Author Topic: Special Hobby 1/48 Phonix D.II - In-Box and Build Review  (Read 7173 times)
Offline Brad Cancian
    • Brad's Models
« on: October 05, 2020, 01:14:12 PM »
Special Hobby 1/48 Phönix D.II
Reviewed by Brad Cancian
Item: SH48036
scale: 1/48
Price: Varies – 28 Euros direct from Special Hobby, $US34 MSRP in USA. Available through hobby retailers worldwide.
Review kit kindly provided by Special Hobby at https://www.specialhobby.eu
The Phönix D.II
The Phönix D.II was a successful development of the likewise successful Phönix D.I fighter. The D.I, though a competent aircraft design with good manoeuvrability, was still slower in speed and in climb than its contemporaries, such as the Hansa-Brandenburg D.I. As such, with the D.II came a lightened airframe to improve speed, a shortened fuselage, and redesigned wings and tailplane. Compared to the Phönix D.I, the D.II maintained the good manoeuvrability of its predecessor, but with an improved maximum speed and rate of climb, whilst mounting the same Heiro 200hp engine. A further development of the D.II, the D.IIa, was the same in all respects aside from a more powerful Herio 230hp engine.
Introduced into service in March 1918, the Phönix D.II saw service with both the Austro-Hungarian Air Force and Navy.  The Phönix D.II served until the end of the war, and alongside the Oeffag Albatros series of fighters, was amongst the best machines in Austro-Hungarian service.
The Bits and Bobs
Special Hobby’s Phönix D.II was released around 2005, and despite its age, it is still available to purchase today. Like the real aircraft, the Phönix D.II kit is a development from the earlier 2004 Phönix D.I release, and shares some common parts. It is presented in Special Hobby’s typical small black-bordered box of the time. Special Hobby have always presented lovely and evocative box art, and this one is no different. This kit was produced in the years where Special Hobby was still very much a limited run manufacturer, and those of you familiar with Special Hobby’s products of the time will know what to expect. The plastic is well done; crisp yet easily workable, if not a little thick, with a little bit of flash. You also get some resin, and some etch. Even though the plastic is limited run, with some large sprue gates, they parts are none the less crisp and well moulded. The kit has a low parts count; 38 plastic parts (three of which are for the D.I and are not used), 18 resin parts (including alternate exhausts), 17 etched parts, and two clear film windscreens and a clear film instrument panel.
The plastic comes on three sprues. Sprue A contains the detail parts; engine, wheels, struts, and cockpit. Interestingly, sprue A also contains fuselage halves and vertical stabiliser for the Phönix D.I, which you don’t use. This shows that this sprue has commonality with the earlier kit. Parts are nicely moulded, but their limited run origins (and possibly the age of the moulds) show a little; there is some flash, and some blobby plastic between some of the engine cylinders which will need to be cleaned up. Nothing that can’t be relatively easily dealt with.
Sprue B contains wings (upper and lower), tail planes, propeller and tail skid. The wings are thankfully moulded in one piece, which will make alignment a breeze. Surface detail on the wings and tailplane is nicely restrained but present, with subtle impressions of ribs which look wonderful in this scale and compare nicely to overdone offerings of other kits. The ailerons and elevators are crisply moulded, with the former having nice representation of the aileron wash out present on the real thing. The only downside with the wings is that there seems to be a bend in the wings at the centre, giving an odd ‘humped’ appearance when view head on. This is possibly an issue with the moulding, or the plastic ‘sagged’ slightly when cooling, causing a bend from the sprue attachment points. Though it is only slight, it is obvious once you see it. You could live with it, but if you wanted to be accurate, this will need to be corrected as the leading edge of the wing is straight from tip to tip. There is some flash around the parts, but again, nothing that can’t be dealt with. The propeller boss detail is a little blobby, but present. Some care will be needed to clean up the prop and retain the detail due to the location of the attachment points.
Here's the bend in the wing:
Sprue C contains the D.II fuselage parts and vertical stabiliser. Detail here is lovely and crisp, with some wonderful fastener and hatch detail. The interior of the fuselage sides have no detail other than some mould release pins (which should be easy to clean up) and some feint lines for locating the cockpit parts.
