Author Topic: Wire source  (Read 4709 times)
Offline petrov27
Wire source
« on: December 11, 2012, 12:23:19 AM »
Hi All - does anyone have a source in the USA for fine gauge straight lengths of stainless wire suitable for rigging purposes in 1/32? I had bought some from Sprue Brothers ages ago from a company called Minimeca but they dont seem to offer it anymore.
Thanks!
-Patrick
Offline Chuckt5
Re: Wire source
« Reply #1 on: December 11, 2012, 02:01:44 AM »
I'm not sure what sizes you need, but Albion Alloys has an excellent selection of rod and tube in various sizes.
Offline eclarson
Re: Wire source
« Reply #2 on: December 11, 2012, 08:15:25 AM »
I buy mine from Small Parts, Inc. which is now part of the Amazon family.
http://www.amazon.com/exec/obidos/tg/browse/-/16310091/ref=16310091?
I've purchased all kinds of fine tubing and wire from them over the years, most recently some Nitinol wire for rigging experiments.
http://www.amazon.com/dp/B003R5028K/ref=biss_dp_sa2
First time shoppers may find the the size searching confusing and also note that prices are all over the place.  Shop carefully and you'll usually find plenty of what you want at a good price.  Sometimes it's better to buy one really long piece vs. several shorter ones, but it can also work the other way around.
HTH,
Eric
Offline petrov27
Re: Wire source
« Reply #3 on: December 11, 2012, 08:51:27 AM »
Excellent - thanks - I will give them a shot!
HTH,
Eric
-Patrick
Offline Chuckt5
Re: Wire source
« Reply #4 on: December 11, 2012, 12:24:34 PM »
Thanks for the link's Eric. One question though, how do you navigate amizons search when looking for small diameter tube from industrial scientific?
I've entered in.3 mm aluminum tube and aluminum tube and it shows everyhting BUT what I'm looking for!
Any hints on how to find what I want?
Offline eclarson
Re: Wire source
« Reply #5 on: December 11, 2012, 02:05:09 PM »
It takes some fiddling.  I started by searching for "aluminum tubing" and got here
http://www.amazon.com/s/ref=nb_sb_noss?url=node%3D383597011&field-keywords=aluminum+tubing
Scrolling down, for example,  pick Aluminum 3003 Seamless Round Tubing.  That will take you to the page where you can see available sizes.
Unfortunately, I don't see any as fine as you desire.  By .3mm (0.012"), are you talking inside or outside diameter?  I don't know if aluminum tubing is made that small.
Is there a reason you need aluminum?  I usually buy stainless hypodermic tubing but also like Polyimide tubing which is a type of nylon and can be found in very small diameters.  I use the latter for 1/48 turnbuckle bodies as it's much easier to cut than metal.
Eric
Eric
Offline Chuckt5
Re: Wire source
« Reply #6 on: December 11, 2012, 03:21:20 PM »
I want .3mm external diameter alum tube for making some tiny drain valves. I have some tubing that small in brass, but its tough on my drill bits! I'm hoping alum will be easier to drill through.
I was able to find some .3mm diameter alum tube on another website. Albion alloys offers tube this small but they are kind of hard to get a hold of. I ordered thier product from another website.
Thanks again, Chuck.
Offline eclarson
Re: Wire source
« Reply #7 on: December 12, 2012, 05:12:00 AM »
Glad to hear you found some.  Good luck with your valves!
You're welcome.  I wish I could have been of more help.
Eric
Offline Chuckt5
Re: Wire source
« Reply #8 on: December 12, 2012, 07:22:17 AM »
It will probably be a good source of items in the future, so you were a help thanks!
I have ordered from them (before they were on amazon) but couldnt find them anymore, so its good to know where to find them now.
Merry Christmas to you and your family, Chuck.
Dicecaller
Re: Wire source
« Reply #9 on: December 12, 2012, 07:32:04 AM »
Greetings,
If you are looking for fine gauge wire; I highly recomend  http://stores.ebay.com/Jacobs-Online  He offers NiCr Resistance wire in several gauges and multiple lengths (including 10ft 'trial' size).
The 38 Gauge is 0.1mm and very easy to work with.
I hope this helps.
Shane
Re: Wire source
« Reply #10 on: December 12, 2012, 09:49:02 AM »
I'll second Shanes's recommendation. I've dealt with them several times for different diameter wire and when buying it in spools, it's excellent value.
Offline petrov27
Re: Wire source
« Reply #11 on: December 12, 2012, 10:35:41 AM »
I am curious about the nitinol wire - how did your rigging experiment with that go?
Thanks!
Eric
-Patrick
Offline eclarson
Re: Wire source
« Reply #12 on: December 12, 2012, 10:54:45 AM »
Thanks!
Eric
I wish I could tell you but I haven't had a chance to use it yet!  It does appear to be very promising though.  The .005" is so fine it's almost invisible.
My thoughts are to use it in short lengths for internal bracing and control cables.   .006 to .008" would be good sizes for 1/32.
Eric
Offline petrov27
Re: Wire source
« Reply #13 on: December 12, 2012, 11:57:02 AM »
Eric
Ahh - no worries - I went ahead and ordered a bit of it to try it out myself. Thanks again!
-Patrick
Offline miamiangler
Re: Wire source
« Reply #14 on: December 14, 2012, 05:49:14 AM »
I just got my order of micro tubing from JBModel.EU.It was here in less then a week shipping was 5.44 for 28g but it was the only place I found that carried tubing in 0.3,0.4 ,0.6 mm .I would check the site out .
