Author Topic: Can Lukgraph Sopwith Baby kit be converted to an early Schneider cup racer?  (Read 1384 times)
Offline James Reagan
Has anyone tried this. Also can it be converted  to a civilian aircraft?
Well you will have your work cut out for you , width of the fuselage will need to changed , the cowl , upper decking . strut positions , cockpit layout .
Quick fix would be to change the cowl and upper decking along with the prop . Rest I don't think will make much of a difference when view by others . But yes it can be done depending on ones how far one wants to go .
You mean the Sowith Schneider as flown in Monaco?
I converted on from a special Hobby kit in 1/48, with new wooden floats, engine, cowling, changed fuselage, masks instead of decals, ....
More here: https://forum.ww1aircraftmodels.com/index.php?topic=10864
So I guess this could be done: Just scratch all parts, which do not fit ;)
May be you should start with the Windsock Datafiles and compare the drawings for differences between Sopwith Schneider (Tabloid) and Baby, so you will get a feeling, what can be used from the kit.
Good luck,
