Author Topic: Roden 1/72 Felixstowe F.2A  (Read 6374 times)
Offline Early Bird Fan
Re: Roden 1/72 Felixstowe F.2A
« Reply #15 on: November 28, 2020, 02:54:14 AM »
thanks for the comments and for looking in on my project
I've got he fuselage halves finished and joined together, the fit is pretty good and only a slight fettling was needed.
I've put part of the carriage together and PVA'd it to a couple of stirring sticks, this should give me a steadier platform when fitting wings etc.
The upper wing is now assembled and I added a couple of .8mm brass pins to give it a bit of strength.
The underside of both wings are now painted, they look white but do have a slight shade to them, i mixed up mainly white but added some brown and grey to create a slight off white colour, gotta be honest it looked a bit darker in the mixing pot than it does on the wing but when seen next to white you can tell the difference.
Before painting i used a pencil to add some dark grey to the spar grooves on the underside, after a few coats over the top of the pencil lines i think it looks ok
« Reply #16 on: November 28, 2020, 12:16:36 PM »
Nice progress EBF , using the dolley as a building base is an excellent idea  :)
Offline malaula
« Reply #17 on: November 28, 2020, 10:37:14 PM »
Hi Early Bird Fan! looking good so far..just one hint: the outer parts of the wings should be fitted with a slight dihedral ,most important because otherwise the wings will appear sagged after assembly.
cheers
mathias
« Reply #18 on: November 29, 2020, 12:44:00 AM »
It looks like your pencil lines did the trick! Looking excellent!
« Reply #19 on: November 29, 2020, 03:35:07 AM »
cheers
mathias
thanks for the tip, i'll try and build them as you suggest
« Reply #20 on: November 29, 2020, 04:10:56 AM »
Looking very good so far. I'll try to remember the tips for when I build mine!
« Reply #21 on: November 29, 2020, 05:16:37 PM »
Some very neat and beautiful work! I do like your effects on the wing underside... Marc.
Hector Sauvage
« Reply #22 on: December 02, 2020, 03:42:18 AM »
You have to love Roden. In this somewhat mean-spirited age, opening up their Ni. 27 yielded half a Sopwith F.1 on the rotary sprue. Very nice. Buying them from everywhere now, where possible.
Good luck, she's looking fine already: such a beautiful bird.  :)
« Reply #23 on: December 04, 2020, 03:48:19 AM »
Just catching up EBF: you are making excellent progress with this monster. I like your jig for supporting the wing assembly while it dries!
Offline Fvdm
« Reply #24 on: December 04, 2020, 04:50:27 PM »
Even in 1:72 this is a big bird. I think the progress so far looks real good
« Reply #25 on: December 06, 2020, 06:55:39 PM »
This is a great build and I think it looks brilliant!
I have this one in my stash too and I am following with interest.
