Author Topic: Fokker D.V, Special Hobby 1/48; Update 21.12.20 Finished  (Read 41610 times)
Re: Fokker D.V, Special Hobby 1/48; Update 14.12.20 New legs
« Reply #120 on: December 15, 2020, 06:59:12 PM »
What a stunning job of micro soldering!
« Reply #121 on: December 15, 2020, 11:26:50 PM »
As always your scratch built struts are better than the kit supplied version...By FAR! Lovely work Frank!
« Reply #122 on: December 15, 2020, 11:34:47 PM »
Your landing gear looks great - and they fit.  What's the plan for covering the front tubes?
« Reply #123 on: December 16, 2020, 12:26:47 AM »
Thank you Terri, Ferry, Willem, Rick and Ken for leaving a comment!
Good catch!
There are pictures available showing some D.V without covering, but most of them had one.
The plan is to use wood, as on wing struts, for the back strut and to cover the front struts with paper (remains of the recent Derperdussin Monocoque project).
« Reply #124 on: December 16, 2020, 06:58:40 AM »
Quote: "looks nice I think". Really Frank, you are German and we Brits are supposed to be the masters of understatement...!
Personally I think you solution to the undercarriage problem is much like your other solutions - b.....y marvellous!
Fokker D.V, Special Hobby 1/48; Update 15.12.20 Crash!
« Reply #125 on: December 16, 2020, 07:43:59 AM »
Thank you Stephen ;)
I didn't want to post any pictures today, but what just happened almost gave me a heart attack!
Crash!
Today I nearly lost the model!
But one step after another.
This late afternoon I added wood to the back strut and covered the front struts with paper.
Paint is missing, but the new gear looks promising.
Shortly after that picture (I have moved the lamps for better picture light before) the heavy head of a lamp with 1.9kg (with two light tube and a huge magnifying glass between them) crashes down to the bench only 10cm right of the model!
Reason: the adjustment and holding clamp breaks into parts  :o :o :o The round parts were still on the arm.
I'm soooo happy, that the model survived! :)
Need to fix this to be able to work in this dark late afternoons and evenings.
« Last Edit: December 16, 2020, 07:58:31 AM by Bughunter »
Re: Fokker D.V, Special Hobby 1/48; Update 15.12.20 Crash!
« Reply #126 on: December 16, 2020, 10:58:43 PM »
It's a lucky model - better keep it!
It's a shame that the struts and landing gear are painted.  I like the look of the metal and wood.
Offline O_Pablo
« Reply #127 on: December 17, 2020, 01:37:27 AM »
Let's be to glad that the model has survived!
Offline Fvdm
« Reply #128 on: December 17, 2020, 01:38:22 AM »
Oops   :o
« Reply #129 on: December 17, 2020, 02:32:59 AM »
Everybody is entitled to a little luck every now and then!
« Reply #130 on: December 17, 2020, 04:20:57 AM »
I was Really Concerned when I read the subtitle! I thought 2020 had claimed yet another build  ::) I am so relieved that the lamp Missed the Model  ;D The lamp is easier to replace  ::)
« Reply #131 on: December 17, 2020, 04:43:05 AM »
Thank you my friends!
Oh yes Rick, from that point of view a accident like that would match the row of bad things happens this year!
On Scalemates some other modelers reported the same issue with words like this: "Same lamp, same supplier, same problem...." Even different lamps types and arms using the same moulded zamac pieces. So if your lamps shows some clamps at the end of the arm be warned!
I like it too ??? I will scratch it here and there to show the material below.
« Reply #132 on: December 17, 2020, 06:07:59 AM »
Just caught up Frank - for a moment I thought that this was going to be number three (following Rick's two disasters). That was a lucky near-miss. Hoping for better luck in future - with a stronger fixing on the lamp.
« Reply #133 on: December 17, 2020, 06:31:06 AM »
I forgot to mention that the Landing Gear looks perfect! Great job as always Frank!
« Reply #134 on: December 17, 2020, 07:33:03 AM »
Stephen and Rick, you always have a kind word for me, thank you!
So I have a big chance, that this model will be the finished one number 8 this year.
I think I will paint but not yet mount it. So it can dry and I will try to do the rigging on Friday using the day light.
Then mount the u/c and add gear rigging and the line to the front. At least that is the plan.