Resin parts consist of a lovely radiator, gun troughs, and exhaust stacks. Two different exhaust stacks are provided, depending upon the version you choose to build. Also includes is a small resin pistol, fitted to one of the marking choices; a nice touch. Etched parts consist of seat belts, tailplane struts, gun sights, an etched instrument panel, and other bits and bobs.
Instructions
Instructions are provided in a small eight-page black and white booklet, with a history of the aircraft and technical specifications on the first page, and an illustrated parts breakdown on the second page. Unfortunately, no rigging guide is provided. Markings are provided for two aircraft. Construction is quite standard, beginning with the interior, then engine, and major construction. The instructions tell you which of the colour schemes carried what exhausts and other bits and bobs.  Paint callouts are Gunze, as is usual for Special Hobby.
Colour schemes for two machines are provided in this boxing; both are mottled green overall. One of the aircraft has earlier Maltese cross markings, and the other has straight cross markings and a nice red fuselage band and ID stripes along the leading edge of the wing. It would have been nice to have some more colourful markings (i.e. Austro-Hungarian Navy markings with red / white striped wings), but that is only a minor gripe.
Marking options are:
•   Phönix D.II  222/10, Flik 55J, June / July 1918, Pergine airfield, Oblt. Eduard Ritter von Hebra
•   Phönix D.IIa, 442.30, Flik17J, October / November 1918, Feltre airfield, Fw. Karl Teichmann
Decals
The decals are done by Aviprint and are very nicely printed. The carrier film is glossy and thin, and the density and register look spot on. No complaints here.
Accuracy
I used the Windsock Datafile on the Phönix as my primary reference. The Phönix D.II was big for a fighter, and the overall dimensions and panels accord to the datafile, which was clearly used as the primary reference. As noted, the centre section of the upper wing is bowed and will need to be corrected by those inclined by bending in some hot water.
Not surprisingly, for such a low parts count, detail is a little sparse in places. The cockpit, for example, consists of a floor, bulkhead, seat, seatbelts, stick, rudder bar, instrument panel and shelf, and nothing else. There are no fittings such as a throttle, or any other detail. This is slightly disappointing given the cockpit opening is quite large; detailers could go to town here. The engine is also a little simple, but most of it will be hidden under the cowlings, so not much to worry about here. Speaking of the engine, there is only one engine provided (noting the D.II and D.IIa had different engines) – from my research, the cylinders seem to look roughly the same, so it’s fair to represent both a D.II and D.IIa from this kit (as Special Hobby has done). I also note that there is no cut out in the starboard nose cowl for the engine induction pipes; these will clash with the cowl if left as is, not allowing the fuselage halves to come together; one to watch for when you build this kit. Lastly, the kit has an interesting minor omission; whilst the control horns for the rudder are included, none are included for the ailerons. This is odd, and I can only put this down to an oversight by Special Hobby. Thankfully, these should be easy to add for those so inclined.
The markings represent machines photographed and included in the datafile, and the markings and decal guide look accurate.
In-Box Conclusions
This is another nicely done kit from Special Hobby of an interesting and not oft seen subject. Construction should be straight forward, simplified by the low parts count and single piece wings, but you’ll have to make the choice about straightening out that upper wing. There is room for improvement, as is the case in most kits, but the kit provides a very solid foundation. There is no other competition in this scale, and the model’s size, combined with the unique speckle camouflage seen on these machines, will provide something unique and eye-catching in the display cabinet or competition table. The proof will be in the build, but based on what’s in the box, this is another excellent package from Special Hobby!
Our thanks to Special Hobby for the review sample
Now, onto…
    • Brad's Models
Re: Special Hobby 1/48 Phonix D.II - In-Box and Build Review
« Reply #1 on: October 05, 2020, 01:15:35 PM »
The Build!
I decided to get into this build pretty much straight after receiving the review sample. My intent was to build this one completely out of the box, with no additions. So, how does this one build up with what you get in the box?
