Author Topic: Eduard 1/48 Fokker D.VIII - Polish markings  (Read 9115 times)
« on: January 11, 2021, 04:57:50 AM »
Good evening!
I lost a bit of modelling mojo a while back but have been tinkering a little with Eduards Fokker D.VIII kit i 1/48 scale.
I thought of it as a quick build to sort of just get through... which means that I missed a few details that I now regret... like internal rigging in the cockpit. I thought of getting other versions of lozenge but given the out of the box idea I stayed with the decals supplied by Eduard. There are some things added, but the only innovative thing has to do with the aluminium ammunition (?) box. I'll come back to that. If I was to model another of these I'd probably go with a lighter wood tone as well.
After having started I decided on the following scheme.
Even though I've been a weak contributer on the forum lately, I do pop in to take a look at all the great work done by others. Looking through forum posts gives me a good feeling and in at least one case it's also given me and idea to test. Over in the scratchbuild section Kensar showed a method to replicate turned metal. Ken's build and method. Thanks for the inspiration, Ken!
I thought that a brilliant idea, but I needed the circles to be smaller. A long time ago I converted an old toothbrush head to take a sanding disc. It works wonders when you have to sand something that is a bit hard to reach. With Ken's idea in the back of my head I now converted another head to take a smaller disc, as seen below. The smaller disc is two millimetres in diameter and put to use on a bit of aluminum tape it looks like this. I think it's pretty good, especially when view slightly less close.
So, things were moving ahead despite low spirits and it was time to paint the wing. Following the instructions from Eduard it turned out like this.
At this point I was going to drill through the wing to be able to tension the control wires later and broke the drill inside the wing. Sigh! Efforts to remove the drill bit caused more and more damage to the paintwork and at the same time I was starting to wonder about the streaking on the top side. Looking at Fokker E.V builds here in the forum I came across the idea that the wing shouldn't be dark green or streaked in green and looking at Arma Hobby's instructions for a similar aircraft from the same unit and time period as mine, I'm now thing that I will go with green and brown on the top side and blue and purple (?) on the bottom side of the wing. The picture below comes from the Arma Hobby instructions and it is found at Model Paint Solutions.
Repainting the wing is in progress.
/Fredrik - who really likes being a part of this great forum!
« Last Edit: January 11, 2021, 06:41:52 AM by FAf »
Re: Eduard 1/48 Fokker D.VIII - Polish markings
« Reply #1 on: January 11, 2021, 05:41:32 AM »
Welcome back! and a great idea with the toothbrush. I have a Proxxon sanding stick, bit it do not rotate, so your toothbrush idea is better for that. Could it also polish paint (with more fine polishing material)? For example for a Fokker E.III front.
This is a nice kit, I build that years ago (shown here in the forum). And I have a different meaning regarding the wing colors ;)
« Reply #2 on: January 11, 2021, 05:50:00 AM »
Love it Fredrik,
The metal swirling is magnificent! What a great idea. I’ve got my eye on this kit too...
Online RAGIII
« Reply #3 on: January 11, 2021, 07:08:54 AM »
All is looking great in your interior and also the turned metal! Personally I like the look of the 4 colors on the wings but who knows what is correct. All educated guesses in My Opinion  ::) Looking forward to more!
« Reply #4 on: January 11, 2021, 11:08:00 AM »
Not bad at all Fredrik ! Very impressive work  ;)
« Reply #5 on: January 11, 2021, 04:59:07 PM »
That’s an amazing idea regarding the electric toothbrush. I think that could look great also with bare metal foil on the front parts of a Fokker Eindecker.
Great work all around!
« Reply #6 on: January 12, 2021, 12:00:04 AM »
Thanks Frank! I saw your alternative interpretation of the colours and I might go with that idea. We'll see, but right now I'm testing plywood decals and paint to see what looks best. Apparently these colours were very thin...
I'm guessing that you could polish with the toothbrush as well. I imagine that you could have a whole selection of different heads for different needs. I simply attach my punched sanding discs with double-sided tape. One "problem" is that the toothbrush head goes back and forth and not just around in one direction.
« Reply #7 on: January 12, 2021, 12:03:23 AM »
Thanks Andreas!
I guess the same for just about any kind of material, but that you might have to adjust the coarseness of the sanding paper.
« Reply #8 on: January 12, 2021, 12:04:19 AM »
Thanks Guy, Rick and Alexis! Your support is much appreciated!
« Reply #9 on: January 12, 2021, 12:21:06 AM »
Great extension to the original idea, Faf.  Your method may work well on curved surfaces, too.
I'll be following this build, as I think the D.VIII is very appealing.
« Reply #10 on: January 12, 2021, 02:14:55 AM »
Good to know! That brings me to another idea:
I have a Proxxon Micromot hand drill, on a adjustable power supply. I use it to polish metal parts with a brass brush. Something like that:
I need to reduce the rpm, otherwise all those brass needles fly away ;)
So with an adapter for the punched sanding disc and reduced speed I can use that Micromot tool too.
I forgot yesterday to mention the two wings of your kit. Do you know the reason?
It is stated in the manual on the first page. One wing has a simulation of a wavy surface, like the wood was wet. It is visible in a side view :D
« Reply #11 on: January 12, 2021, 08:00:36 AM »
Great original idea, Kensar! 😃
Thanks for looking in.
« Reply #12 on: January 12, 2021, 08:02:49 AM »
Frank: I used the plywood wing first but with the drillbit firmly lodged inside it, I've now switched to the other one.
« Reply #13 on: January 12, 2021, 08:30:16 PM »
Very fine work aith great ideas (toothbrush :)). And I am so glad you chose the Polish scheme.
Offline fredjocko
« Reply #14 on: January 14, 2021, 02:30:43 AM »
Very nice!! I was in a slump last year and decided to build the same kit as it looked "simple". That is a great idea on the aluminum. I will have to try that on my next one.
