Author Topic: 1:32nd scale - Ansaldo A.1 'Balilla'  (Read 25203 times)
Re: 1:32nd scale - Ansaldo A.1 'Balilla'
« Reply #45 on: January 02, 2021, 07:27:30 AM »
That wood grain and rivet effect looks excellent. The fuselage is shaping up beautifully Mike.
« Reply #46 on: January 02, 2021, 12:01:48 PM »
Beautiful work!
« Reply #47 on: January 03, 2021, 01:11:17 AM »
I just love it! Absolutely convincing and a wonderful lesson in different techniques... Regards, Marc
« Reply #48 on: January 03, 2021, 03:28:46 AM »
Just a quick update.
The 'Aviattic' fuselage wood effect decals have circular access panels printed, but these look rather ‘flat’.
Therefore to raise these panels and make them stand out more, I added extra decals.
I'm now working my way through the fuselage photo-etch,
« Reply #49 on: January 03, 2021, 07:44:58 AM »
Ad my kudos to all the above, await completion !!
« Reply #50 on: January 03, 2021, 07:59:40 AM »
Yep, better with each update Mike!
« Reply #51 on: January 03, 2021, 08:39:40 AM »
Very fine. Great to see you solve little and bigger problems. Pity you could not effectively use the HGW nail head decals. I have found them very attractive on the bright wood in my Polish A.1.
« Reply #52 on: January 03, 2021, 10:21:26 AM »
Yes your build and others is why I tried them, but as I said you can barely see them on dark wood.
Offline AndRoby67
« Reply #53 on: January 04, 2021, 03:10:54 AM »
Hi Mike!
I reply now to your email, I see now that some of my comments are in late.
First of all is that fuselage sides of Balillas were not cutted in the manner of kit's decals.
This is for all of you that have same kit to build.
I will follow your build, the kit is well realized by Aviattic but not so accurate, first in colors.
Here some useful photos, 16553 was 90% original when we started to restore it, in 2003:
https://gavs-torino.com/2015/04/07/ansaldo-a-1-balilla/
Roberto
« Last Edit: January 04, 2021, 07:58:46 PM by AndRoby67 »
« Reply #54 on: January 07, 2021, 08:45:25 AM »
Hi Roberto,
As usual, thankyou for your help  :)
« Reply #55 on: January 07, 2021, 08:45:49 AM »
The basic fuselage is now complete, apart from the windscreen and flying wire anchor points.
The final display will be the aircraft undergoing engine maintenance, so the engine front twin cowl panel will be removed.
I’ve added the coolant/vent pipe from the rear of the radiator header tank, made from 0.5 mm tube.
Two bracing lines were fitted between the forward fuselage cabane struts and an inverted tubular ‘V’ frame, which was attached to the insides of the fuselage and over the top of the engine camshaft.
This was made from formed 0.8 mm diameter tube with ’GasPatch’ resin 1:48th anchor points.
A tubular retaining frame was fitted over the inverted ‘V’ frame and attached to the inside of the fuselage sides.
This was made from annealed 0.375 mm diameter copper wire.
I’ve changed the aircraft serial number by replacing the number 3 with the number 5.
The supplied decal for the particular aircraft is 16538.
However is seems the only ‘Balilla’ aircraft serial numbers recorded for No:70a Squadriglia were 16550, 16555, 16556 and 16558.
Therefore my assumption is that this aircraft serial number was probably 16558, not 16538.
Also this aircraft had two light coloured bar markings on the left of the turtle decal, just behind the cockpit.
The exact colour of these bands is not known or if they were repeated on the other side of the turtle deck.
Now onto the undercarriage before starting on the wings and rigging preparation,
Offline Dave Brewer
« Reply #56 on: January 07, 2021, 09:02:10 AM »
Simply stunning Mike, great update.
Dave.
« Reply #57 on: January 07, 2021, 12:02:20 PM »
Looking good Mike
« Reply #58 on: January 08, 2021, 01:25:22 AM »
A great milestone - completing the fuselage.  This build is progressing nicely, with your attention to detail.
« Reply #59 on: January 08, 2021, 01:51:03 AM »
Superb as always Mike!