First is first, I decided to tackle the bent upper wing. It effectively requires a couple of bends to straighten out the ‘hump’. I dipped the wing in warm water and gently applied pressure; I got one side ok but then, ‘snap’, I now had two wing halves. Darn. Thankfully the wing split cleanly and essentially straight down the middle, so it wasn’t too worrisome to glue it back together with minimal clean up. The wing still isn’t dead flat, but after one incident, I wasn’t willing to push my luck again. It’s what I call ‘straight enough’.
As noted in the review, the interior is spartan; a basic cockpit, an engine, and that’s that. I started with the engine; this builds up relatively simply. There are some large ejector pins on the inside which need to be sanded slightly to bring the two engine halves together. The blobby plastic bits between the cylinders was cleaned up as best I could before it all came together. I then cut out the holes in the starboard engine cowl for the induction pipes – without these, the engine won’t allow the fuselage halves to come together. What is also interesting in this kit is that there are no positive mounts for the engine inside the fuselage halves; the engine glues into the hole for the propeller shaft and essentially ‘hangs free’. I think the reason for this is to allow the engine to be ‘pushed’ down by the radiator pipes when the upper wing is fitted, so that the radiator pipe looks connected to the upper wing without actually impeding the fit of the wing. It’s not the greatest approach in my mind; the last thing I wanted was the engine breaking free during construction. As such, I used a small piece of plastic, glued to the fuselage side, for the engine to sit on. The plastic was only glued on one side of the fuselage, so that it could act like a cantilever, allowing the engine to flex slightly down into the fuselage should it be needed when the upper wing went on. I left off the exhaust pipes, to be fitted after painting of the airframe. The engine was painted aluminium, with the induction pipes picked out in black as per the instructions, and the assembly was given a black / brown oil wash.
With the engine done, I moved to the cockpit. It’s all pretty simple and everything is effectively painted ‘wood’, including the seat. I sanded back the small ejector pin marks in the fuselage halves, and assembled the basic details. I decided to use the plastic instrument panel, instead of the etched piece, as the plastic piece has some nice prominent ‘bezels’ for the instruments. Some fettling was required to get a good fit for the panel and its ‘shelf’, and the rear bulkhead; even then I didn’t quite get the instrument panel to fit nicely. One to watch for if you’re building this kit. I also added a couple of strips of plastic to aid with locating the bulkheads and getting a solid fit. Everything was then painted ‘wood’ using oil paints, with some shading done using Tamiya ‘smoke’. Belts were added and painted white, and various details picked out in silver, with a black / brown oil wash. The cockpit was glued into the starboard fuselage half, and that was the interior done.
The fuselage halves went together ok, but some clamping was required around the engine cowl, and behind the cockpit – this was most likely of my own doing in not being careful enough with my dry-fitting and positioning of parts. The only filler that was needed here was immediately behind the cockpit (again, of my own doing). Once the fuselage halves were together and cleaned up, I drilled out the small cooling holes on the front of the cowl.
Next, the lower wing was added. The fit was snug and solid, and the join only required a little bit of filler. Next, the horizontal stabilisers were added. Note that the small hatches on the rear fuselage impede upon the fit of the stabilisers, so I trimmed the hatches back slightly. There was still some minor filling needed, but nothing significant. The vertical stabiliser went on without too many problems, but I did shorten and thin the attaching tab to make sure it didn’t cause fit issues or split the fuselage halves. At this point, I cleaned up the struts, widened the strut attachment holes, and added some small plastic tabs to the cabane struts, to allow for a more positive fit later on. The airframe was then ready for painting. I masked off the engine and cockpit, primed the airframe, cleaned up the bits I’d missed the first time, and primed again.
Deciding to use the kit decals, I went with the scheme on the box top (Phönix D.IIa, 442.30, Flik17J, October / November 1918, Feltre airfield, flown by Fw. Karl Teichmann). According to the datafile, the real D.II aircraft was left in clear linen flying surfaces and varnished wood fuselage, with a mottle applied on the upper surfaces by hand with sponges at the factory. The mottle, according to the data file, came in a green variety and a brown variety; the instructions state green stippled spots, so I went with a green finish.
