Author Topic: Roden 1/72 Bristol F.2B  (Read 7213 times)
Offline Early Bird Fan
« on: February 24, 2021, 04:22:47 PM »
Something i've been meaning to build for a while is a Bristol F.2B, a Roden version in 1/72 came up on ebay at a decent price so here we are
The kit comes with the same detailed engine as the felixstowe but in this kit there's 2 build options which is nice. You can either build normally with engine enclosed or cut the front off, fit some framework and display with engine on show. for this one i opted to build with the fuselage complete which means you don't fit the rocker assemblies or cooling pipes to the top of the engine otherwise it won't fit inside the fuselage. That all sounds great and this is how roden say to build the engine to fit inside the fuselage, i didn't go mad with the paint as it won't really be seen.
This, in reality is what you end up with and this means the fuselage doesn't meet properly in places.
So the ancillaries were cut off along with the barrels, the barrels are now glued directly to the sides of the fuselage and the crankcase is glued to the radiator and bottom of fuselage. It's the only way i could get the exhaust ports somewhere near where they need to be, get the fuselage closed and have the crankcase and thus the prop shaft sitting square. It was a nice idea from roden and cudos for offering a highly detailed engine even though it won't be seen, in hindsight however i feel a much more simplified engine which fitted in the gap provided would have been the better idea for those building with engine cowl in place.
The interior has some nice details but everything was too wide to fit inside the fuselage, the paint looked a lot better before i had to get serious with a file.
Seatbelts are 1mm masking tape painted in radome tan
The fuselage was finally closed up but some areas just didn't want to talk to each other so once the glue had pretty much set i cracked out the sprue goo and pasted it on. I'll leave that for a good 24hrs to go off and then start the cleaning up process
Offline hrcoleman66
Re: Roden 1/72 Bristol F.2B
« Reply #1 on: February 24, 2021, 09:28:14 PM »
Nice little kit from memory...
Looking forward to seeing how it turns out for you.
Hugh
« Reply #2 on: February 24, 2021, 09:52:03 PM »
Off to a good start on this one .  :) Are you replacing the decals ?
« Reply #3 on: February 24, 2021, 10:45:17 PM »
Grat start. The issues with the engine sound similar to the SPAD VII. Your interior looks good and you have made quick progress getting this one together!
« Reply #4 on: February 24, 2021, 11:27:33 PM »
The closeup shots of small parts are always brutal, but in the end, they are hardly noticeable.  Good detail for the scale and I'm glad to see the poor fit of the fuse hasn't discouraged you.
« Reply #5 on: February 25, 2021, 03:28:56 AM »
hadn't really thought about it tbh, any recommendations?
« Reply #6 on: February 25, 2021, 04:37:21 AM »
That looks like a good start but it is annoying when parts do not fit properly. Just hve to get the knife and files out and show it who is boss!
« Reply #7 on: February 25, 2021, 10:52:35 AM »
I have no idea what is out there for replacement decals in this scale . I'm sure the guys that build in this scale will have a better idea then me . Sorry I can't help you out
Offline Rip Van Winkle
« Reply #8 on: February 26, 2021, 02:40:00 AM »
 Print scale makes after market decals for the Bristol F.2B.  #72-234 Bristol F2B aces . I usually try to have some backup decals for any model because of decal inconsistency.
Offline fredjocko
« Reply #9 on: February 26, 2021, 11:17:01 PM »
Very nice detail in such a small scale.
« Reply #10 on: February 28, 2021, 11:13:31 AM »
thanks for the heads up, i'll see if i can find some
« Reply #11 on: March 11, 2021, 05:05:28 PM »
made a bit of progress on the bristol the other day, after a fair bit of sanding back it's not looking too bad and i haven't destroyed any of the details. I need to go back over the seems behind the cockpit with a skim of filler to smooth out some of the pin holes prior to painting that area.
The underside was trickier to sand as this area is not flat so only trying to sand the centre line was a bit tricky, definately another go is needed in this area
The nose section wasn't looking too bad after a bit more sanding with a finer grit so i've given it 4 rather heavily thinned coats of gull grey, i'll buff it back once the filling is done and give it one more coat as the coverage is still a bit patchy in places.
r
« Reply #12 on: March 11, 2021, 10:33:35 PM »
Really nice progress on the fuselage so far  :) Looking forward towards the next up-date !
« Reply #13 on: March 11, 2021, 10:38:07 PM »
Great progress! Like Alexis I am looking forward to the next update!
« Reply #14 on: March 12, 2021, 08:58:33 AM »
Sorry EBF but I somehow missed your last post. Making very good progress - sorting out the underside join looks fun but you have achieved it. The early paintwork looks good.
