Author Topic: Roden 1/48 Fokker D.VII Albatros  (Read 11060 times)
Offline Matti
Re: Roden 1/48 Fokker D.VII Albatros
« Reply #15 on: May 10, 2021, 01:16:51 AM »
After celebrating my girlfriends birthday and the Mothers Day this weekend, i managed to steal some time for my project, cockpit parts are almost done, i made the seat cushion from Tamiya epoxy putty, buttons from plastic rivets, i also used seatbelts from Eduard pe set, from that same set i took the throttle lever and some instruments, only some touch ups remain and the fuselage halves can be glued together.
« Last Edit: May 10, 2021, 01:25:18 AM by Matti »
« Reply #16 on: May 10, 2021, 01:29:48 AM »
Gorgeous interior work! Looking Fantastic!
Offline Matti
« Reply #17 on: May 10, 2021, 01:55:38 AM »
Thank you :)
« Reply #18 on: May 10, 2021, 06:46:21 AM »
Lovely detailing, you must be very pleased with how this is going.
« Reply #19 on: May 10, 2021, 07:47:39 PM »
Nice work in the pit  :)
Offline Matti
« Reply #20 on: May 11, 2021, 12:01:41 AM »
Thanks!
I am quite pleased, wash is maybe too dark, i used Mig dark wash, usually i mix washes from oils.
« Reply #21 on: May 11, 2021, 12:08:55 AM »
Excellent work on your interior, Matti. That camo pattern on the interior walls turned out exceptionally well indeed.
Offline Matti
« Reply #22 on: May 11, 2021, 03:56:49 AM »
Many thanks Gary :)
« Reply #23 on: May 11, 2021, 03:59:53 AM »
Really nice work on that cockpit, Matti! You have a sure touch and bring out the best! Regards, Marc.
Offline Matti
« Reply #24 on: May 12, 2021, 03:46:31 AM »
Thank you :-)
« Reply #25 on: May 12, 2021, 04:51:39 AM »
Super internal details. I just hope that most of them will be visible when you close up the fuselage.
Offline Matti
« Reply #26 on: May 12, 2021, 01:13:11 PM »
« Reply #27 on: May 12, 2021, 06:35:15 PM »
Lovely work on the interieur, Matti. The seatbelts look great.
Bye,
Offline Matti
« Reply #28 on: May 13, 2021, 07:20:44 PM »
Thanks Manni :)
Offline Matti
« Reply #29 on: May 14, 2021, 01:51:57 AM »
Fuselage halves and cowling pieces glued together. So far nearly every part in this kit has required trimming, even carving and constant test fitting before final assembly. Upper cowling pieces seem to need some extra work too to fit properly in place :-\
