Author Topic: Roland C.IIa, WnW 1/32  (Read 9981 times)
Offline mess
Re: Roland C.IIa, WnW 1/32
« Reply #30 on: April 10, 2021, 07:52:06 PM »
... and almost ready to close the fuselage.
Martin from Czechia
« Reply #31 on: April 11, 2021, 08:36:59 AM »
Nnnice. Especially that I have just closed the fuselage on mine  :D
« Reply #32 on: April 11, 2021, 11:24:24 AM »
Everything looks great in place. Excellent work and your detailing shows!
« Reply #33 on: April 11, 2021, 01:17:57 PM »
Beautiful work
Offline mess
« Reply #34 on: April 11, 2021, 09:05:24 PM »
Thanks! :)
With fuselage closed, seam filled with CA glue and cleaned, I started to solve the windows. First I wanted to replace decal curtains with some 3D representation, but I realised that it was painted even in real. Continuing with decals, there was no white on it and was needed to be painted by hand.
My procedure: I placed decals from inside with front face out. painted white and then used oil paints to represent shades from inside the windows. Complete windows were glued to fuselage and masked.
Wings fall perfectly to their places. Not glued yet.
Martin from Czechia
« Reply #35 on: April 12, 2021, 06:17:09 AM »
This one is taking shape nicely, mess - well done.
Offline mess
« Reply #36 on: April 12, 2021, 06:53:16 AM »
Continuing with first camo colour. First I sprayed and masked white squares under crosses and applied brown.
Martin from Czechia
Offline mess
« Reply #37 on: April 12, 2021, 06:55:56 AM »
Brown was GSI, after that I applied two greens by Drooling Bulldog. Awesome paints!
Martin from Czechia
Offline mess
« Reply #38 on: April 12, 2021, 06:56:18 AM »
Martin from Czechia
Offline mess
« Reply #39 on: April 12, 2021, 06:58:15 AM »
Then crosses were masked and sprayed.
Martin from Czechia
Offline mess
« Reply #40 on: April 12, 2021, 06:58:37 AM »
Martin from Czechia
« Reply #41 on: April 12, 2021, 07:11:48 AM »
Absolutely Stunning paint work! What a Beauty this one is!
Offline mess
« Reply #42 on: April 12, 2021, 06:15:51 PM »
Both magine guns were used OOB, I like it more than Gaspatch offerings, it has to thick cooling jackets. The fuselage one was completed, dryfitted, synchro cable replaced with thinner one and complete set was sprayed with gunmetal. Weathering will be applied later.
Martin from Czechia
Offline mess
« Reply #43 on: April 12, 2021, 06:17:32 PM »
And as mentioned before, one hatch cover on engine cover was found unacceptable, so I reworked it by removing it and reworing with sheet of styrene. I also removed all cover locks (or how it should be named :) ) and drilled out their holes.
Martin from Czechia
Offline mess
« Reply #44 on: April 12, 2021, 06:20:55 PM »
Started with decals and creating cover locks. I was afraid of it because fuselage surface in those parts was quite complicated. Decals went fine and with some effort the result seems ok to me.
Martin from Czechia