I painted some rib detail on the under-surfaces of the wings and applied light coats of linen to help give the rib detail a slight ‘see through’ effect. I painted the wooden fuselage and propeller using streaked burnt sienna oil paints, and once dry, I masked and sprayed the cowl panels and hatches using alclad airframe aluminium. I masked off the leading edge bands on the upper wing; Special Hobby provide these as decals but I didn’t really want to muck about with these.
The mottle was always going to be the hard part; I thought about trying to spray it but then I thought this might be a bit of a disaster, so I decided to apply it the same way they did at the factory – by hand. I used a piece of old dish sponge, dipped in paint, to apply the mottle. The colour was a combination of Humbrol 30 and Humbrol 120 (in hindsight, this is a little too green; next time I think I’ll add a little brown). I had to make this dense enough to cover the colour differences between the fuselage, wings, and cowl, but not so dense as to not be able to see the base colours poking through. One I had achieved what I thought was ‘enough’ mottle, I applied a little bit of thinner to a brush, and using a dabbing motion, blended the mottle just slightly. This was done to help provide a slightly more uniform colour, but still give the correct impression of hand application. I was still left with a bit of a bumpy surface, so once dry I attacked the surface with some 2000 grit sandpaper. This took off some of the bumps (and in some cases, too much of the paint), but thanks to the enamels, it is nowhere near a smooth surface. Next time I try a finish like this, I think I’ll need to find a more level enamel paint, or a slower drying acrylic. In any case, with this done, I painted the red fuselage and wing bands and glossed the model in preparation for decals.
The decals went on beautifully and without any problems. They are reasonably thin, tough, adhere nicely, and respond to decal softener. No complaints here. Once dry, I applied a clear coat and masked off the wing ribs, cowl and hatches in preparation for shading. I used thinned black / brown (more brown than black) for the shading, going over the ribs and around the panels. This always helps to ‘pull’ the look together. I went a bit over the top here and there, but I felt this was necessary given the nature of the mottled finish. Once this was done, the masking was removed (thankfully very minimal decal lifting), and the panels given a wash of black / brown oils to help ‘pop’ out the details. The exhaust pipes, cockpit head padding and gunsight were added at this point. The pipes were an absolute pain to get on, in the end I taped a q-tip to the fuselage sides for the pipes to rest on as the glue dried; they’re not 100% even, but again, good enough.
Next the fun part – struts, rigging, and upper wing. I found during test fitting that the aft interplane struts (part A16) were too long, so I trimmed these a couple of millimetres to fit. At some point I got something slightly off, as though they fit nicely during test fitting, when I went to actually glue the struts, the starboard rear strut was short by about 1mm. As a result, I had to pad this out post gluing the rest of the wing. Oh well. I did find that the upper wing sat nice and snug with the engine radiator piping, and the wing was more or less square, so I don’t think that I got any of the struts mixed up; whatever went wrong was clearly of my own doing… in any case, one to watch for.
Rigging was done using Uschi rigging elastic, without any turnbuckles (sticking with the out of box approach). Once the wing was on, it was a simple matter of adding the remaining bits and pieces to the exterior, i.e. the radiator, rudder control horns, tail struts, undercarriage, and prop. Again, no fit or alignment issues here. And with that, she was done. And here she is:
Conclusions
All in all, my in-box impressions were backed up by my build experience; this is a lovely and eye-catching model, that builds up quite nicely out of the box. If you approach this kit like a limited run kit, you will have an enjoyable build experience. The kit also offers tantalising possibilities for the detailer – the cockpit is big, open, and crying out for more detail. Likewise, the engine is prominent, and the detailer could go to town here. There are some minor fit issues (plus that slightly annoying upper wing), and some minor omissions here and there, but nothing that can’t be overcome with the slightest of efforts. For me, the most challenging part of the build was the painting; not having done a mottle scheme before, and being primarily an airbursh painter, I had some challenges, but this was all my fault (I learned a lot for next time). Likewise, my challenges with the wing and struts were pretty much of my own doing, so I can’t complain there.
As such, I would recommend this kit highly to anyone with a couple of WW1 kits under their belts; you’ll be rewarded with a pleasant build experience, and a unique looking model – its size and colour scheme certainly makes this one stand out in my cabinet!
BC
Thanks again to Special Hobby for the review sample and lovely build experience!
