Author Topic: 1:32nd scale - Ansaldo A.1 'Balilla'  (Read 25130 times)
Offline AndRoby67
Re: 1:32nd scale - Ansaldo A.1 'Balilla'
« Reply #60 on: January 08, 2021, 03:30:35 AM »
Hi Mike!
There are two italian Aces pictured with right side of a 70a Squadriglia's Balilla and no traces of the two strange bands on turtledeck of that side.
Another strange thing to me are the bend exhaust tubes, the last two in the line. 16552 and 16553 have original straight exhaust tubes and here some other useful photos: http://www.airwar.ru/enc/fww1/a1.html
Other interesting photos here: http://www.cmpr.it/Balilla%20-%20E.Molteni/balilla.htm
Hope useful!
Roberto
P.S.: Good that you had corrected serial number on your model: two different italian sources mentioned 16558 as the mount of Eleuteri on the only Balilla's victory of entire WWI.
« Last Edit: January 08, 2021, 03:49:42 AM by AndRoby67 »
Offline Fvdm
« Reply #61 on: January 08, 2021, 03:58:17 AM »
Just fantastic.
« Reply #62 on: January 08, 2021, 09:54:47 PM »
Hi Mike!
Hope useful!
Roberto
P.S.: Good that you had corrected serial number on your model: two different Italian sources mentioned 16558 as the mount of Eleuteri on the only Balilla's victory of entire WWI.
Hi Roberto,
That's good to know,
Yes that photograph was apparently a 'factory' shot.
That engine does have bends in the exhaust pipes, but I can't find any information why.
All other references show all pipes straight, although Windsock data file states that on some aircraft, the second pipe from the rear was longer?
Thanks again,
« Last Edit: January 08, 2021, 10:18:37 PM by Mike 'Sandbagger' Norris »
Offline fredjocko
« Reply #63 on: January 08, 2021, 10:53:49 PM »
Your fuselage looks fantastic!
« Reply #64 on: January 09, 2021, 08:45:17 AM »
Some modellers think photo-etch 'is your friend'.
Here are the wing and strut rigging attachments plus the aileron control levers.
All are photo-etch and with self-aligning 'hinged' anchor plates for attaching the rigging lines.
« Reply #65 on: January 09, 2021, 08:52:31 AM »
Outstanding progress. I am amazed at the details Aviattic included but it takes a Real Modeler to bring it all together!
« Reply #66 on: January 09, 2021, 11:28:19 PM »
PE is the devils details ...you got him beat !
Offline Fvdm
« Reply #67 on: January 10, 2021, 06:45:23 PM »
Great work on the PE.
« Reply #68 on: January 13, 2021, 07:56:58 AM »
I've finally applied all of the required decals.
Accurate cutting out of the decals is necessary for the wing coverings and alignment of edges is necessary.
Slight overhang of dried decal was gently sanded away.
Weather, although slight, was done using 'Flory Models' Dark Dirt fine clay wash, sealed with 'Alclad' Semi-Matte lacquer.
Now it's onto fitting the photo-etch rigging anchors before pre-rigging is carried out.
« Reply #69 on: January 13, 2021, 09:49:40 AM »
Excellent work on the decals and wash Mike. Looking Great!
« Reply #70 on: January 13, 2021, 06:57:53 PM »
Another masterpiece in the making
« Reply #71 on: January 13, 2021, 09:08:48 PM »
excellent paint and weathering, Mike.
« Reply #72 on: January 13, 2021, 11:42:46 PM »
Very nice looking colours! I'm also very impressed with your PE-work! Fiddly - but self leveling attachment points sounds nice.
« Reply #73 on: January 14, 2021, 09:52:06 AM »
An example of pre-rigging a twin flying wire anchor for the lower wing roots.
A combination of 0.08 mm and 0.15 mm diameter mono-filament and 0.4 mm and 0.5 mm blackened brass tubes.
All together there will be sixteen various types of hinged rigging anchors to pre-rig before the wings are fitted,
« Reply #74 on: January 14, 2021, 10:00:31 AM »
Mike, Your rigging is truly magnificent! I m envious of your talents to say the least!
