Author Topic: FF-33E 1/48  (Read 36292 times)
Re: FF-33E 1/48
« Reply #165 on: December 25, 2021, 12:52:07 PM »
Awesome progress Alexis!
Offline Stuart Malone
Re: FF-33E 1/48
« Reply #166 on: December 28, 2021, 06:10:40 AM »
That engine is quite prominent!  Very nice job.  I especially like the staggering of the rocker arms.  That adds quite a lot of realism, IMO.
Stuart
Re: FF-33E 1/48
« Reply #167 on: December 28, 2021, 07:10:57 AM »
Nice work Alexis, it's looking good!
Re: FF-33E 1/48
« Reply #168 on: December 29, 2021, 06:15:46 AM »
Good work! Looking forward to primer and continued construction.
Re: FF-33E 1/48
« Reply #169 on: December 31, 2021, 01:50:14 PM »
Thanks guys for your continuing support  :)
Over the seasonal holiday was able to get a few days in wth cleaning up the struts and there is a fair amount of them . The prop detail wasn't very crisp with the prop being to thick . I searched the spare box and came out empty handed so cleaning up the kit prop with the aid of a Copper States Models PE prop boss , 1mm hex rod and bit of .5mm brass rod and I end up with something that looks better . A few of the struts will get pinned and the fun part is next , rigging holes ! Then t should be off to the painting stage .
Re: FF-33E 1/48
« Reply #170 on: December 31, 2021, 01:50:42 PM »
Re: FF-33E 1/48
« Reply #171 on: December 31, 2021, 01:51:32 PM »
Re: FF-33E 1/48
« Reply #172 on: December 31, 2021, 11:03:33 PM »
Good work, especially on that prop!
Re: FF-33E 1/48
« Reply #173 on: January 01, 2022, 12:28:06 AM »
The parts look good Alexis. Like Fredrik said, especially the prop!
Re: FF-33E 1/48
« Reply #174 on: January 01, 2022, 02:51:59 AM »
Oh, after I was out of the town for a while I found some progress pics here - Alexis is back on the bench!
Happy New Year!
Re: FF-33E 1/48
« Reply #175 on: January 01, 2022, 11:13:38 AM »
Happy new year guys ! And thank you very much  :)
Little bit more was done today with getting the struts pinned and started painting up the power plant . Tomorrow if all goes well should have all the rigging holes drilled for eyelets . Once the bit more is done will post some pic's .
Frank , it's good to be back
Re: FF-33E 1/48
« Reply #176 on: January 01, 2022, 09:08:05 PM »
Good to see you back at the model bench, Alex -
Good progress on your struts and prop
Re: FF-33E 1/48
« Reply #177 on: January 02, 2022, 01:47:48 AM »
Excellent progress with the struts and prop.
Re: FF-33E 1/48
« Reply #178 on: January 02, 2022, 05:27:39 AM »
Awwww , thanks guys !
Anyone who has this kit I recommend replacing the struts with something a bit stronger . The struts when molded are a mismatch most noticeable on the float struts than again must of the kit parts are . I was going to replace them but I don't have enough material to make it work in my favor , which is alright .
Re: FF-33E 1/48
« Reply #179 on: January 03, 2022, 12:48:31 PM »
Past few day has left the bench with progress moving forward , which is always a good thing even better after a joint , which seems to make the time go by fast .
Engine has been painted with a wash and fit in place with the front cowling included  Once the the glue sets a bit it will need sanding need to smooth out the ruff areas . Forward landing bracing struts are fitted , these are the kit parts and need to be test fitted and trimmed to fit . I do recommend replacing these . The plastic is very soft and filmys . So I should mention be careful when sanding , it goes very quick !
Tail feathersssss ( wipes spit off computer screen ) in place and the struts I replace with rod . I see no reason to the clean up the kit parts when rod just needs to be cut to length and well ..just saves time in the really . So once the nose work is done and a few more holes drilled for the float struts , it's off to primer to see if my skills have improved since my relapse .
« Last Edit: January 03, 2022, 12:58:14 PM by Alexis »
