Author Topic: Friedrichshafen FF.33L CHFT + Zeebrügge Rail Car  (Read 45659 times)
Offline kkarlsen
Re: Friedrichshafen FF.33L CHFT + Zeebrügge Rail Car
« Reply #45 on: June 01, 2021, 06:18:49 PM »
Thanks Günther, that would be awesome having a locomotive (not promising anything)
Spend the last couple of days on the Benz Bz III engine:
The pushrods have been replaced by nickel + some additional detailing.
Dirty and mucked up  ;)
Cheers: Kent
« Reply #46 on: June 01, 2021, 10:00:38 PM »
Your engine looks Terrific! I will save the photos for reference!
Offline kkarlsen
« Reply #47 on: June 01, 2021, 10:24:48 PM »
Thank you Rick, not my favorite discipline  :'(
Kent
« Reply #48 on: June 01, 2021, 10:27:32 PM »
Incredibly realistic engine!
« Reply #49 on: June 01, 2021, 11:04:25 PM »
EYE CANDY  ;)
Offline kkarlsen
« Reply #50 on: June 02, 2021, 12:27:25 AM »
Thanks Richie, I 'aim to please'
No seriously the 3D printet engine crankcase has some moiré effect which the aluminium paint enhanced.
So I kept on adding engine grime until it was almost invisible  ;)
EYE CANDY  ;)
Thank you Alexis!
Kent
« Reply #51 on: June 02, 2021, 04:01:57 AM »
Great engine, Kent. The spring looks terrific and the wiring makes the engine look very good.
Bye Manni.
« Reply #52 on: June 02, 2021, 06:48:24 PM »
Gorgeous engine, indeed. I still wonder, what will you do with it. Bury inside the fuselage?  ;)
Offline kkarlsen
« Reply #53 on: June 02, 2021, 07:53:06 PM »
Bye Manni.
Thank you Manni & Przemol!
I have another Benz Bz III engine, this will be used for the FF.33L built, saving the Lukgraph from being 'buried inside the fuselage'
Since I found this rather nice photo, I've decided to 'convert' the built into the FF.33L CHFT Marine Number 1247.
Up until not these are the alterations I will need for this:
Wireless + antenna & generator (HB W.29)
Different radiator and a leftover propeller from the Hansa kit, Axial?
Extra wing fuel tank and fuel leads.
I will also be reworking the Observers 'coaming' as it looks to me, to be a bit on the small side + the parabellum 'ring' (HB W.29).
Different windscreen. I will be using Aviattic German Naval Hex - Faded.
Wing fuel tank.
Radiator and Propeller on a CHFT
Closeup of some of the important details on Marine Number 1247.
Cheers: Kent
Offline Matti
« Reply #54 on: June 03, 2021, 03:57:58 AM »
Very realistic looking wood effect on those interior parts, the engine looks like the real thing too.
Offline hrcoleman66
« Reply #55 on: June 03, 2021, 08:49:02 AM »
Superb work on the engine!
Hugh
Offline kkarlsen
« Reply #56 on: June 03, 2021, 06:21:00 PM »
Thank you Matti, appreciate it!
Hugh
Thank you Hugh!
« Reply #57 on: June 03, 2021, 09:19:52 PM »
Are the insulators on the fuselage side for the radio ?
Offline kkarlsen
« Reply #58 on: June 03, 2021, 09:50:13 PM »
I'm not very 'electric' but I haven't seen them on FF.33L type's other than the CHFT ones, so I guess it is?
The generator is mounted on the other side of the fuselage...
Would be nice though, if there were someone 'out there' who had the knowledge  ;)
Regards: Kent
Offline kkarlsen
« Reply #59 on: June 03, 2021, 10:31:04 PM »
Progress on the Friedrichshafen built:
The fuselage is assembled, putty'ed and sanded some. I've rebuilt the observers coaming to fit the ring from the HB W.29.
(Shrunken a bit, to look the part)
The wings have been painted in a base color, top white and bottom Gunze Sail color. Wholes for rigging has been drilled and they are now ready for masking.
Thanks for looking: Kent
