Author Topic: FF-33E 1/48  (Read 36422 times)
Re: FF-33E 1/48
« Reply #195 on: January 04, 2022, 02:22:35 PM »
Stephen and Marc . Moving forward with some subjects I will agree with you and follow down that path however, there is a few subjects that will get super detail for they will be the only ones I will build of them . Besides there is about 250 its in the stash , goal is to try ( try being the key word ) building most of them before I leave this rock !
Thanks Zac and Fredrik , Fredrik , glad you found the others and are enjoying the build . :)
Re: FF-33E 1/48
« Reply #196 on: January 05, 2022, 06:54:37 PM »
Starting to really look like an aircraft now, Alexis -
Lovely work on your engine!
Re: FF-33E 1/48
« Reply #197 on: January 06, 2022, 10:21:19 AM »
Thanks Dave  :) Working out the mounting of the floats and struts , I dropped one of the struts and when I moved back to see where the bugger went too . I ended up catching it with the bottom of sock , strut broke and needed repair and I missed placed the forward strut hole on the cowl , twice ! One of those blond moments and yes , more will be had in the future . I'm a master of my own moments ! lol .
Plus side while looking through my resin build on where I left off I found the PE frames for the wind screens ! One very happy lady indeed .  :)
Re: FF-33E 1/48
« Reply #198 on: January 06, 2022, 07:59:57 PM »
Yes, I know those bugger moments only too well, Alexis -
I always seem to break fine parts (separating from sprue) and had to make repairs on my Pfalz.  Either that or I drop a really small part that disappears forever in the carpet ............
Re: FF-33E 1/48
« Reply #199 on: January 07, 2022, 04:50:02 AM »
Just to chime in with my own Moment that is forever burned into my memory, although it is a decade or so off-topic: I was building the Brengun 1/144 Mignet HM-14 Pou-du-Ciel aka Flying Flea - yes, a 1/144 Flea!! - and the fuselage, rudder and lower wing were all in place. I assembled the PE engine mount-cum-top wing strut, added the engine, set the assembly aside to dry...and the whole power/mount section dropped and vanished from existence. I spent literal hours scouring the carpet under my chair, the floor (I was using the garage as my hobby room at that house), swept, used a vacuum cleaner with pantyhose over the nozzle...all to no avail. Truly the worst experience I've had in modelling (the only time I've actually cried over a model) and, sadly, the only good news is that the rest of the kit and airframe survives should I muster the courage to scratch the missing bits. At least, I hope it's still here somewhere...
Anyway, back to Alexis' fantastic Friedrichshafen!!
Re: FF-33E 1/48
« Reply #200 on: January 12, 2022, 01:31:47 PM »
Gee Zac , you sure seems to have quite the adventures when it comes to modelling .  ;) Thanks for sharing your tale .
Today I spent a few hours adding more struts to the assembly . Don't have the room which once accommodated my need for space So taking a different avenue will try to assmelb as much as possible or what can be gotten away with out too much complications for painting . Gotta let this dry overnight so I can test fit the floats and make adjustments . But so far , swimmly well she goes !
Re: FF-33E 1/48
« Reply #201 on: January 13, 2022, 03:22:26 AM »
Despite how attractive some of the Great War seaplanes are (such as the FF-33) the struts for the floats put me off somewhat. I'm glad to see you're not fazed by them, Alexis! They look great! I'd love to build Wolfchen one day given her history around/over New Zealand.
It's a tale as old as time, but that build was quite sentimental for me as I've been a Flea fan all my life. I'd love to build my own in 1/1 one day...
Re: FF-33E 1/48
« Reply #202 on: January 13, 2022, 05:52:21 AM »
Looks good at the moment Alexis. I hope that the floats fir properly when you come back to this tomorrow.
Re: FF-33E 1/48
« Reply #203 on: January 13, 2022, 05:15:47 PM »
Thanks Zac and Stephen !
Slow as the wind blows , more progress moves forward . Test fitting the floats prove that I was successful with my efforts yesterday with the struts .  :)
Not many parts left to go , made a break on getting the details for the rad made , dip the wind screens in future . Ended up losing the part for the control horns on the rudder so will have to make a new one .
Re: FF-33E 1/48
« Reply #204 on: January 13, 2022, 05:16:17 PM »
Re: FF-33E 1/48
« Reply #205 on: January 14, 2022, 02:06:25 AM »
Great that you are working on on this. Strange assembly approach, I would have glued the struts to the floats first. Anyway, I am glad to hear that everything fits well  :)
Re: FF-33E 1/48
« Reply #206 on: January 14, 2022, 05:13:46 AM »
Steady progress Alexis: good.
Re: FF-33E 1/48
« Reply #207 on: January 14, 2022, 05:14:10 AM »
Great work Alexis, it seems the strut assembly works as good as it looks. The PE for the windscreens should set those off nicely!
Re: FF-33E 1/48
« Reply #208 on: January 14, 2022, 09:37:00 AM »
Nice work on the struts and the floats look to be seated perfectly. Excellent progress Alexis!
Re: FF-33E 1/48
« Reply #209 on: January 14, 2022, 06:50:13 PM »
Alexis,
Good to see you have managed to get all the struts sorted out and floats being added.
