 days - the TC Resins Short 184 and Felixstowe F2a, some JGMT stuff, some Jaeger Resins Axis 2-seaters.
Haven't built one for a while, apart from the AlleyCat Bristol M1c, but the main thing I remember is using Monofilament thread through wings as a structural component to keep the heavy wings true, especially the landing wires.
Not much different from plastic, except use a razor saw for cutting and wear a mask. CA glues well and also fills air bubble holes.
I wouldn't hesitate if the subject appealed.
My 2p FWIW
