Author Topic: Roland C.IIa, WnW 1/32  (Read 10049 times)
Offline mess
Re: Roland C.IIa, WnW 1/32
« Reply #45 on: April 12, 2021, 06:21:15 PM »
The last one with whale smile and tail skid.
Martin from Czechia
Offline mess
« Reply #46 on: April 12, 2021, 10:05:18 PM »
First turnbuckles installed to fuselage front part. As I wrote earlier, I used resin Gaspatch 1/48 as it seems better to my eyes than 1/32 ones. And started to work on landing gear. Plough paint wear was achieved with some chipping solution. Weathering was created as before with oil paints and pigments.
Martin from Czechia
Offline mess
« Reply #47 on: April 12, 2021, 10:05:51 PM »
Martin from Czechia
« Reply #48 on: April 12, 2021, 10:39:30 PM »
This is continuing to be a Great guild log. Your painting and weathering is impressive. The decals came out beautifully!
Offline mess
« Reply #49 on: April 13, 2021, 06:32:03 PM »
I'm using monofilament for rigging. I used Uschi but it seems to thin and flat to me. I thought how to paint the line. The method accepted was to put monofilament to sprue, fix it on both sides with CA glue and airbrush it on it. It worked for me fine, I just repaired placed damaged during rigging procedure.
Martin from Czechia
« Reply #50 on: April 13, 2021, 06:43:19 PM »
Great progress, again. A pleasure to watch.
Offline mess
« Reply #51 on: April 13, 2021, 07:21:02 PM »
I had to modify rods used to control ailerons. I repositioned control stick and ailerons and shortened one and lengthened second rod installed behind fuselage radiators (will be installed later on).
Martin from Czechia
Offline mess
« Reply #52 on: April 13, 2021, 09:26:43 PM »
Next steps were rigging itself and some oil weathering.
Martin from Czechia
Offline mess
« Reply #53 on: April 13, 2021, 09:27:54 PM »
There are control rods installed on second photo, it is visible that they were repositioned to represend non-neutral aileron position.
Martin from Czechia
Offline mess
« Reply #54 on: April 13, 2021, 09:29:27 PM »
More rigging... and you could see how finished "curtains" look.
Martin from Czechia
Offline mess
« Reply #55 on: April 13, 2021, 09:30:22 PM »
And finally some wheel dirt and what is visible from cockpit with fuselage closed.
Martin from Czechia
« Reply #56 on: April 13, 2021, 10:44:16 PM »
Wow, this is stunning! Can't imagine why you call yourself Mess! :)
« Reply #57 on: April 13, 2021, 11:05:32 PM »
It's a great mess of details.
Offline mess
« Reply #58 on: April 14, 2021, 01:20:20 AM »
LF model propeller needed some modification to spinner.
Martin from Czechia
« Reply #59 on: April 14, 2021, 03:06:56 AM »
That’s an amazing model of a beautiful bird!
Best regards,
